Old 06-05-2023, 11:25 PM   #113
S.Macias
Only6Cylinders
S.Macias's Avatar
Drives: 2016 Camaro V6 1LT
Anyone else have a 4" binder full of all your upgrades, repairs, fluid changes over the years??
Instagram: @smaciasracing
S.Macias is offline   Reply With Quote
Old 06-06-2023, 02:49 PM   #114
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
I do not! But I had a bunch of loose papers in a plastic bin, for my 1994 Camaro. Everything I have now for my 2020 Camaro is in a Gmail folder.
My Camaro Journal
DamonZ28 is online now   Reply With Quote
Old 06-26-2023, 07:22 PM   #115
S.Macias
Only6Cylinders
S.Macias's Avatar
Installed BMR's driveshaft tunnel brace. Roughly a few ounces heavier than stock. Whole lot of red under the car now.
Old 06-27-2023, 10:26 AM   #116
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
4 piston Brembos, braided steel lines, Motul 5.1 fluid.... All I can say is wow.
And for those interested in doing the same on your 2.0/3.6, all you need is the brembo calipers (caliper bolts are the same as the single piston stock calipers), a set of the 13.6" rotors, and likely new SS brake lines or a set of the stainless steel lines (I ordered mine for $75 from ZZP). Overall cost was a little under $700 including the Motul brake fluid and install with flush
i went from 4 piston stock ss kit to 6 piston zzp kit and i felt the same way haha
Old 06-27-2023, 12:41 PM   #117
S.Macias
Only6Cylinders
S.Macias's Avatar
Ran with the Vapor Trail Vettes in Santa MariaName:  IMG_20230624_132801.jpg
Old 07-11-2023, 11:46 AM   #118
S.Macias
Only6Cylinders
S.Macias's Avatar
Ran some good numbers out at Salinas last Sunday (7/9/23)
Old 09-07-2023, 10:23 PM   #119
S.Macias
Only6Cylinders
S.Macias's Avatar
Steering wheel came in. Easy install. Maybe an hour max.
Old 09-11-2023, 02:57 PM   #120
S.Macias
Only6Cylinders
S.Macias's Avatar
Had some fun in Salinas this weekend running with the Loma Prieta Region Porsche Club.
Old 09-25-2023, 11:44 PM   #121
S.Macias
Only6Cylinders
S.Macias's Avatar
Installed diffuser lights. Matches the side marker lights.
Old 10-08-2023, 07:15 AM   #122
Mid_Life_Crisis
Mid_Life_Crisis's Avatar
Drives: 2023 Chevy Camaro 2LT V6 6MT
Your Camaro in bananas. Love the work you’ve done and thanks for documenting!
2023 Camaro 2LT V6 6MT Vivid Orange Metallic
Mid_Life_Crisis is offline   Reply With Quote
Old 10-29-2023, 11:23 PM   #123
S.Macias
Only6Cylinders
S.Macias's Avatar
Had some fun today
Old 11-12-2023, 03:32 PM   #124
S.Macias
Only6Cylinders
S.Macias's Avatar
Had a fuel injector malfunction. Went ahead and replaced. While at it I replaced the o-rings on the other five injectors, cleaned them with cleaner, and replaced the sparks plugs. Did the oil change this morning.
Old 01-18-2024, 10:30 AM   #125
S.Macias
Only6Cylinders
S.Macias's Avatar
Been conflicted about this. Wanted to install recaro seats with planted brackets, harness bar and 4 point schrotch belts. However, after spending hours searching on the forum and other places I couldn't find a good solution to fix the air bag light. Plus I still wanted the safety of the seat airbags since the car is daily driven with 500 miles being put on every week. I saw another forum member install all black vinyl seat covers so I decided to make the transition as well from the fading cloth. So glad I did. Easy install and matches the car interior and exterior so much better.
More BMR suspension pieces coming soon.
Old 01-18-2024, 01:22 PM   #126
Looks great, much better than cloth. You have almost zero side bolstering on the seatback and the seat itself, though... tradeoffs, tradeoffs everywhere.
