#113 | |
![]() ![]() Drives: ISO ss 1le Join Date: May 2018
Motorsporttech makes the spacers custom for 35 a piece. Very nice work too. |
#114 |
Link to what i used
https://www.motorsport-tech.com/4DCGI/wheel_spacers Also, when ordering open (or any lug nuts) for that matter, make sure the hex size is 19mm, anything larger and you will mar the lug nut pocket on the apex wheels, as they are much smaller than the stock lug pockets. |
#115 | |
![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS 1LE Join Date: Feb 2017
The custom spacers you mention were my first choice (and best) for the fronts but decided on the rings since I need them for the rear anyway. I may wind up getting the custom ones especially if the rings get stuck. Apex recommended the Gorilla closed end lugs which are .75 hex = 19.05mm I also will be using a LISLE STUD INSTALLER #22800 https://www.amazon.com/Lisle-22800-W.../dp/B000ETUD22 |
#116 | |
![]() Drives: 2018 2SS 1LE in Nightfall Gray Join Date: Jul 2018
Love that you put everything needed in one post, but it did bring up a question for me. Did you consider going with the camaro specific version of these wheels, just with the 35 offset? https://www.apexraceparts.com/shop-b...aro-wheel.html You would still need the spacers and longer studs, but you would not have to worry with the hub rings. just a thought. JD |
#117 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE Join Date: Mar 2016
IG: @NC_M1SS1LE
#118 | |
#119 |
![]() ![]() Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
Sm10 19 x10.5 22et
2017 1LE Hyper Blue
#120 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Just to confirm: do closed Gorilla lug nuts work with BOTH Apex 22s AND stock rims with longer studs? Can somebody pls confirm please? Or are the open ones the way to go? Thank you!
#121 |
![]() ![]() Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
I’ve only used open ended lugs with both Apex and OEM wheels. I have ARP studs and I’m not sure close ended style like stock would work with extended studs (especially with OEM wheels and no spacer.)
#122 |
#123 |
MSI makes a great set of extended studs and open lugs..
2017 1LE Hyper Blue
#124 |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
Cut the bullet nose off the ARP’s
#125 |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
Hi All,
If anyone is in need of extended stud and lug kits, we have them in stock. 28mm longer than factory studs and 19mm lug nuts for plenty of socket-to-wheel clearance. https://store.jdpmotorsports.com/col...kit-jdp-ch1001 Kind regards, Stephen Komlos JDP Motorsports 801-545-4215 |
#126 | |
