#113 | |
Ha! Couldn’t resist!It wouldn’t make any difference. The negative stud is just a convenient place to make the body connection. There is nothing mysterious or magical about adding an additional ground cable. It’s purpose is to make sure the negative side of the electric circuit between the battery and everything that needs its power is complete and has the lowest resistance possible. My car is charging like it always did. On short trips the voltage readings are often in the 14v range and as I drive further it drops in the 12v range as the alternator has finished its job and brought the battery to full charge.
#114 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Well, my Camaro is sitting in a Whataburger parking lot due to hot start issues. I'm going to jump it after work if it doesn't crank. The cable will be ordered shortly.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#115 |
![]() Drives: 2018 camaro 2 ss Join Date: Feb 2018
I found that if you hooked it up as SSDan suggests, 21inches long works great. Thanks SSDan for all your posts on this subject. It seemed to help out a lot of people.
#116 |
Did you have to modify the cable any? Looks like a bit is snipped off there. Would the regular bolt work also?
'16 Camaro 1SS
#117 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2017
Yes you do. Cut the tip of to make a "U".
#118 |
Even on the water pump bolt? That seems a bit easier as I don't have the tools available to notch the cable.
'16 Camaro 1SS
#119 | ||
Good luck and I hope you get your car back from Whataburger.
#120 |
![]() Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
Can someone forward this thread to GM? LOL
#121 | |
![]() Drives: 2016 2SS Convertible Join Date: Dec 2019
The water pump bolt is installed from the rear. It goes through what appears to be a black plastic flange, then threads into the water pump housing, i.e., there are threads in the WP housing that the bolt tightens onto. The end of the bolt is flush with the front side of the WP housing, and you can see it easily on the upper part of the housing. To use this location, you must remove the bolt from the backside (easy access, looks to be a 10mm hex head). Then go buy the same thread-size bolt, but at least 1/2"-3/4" longer. Install the new bolt in the housing from the backside and tighten. The bolt then serves its original purpose, before the new cable is installed. The longer threads only serve as a "post" to install the cable. You can then place a washer over the "post" (exposed threads), then the cable, then another washer, then a lock-washer & nut. I haven't done it yet, but that's what I saw when I looked at mine a few days ago. I need to go back with tools and remove the bolt and buy a longer one.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
#122 |
...building an all-electric fleet by 2025 yet leaving it to us DIY garage chimps to figure out a missing ground
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 01-14-2021 at 12:41 AM. |
#123 |
![]() ![]() Drives: 2021 2SS 1LE Join Date: Aug 2020
Thanks so much to those who have spearheaded this solution.
@fxdxron1 or anyone else who has used the water pump mounting position: Does anyone know the bolt size, thread pitch, and length that is needed for the new bolt to replace the OEM shorter one? |
#124 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I got the hardware at Auto Zone. The bolt is an M6-1.0x40 mm Hex Flange Bolt. The nuts are M6-1.0 Hex Flange Nuts. I got 1/4" (M6) 6.35 mm washers. I didn't put a washer between the cable and the water pump. I cleaned off the metal surface and the flange on the cable with some emery paper, then used a washer and two nuts to secure it. Very pleased with the results so far, four days.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers, Mamo Throttle Body Delivered: 08/15/2016 #TeamBeckyD |
#125 |
![]() Drives: 2016 Camaro SS Join Date: Jan 2019
^^^^Very helpful GroundhogSS!
You the man Dan. Attached mine the other day, no issues so far.
2016 Gloss Black Camaro 1SS, A8, MRC, 6-Piston BBK
Whipple, LT4 fueling, AlkyControl, Kooks, Borla, Roto Fab, Mightymouse, aFe, Apex, C7 Carbon, etc... |
#126 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Was something changed on the 2017 and later models? Mine does not exhibit this issue ever. I have a 2017 SS.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
