Old 06-03-2020, 08:14 AM   #113
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
I didn't see this shared but may have missed it.
https://www.gmdexos.com/brands/dexos2/index.html
The four 0W40 Dexos2 licensed oils:
Castrol Edge Castrol Ltd. dexos2™ 0W-40 GB2C1214082 Global
Mobil 1 ESP ExxonMobil Oil Corp. dexos2™ 0W-40 GB1A0917015 Global
Mobil 1 ESP Formula ExxonMobil Oil Corp. dexos2™ 0W-40 D20679HJ015 Global
Mobil 1 ESP x3 ExxonMobil Oil Corp. dexos2™ 0W-40 D20682HJ015 Global
Dexos 2 covers both gas and diesel engines. The spec originally came about for European diesels for controlling ash load on the DPFs. Dexos2 oils then started to apply to European gas engines for emissions and gas DPFs in Europe (yes, some gas engines have particulate filters). Dexos2's first US appearance was the 2014 Cruze Diesel, and then made its way for the 2.8 Duramax in the Colorado/Canyon. Dexos2 oils contain typically 0.8% sulfated ash or less which is crucial to the life of emissions equipment.
GM using this in the performance 6.2 engines allows for street and track use without the need (unless noted like ZLE) for a higher ash content oil that if used frequently can lead to emissions component failure (cats, GDPF, DPF, etc.).
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
Originally Posted by fbodfather View Post
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 06-03-2020, 07:54 PM   #114
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
Originally Posted by iPODFAN11 View Post
No problems with that number in the states. 19370233 Does not supersede to anything else and is still a valid and current # in GM's system.
Went to GM parts on-line and this is what was found:
GM Part No.: 19370233
OIL,ENG ESP FORMULA 0W40 MOBIL1 1QTX6
Part Description OIL,ENG ESP FORMULA 0W40 MOBIL1 1QTX6
Manufacturer GM. This genuine GM part is guaranteed by GM's factory warranty.
Manufacturer's Notes
This part is discontinued. It is no longer available for purchase.
george is offline   Reply With Quote
Old 06-04-2020, 12:21 AM   #115
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Interesting because the Mercedes webpage lists Castrol Edge as low SPAsh
https://bevo.mercedes-benz.com/bevol..._en.html#close
Also https://www.bobistheoilguy.com/forum...0W40__qualify_
https://msdspds.castrol.com/bpglis/F...PXE-A2A2UV.pdf
ZX-10R is offline   Reply With Quote
Old 06-05-2020, 12:34 PM   #116
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
After seeing this thread I ordered enough for an oil change (from the link in post #2). It shipped and arrived right away and I have the oil change completed. Thanks for the info.
CW3SF is offline   Reply With Quote
Old 06-05-2020, 01:18 PM   #117
PROMETHEUS
PROMETHEUS's Avatar
If the oil isn't available through GM, there are other sources out there that sell it cheaper anyway. Don't stress over GM not having it!
Old 06-05-2020, 01:19 PM   #118
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I use Valvoline 5W30 full synthetic dexos 2 in my 2017 ZL1 and also in my 2005 Silverado truck with the 4.8 liter V8. It ain’t rocket science you know.��
Old 06-05-2020, 01:24 PM   #119
Redlinez
Shifts under load
Redlinez's Avatar
^ I've been running that for a while. I plan to try the Pennzoil Euro L platinum syn next as quite a few people on the net swear by it.
22 Suzuki GSX-S 1000GT blue
Old 06-05-2020, 10:54 PM   #120
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
I think a lot of the reason for Dexos 2 is LSPI (low speed pre-ignition) protection, particularly an issue with Direct Injection Forced Induction motors like the LT4. From here:
https://myemail.constantcontact.com/...id=iD8Bl4jX1H8
Modern gasoline direct injected (GDI) engines are prone to damage from LSPI, so oil standards like API SN+ and GM Dexos2 have been introduced to provide protection from detonation at low speeds and high loads. LSPI occurs when engine oil infiltrates the combustion chamber and combusts before the ignition event. Changes include reduction of calcium detergents and elimination of sodium detergents, as well as increased Moly and other friction modifiers. Likewise, modern low-SAPS oils are designed with reduced anti-wear additives, like ZDDP, which can shorten catalyst life, or plug after treatment particulate filters. It is interesting that this new standard and the corresponding Mobil 1 C40 specification oil provides protection for these particulate filters, as it has been determined that gasoline direction injection engine or gasoline compression engines produce particulate matter in their exhaust, soot, like diesel engines, which poses a potential environmental issue. Remember, diesel engines have been legislated away and become less common due to the soot particulate matter they produce, so particulate filters have been added to many engines, and they are coming to gasoline engines now including some Porsche models.
SFV1LE is offline   Reply With Quote
Old 06-06-2020, 12:45 AM   #121
ZX-10R
ZX-10R's Avatar
Again, no engine oil additive is going to do jack for pre-ignition, which is related to quality of fuel, compression, boost, tuning, and, as that article indicates, oil (blowby) in the combustion chamber. The only fix for the latter is installing a catch can
Old 06-06-2020, 01:59 PM   #122
SFV1LE
According to the Mobil 1 engineers and chemists, LSPI which is different than standard PI/knock/detonation, occurs at low speed conditions under high load with DI engines, and LSPI is pre-ignition of the blow-by oil vapor itself and not the fuel, so higher octane fuel doesn't fix it. It's the chemistry of this Dexos 2 oil vapor (like the high octane chemistry of race gas), that resists ignition under high pressure, making it more effective for LSPI than standard oils.
It may not be the only cure for LSPI, but according to their data it helps prevent this engine damaging phenomenon. The more help the better IMO.
Old 06-08-2020, 01:36 PM   #123
iPODFAN11
iPODFAN11's Avatar
Their information is incorrect, as is a good bit of GM online part sellers can be.
Could that particular seller be out of stock? Could be. But the # is a valid and non-discontinued # in GM's system, and the GM authorized oil suppliers that provide a hefty list of quart/gallon/drum/bulk oils have stock as well.
Old 06-08-2020, 03:41 PM   #124
Redlinez
Shifts under load
Redlinez's Avatar
The GM part number for 0-40 ESP is #19353135. I called a local dealer and got pricing recently. Tasca has it as well.
Old 06-09-2020, 02:07 PM   #125
george
ZL1 Driver
george's Avatar
Went to the on-line GM parts store and they all said this:
GM Part No.: 19353135
OIL,ENG MOBIL1 ESP 0W-40 DEXOS 2 1LT
Part Description OIL,ENG MOBIL1 ESP 0W-40 DEXOS 2 1LT
Old 06-09-2020, 05:46 PM   #126
Redlinez
Shifts under load
Redlinez's Avatar
You may just need to call a few dealers. I found one locally who had plenty.
