Old 08-12-2020, 10:44 AM   #113
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
What cam in the COPO?
Depends which COPO.
TECH SPECS:
Displacement: 427 cu in (7.0L)
Compression Ratio: 13.5:1
Cylinder Block: LSX iron
Bore x Stroke (in): 4.125 x 4.000
Crankshaft: Forged steel
Connecting Rods: Forged steel
Pistons: Forged dome
Cylinder Heads: LSX-LS7 aluminum six-bolt
Induction: Natural
Intake Manifold: Holley Hi-Ram
Camshaft Type: Hydraulic roller
Camshaft Lift (int./exh.): .630/.630-inch
Camshaft Duration (int./exh.): 233/276 deg. @ .050-inch
https://www.gmperformancemotor.com/category/COPOE.html
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 08-12-2020, 11:09 AM   #114
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
Wanted to update with my cam specs.
LT1-LT4 SMOOTH IDLE BLOWER CAM, 218/226. .635/.635, 116 LSA 110 +32% FUEL LOBE
Also, it sounds like JRE is going to hook me up with the Johnson lifters. So, that's encouraging.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
Darth Martel is offline   Reply With Quote
Old 08-12-2020, 12:03 PM   #115
oldman
Drives: SS 6 speed of course
so the lobe will need to be shimmed in, lots of right ups on that.
Old 08-12-2020, 01:25 PM   #116
L78toLT1
L78toLT1's Avatar
You'll like that cam. I've been running it, with ls7 lifters, for the past 18 months or so. It pulls hard deep into the 6000's. I usually shift at 68 - 6900. It's very stealthy too, idles almost like stock.
Ted has done nearly every cam/Pump combination and the shim he tells you to use will likely be spot on. I checked mine just to be sure, and Ted's recommendation was perfect.
Baby Blue
Old 08-12-2020, 07:32 PM   #117
Darth Martel
Darth Martel
The shim should already be in. Guess I just need to check and make sure.
Old 08-13-2020, 06:45 AM   #118
L78toLT1
L78toLT1's Avatar
Given that your motor has already been running, albeit with a collapsed lifter, your pump is probably shimmed correctly.
Baby Blue
Old 08-13-2020, 07:52 AM   #119
oldman
You can look at the shim, if there are no grind marks on it, I HIGHLY doubt it was done.
Old 08-13-2020, 11:06 AM   #120
Darth Martel
Darth Martel
I contacted my installer and the shim was included in the kit and he installed it. I should be good.
Old 08-13-2020, 11:26 AM   #121
oldman
The shim needs to be ground down, you can't just put it on. No grinds = BAD
Old 08-13-2020, 12:02 PM   #122
BlueinTN
Drives: gas powered
The lifters I was supplied were TopLine 345A 2281S
Or as I call them... GARBAGE
if google tells me right those want a tight lash because of the S designation?
..and made in America with American steel they cant be that bad.
Texas speed makes/grinds there own cams and has a spin tron thats like 2 millions dollars worth of equipment right there. I would still call them and ask some questions. They must know something or they blew alotta money for nothing.
2018 ZL1 ZLE
Oldblueaccord <<< MY YOUTUBE PAGE!
BlueinTN is offline   Reply With Quote
Old 08-13-2020, 02:25 PM   #123
Darth Martel
Darth Martel
It's quite possible the Top Line lifters weren't the true source ofbthe problem. The problem is that Texas Speed provided them.as a substitute to JRE in place of the standard LS7 lifters provided in the kit that were never tested and verified. If those Top Line lifters have a tight tolerance, they should never be used as a substitute for lifters that have loose tolerance requirements. Namely, because the preload will be different, thus the pushrods supplied won't work. Therefore, the kit JRE provided, was going to fail regardless, simply because they had a different lifter than what they normally provide.
The more I'm thinking about this, the more pissed I'm getting.
Old 08-13-2020, 03:21 PM   #124
6spdhyperblue
Drives: 2SS 1LE
Did you see what preload they were installed at vs the manufacturer spec?
Old 08-13-2020, 04:01 PM   #125
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Top line Hy-lift are the same thing as the Hy-lift Johnson I mentioned earlier. They are made in Muskegon, Michigan. From what I see the call for .030 preload (2148se)depending on which version you received. IF you have the actual part number I could find more info.
Old 08-13-2020, 04:03 PM   #126
Darth Martel
Darth Martel
No, I have no idea. Whatever the pushrods that came with the kit is what was used. And I don't know what length those were.
