Old 06-27-2023, 06:23 PM   #113
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
Originally Posted by Boost Creep View Post
I had been running the Valvoline MST 5W40 up until it was discontinued. Searched for a replacement Dexos 5w40 and could only find Amalie, nothing else was available. Havoline was supposedly making a 5w40 Dexos, but could never find it.
Now the Amalie is no longer around, ended up getting two 5qt jugs of Mobil 1 5w40 European formula... not Dexos certified.
Don't want to run a 0w oil in my car, nor do I want to run a 5w30 in the summer.
Car doesn't burn any oil so I doubt it will kill the cats any time soon.
i run torco sr1 5w40 in my car no issues not dexos approved but i dont have warranty anymore so who cares...
Old 06-27-2023, 09:41 PM   #114
TrackClub
TrackClub's Avatar
Well, if ya no longer have warranty you should REALLY care....just sayin lol 😀
Old 06-29-2023, 02:28 PM   #115
Suzanna509
Suzanna509's Avatar
Drives: 2023 2SS Redline
Any opinions on Motul 5W-40
I am about to have the 1500 miles service done including the oil change in the differential. The engine oil my shop is using is the Motul 5W-40. Any experience with this oil? I am mainly using my SS for street, no track yet.
Suzanna509 is offline   Reply With Quote
Old 06-29-2023, 06:54 PM   #116
TrackClub
TrackClub's Avatar
Yep. Check my post #112. Cheers!
Old 07-07-2023, 02:36 AM   #117
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
my 2023 manual says DEXOS R
WHICH ONLY COMES IN MOBILE 1 SUPERCAR
https://www.gmdexos.com/index.html
The LT1 and LT4 engines are factory filled
with 0W-40 dexosR oil. 0W-40 dexosR
engine oil is approved for both track and
street use with the LT1 and LT4 engines.
15W-50 full synthetic engine oil may also be
used for track use, but after track use must
be changed back to 0W-40 dexosR for street
use. See Capacities and Specifications 0 37.
IMCWORTH is offline   Reply With Quote
Old 07-07-2023, 10:00 AM   #118
ember1205
Hot Camaro
ember1205's Avatar
dexosR is "recommended". 5W-30 dexos1 is still fine for street use in at least the LT1 motor. They really are working hard to make this super confusing.
Old 07-07-2023, 02:44 PM   #119
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
The list is outdated with oils no longer produced, and includes many oils not available in this hemisphere.
'18 1SS 1LE Black, PDR
Old 07-07-2023, 05:22 PM   #120
ArmedTrashPanda
ArmedTrashPanda's Avatar
Drives: 2018 Chevy Camaro ZL1 1LE “ZLR”
What are you guys running for your higher HP modded cars? I was getting aerating issues with the recommended oil so switched to a more viscous PennGrade SAE50 race oil.
2018 Camaro ZL1 1LE "ZLR" 1500 whp built by Prospeed Autosports | LME 416 Dry Sump Long Block LT4 8500 RPM | LME Intake Manifold | Prospeed Custom 1500 Precision Twin Turbo 6466 Gen 2 | RTS RXD 6 spd Billet Seq Gearbox | RPS Triple Carbon Clutch w/ Tilton Slave | ARH catless exhaust | DSS 9” Rear Kit | Carlyle 15” Conv | MoTeC M180 ECU w/ Air Paddle Shift | Avio Race Steering Wheel | MoTeC C1212 Dash | RPM 6-pt Roll Bar | Belak Beadlocks | M/T 275/60R15 Street Rs | DSC Tractive Coilvers w/ Cntrl | BMR Chassis | Cobra CF Seats | Rear Seat Delete | Anderson Comp CF | APR CF Wing & Rear Diffuser
ArmedTrashPanda is offline   Reply With Quote
Old 07-18-2023, 11:55 AM   #121
JSH
JSH's Avatar
Drives: '20 ZLE
Mobil 1 Supercar Full Synthetic Motor Oil, 0W-40, Dexos R. And where are we with recommended filter? I'm using a Mobil 1 filter #M1-113 now.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 07-18-2023, 03:40 PM   #122
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I run Amsoil 0-40 but I also don’t track my car yet. Our local new track just opened and waiting for more public run days once all the millionaires finish paying for all their privileges and they realize they need the Lehman to support the track
Old 10-02-2023, 03:26 PM   #123
havelegs
havelegs's Avatar
Drives: 24 LT1 M
So is supercar 0-40 the new oil we are supposed to use, for those of us with warranties?
havelegs is offline   Reply With Quote
Old 10-02-2023, 03:57 PM   #124
CTRifecta
CTRifecta's Avatar
Drives: 2SS 1LE
Correct
2024 2SS 1LE | 6MT | Riverside Blue
1100 - Order submitted - 7/12/23
2000 - Order accepted - 8/22/23
Vehicle Built (per chevy chat bot) - 10/10/23
Window sticker available online - 11/4/23
Arrived at dealership - 11/10/23
CTRifecta is offline   Reply With Quote
Old 10-02-2023, 03:58 PM   #125
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/86 IROC-Z
If you don't take your car to the track, you can use 5w-30.
Old 10-02-2023, 07:50 PM   #126
havelegs
havelegs's Avatar
Drives: 24 LT1 M
Originally Posted by CTRifecta View Post
Correct
OK thanks. BTW, Advanced Auto has the oil on sale for $7.43 per quart.
https://shop.advanceautoparts.com/p/...hTerm=supercar
Ordered 11, one extra for good measure
