Old 07-26-2024, 10:42 PM   #113
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
When the pics I post from my iPhone turn sideways I crop a little off the top and bottom and repost them. Works every time.
You’re a scholar ! It worked! I miss you guys over there in the Motor City
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
Old 10-23-2024, 09:09 PM   #114
Blackmonba6Gen
BLUPRINT_1LE
Went to the half mile the other day to test my setup. Learned how to slip the clutch a bit and came out with a good trap speed at 150.9 in 4th gear. I had a little bit of spinning going from 1-2 but it is what it is. I wonder what other ppl run with similar setups? Is this the fastest camaro ss 1le heads cam on stock compression?! I guess so, no data no proof
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 11-09-2024, 10:37 PM   #115
BSV-CamaroSS
US Army Retired
BSV-CamaroSS's Avatar
Drives: 2002 WS6, 2023 2SS 1LE
So when you replaced your hood, trunk and put in an anti-gravity battery you only dropped 60lbs? For some reason I thought it would be more than that. No disrespect because I know ever ounce counts.
2002 WS6 #3392 SOM, 820 hp, 644 tq. "Phoenix"
2023 2SS 1LE Shadow Gray Metallic A10, ACS side skirts, rock guards, Diode side markers, Roto-Fab, GM Performance black STB. Stock dyno 384 hp, 397 tq, with RF, BTR 220, Headers mid pipes, Corsa NPP, E85 466hp, 458tq "Night Stalker"
BSV-CamaroSS is offline   Reply With Quote
Old 11-13-2024, 06:22 AM   #116
Blackmonba6Gen
BLUPRINT_1LE
The hood is pretty much a hog wash, it probably saved about 2-5lbs max, it’s more for heat extraction. The majority came from the trunk and battery. Overall it’ll definitely make a difference vs your competitors depending on what you’re doing.
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 11-13-2024, 06:26 AM   #117
Blackmonba6Gen
BLUPRINT_1LE
Finally got around to installing my BMR parts I got a long time ago! I guess it was worth the wait since I did everything myself. Time for an alignment now and see how planted it really is. I may do the toe rods and endlinks but we’ll see how it goes
Upper/Lower Trailing Arms ☑️
Control Arms☑️
Rear Cradle Lockout☑️
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 11-13-2024, 01:32 PM   #118
tortilla-flats
tortilla-flats's Avatar
Drives: 2023 Camaro 2SS
Ah your a member. I'm new to the Camaro community and have been watching your YT channel. Good stuff!
tortilla-flats is offline   Reply With Quote
Old 11-13-2024, 03:32 PM   #119
Blackmonba6Gen
BLUPRINT_1LE
yessir! Welcome to the community! This is a great place to be and lots of good information here and knowledgable people here. Thanks for checking out my channel I appreciated. If you got any questions or need anything let me know!
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 11-18-2024, 08:20 AM   #120
Blackmonba6Gen
BLUPRINT_1LE
I made the best decision and mod I think anybody could add if you own a manual camaro and that is upgrading the shift knob. I decided to get a weighted shift knob from Raceseng. They shift knobs are known of high quality and tend to be expensive but they are going out of business is have some great deals on their products. I recently purchased one and its a game changer! I surprised I didnt do this sooner. I added the extender to mine and it drastically improved my shifting experience. Go check out their site while you can and get some stuff. It will be shut down for good 12/31.
https://raceseng.com/collections/camaro-2016-2022
Shift Knob Shown: The Slammer
Weight: 1.4lbs
Extender: 1.8in
They have another called Ashiko and it's 1.6lbs so you have a few to choose from.
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 12-04-2025, 02:19 PM   #121
Blackmonba6Gen
BLUPRINT_1LE
I don’t know how this got in my garage but RaceTech x 1LE collaboration is always welcomed. These seats are wayyyy more comfortable than the RECAROs! The upper bolstering really helped out for broad shoulders like I have. The RECAROs are great for daily and will hug you in but this is like a lazyboy ��
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 12-04-2025, 03:43 PM   #122
tortilla-flats
:O
Camaro SS - (almost) FBO/E85: Tuned by Snackbar Tuning/21st Century Muscle Cars
Old 07-02-2026, 06:40 PM   #123
tortilla-flats
@Blackmonba6Gen
I'm researching a head/cam package and if I go this direction, I'll probably go the Torquer cam route with the Katech heads.
Question: what are you running for rocker arms? Factory stock? Bushing upgrade? ARP rocker bolts?
