#113 |
![]() Drives: 2018 1SS 1LE Join Date: Dec 2012
Is there any poke with the 19x10 et 20 front(non zl1 fenders) and 19x11 et35 rear ? Would love to see some shots. In for the group buy!!!!
#114 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
The front wheel width/offset is identical to the stock SS 1LE front wheel. The rear wheel would sit 8mm further outward than an SS 1LE rear wheel (since it has a 35mm offset vs. stock 1LE offset of 43mm).
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#115 |
![]() Drives: 2016 Camaro SS Join Date: Jan 2019
I don't have a before pic, but this is after a -1.20 degree front camber alignment for the 19x10 et20 on a 285/35/19 tire, which is between the stock and GM track spec alignment (-0.75 and -1.50 respectively if I remember correctly). At stock alignment they noticeably poked at the top. My car has MRC and I'm lowered about 7/8" in front and I haven't had any clearance issues.
2016 Gloss Black Camaro 1SS, A8, MRC, 6-Piston BBK
Whipple, LT4 fueling, AlkyControl, Kooks, Borla, Roto Fab, Mightymouse, aFe, Apex, C7 Carbon, etc... |
#116 |
![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS 1LE Join Date: Feb 2017
Loving my 19x10.5 ARC-8 true square track setup using 305 tires
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87 |
#117 |
![]() Drives: 2017 HBM Camaro SS 1LE Camaro Join Date: May 2013
carguy55 - Great pic...car looks good! Is your car lowered at all? You running the SC3 tires?
#118 |
Not lowered, that just how far the 10.5 ET22 push out, plus 5mm spacer in front.. Running SC3R currently but may be changing to the SC3 just to see what I can do after experiencing the 3R crack.
#119 |
![]() ![]() Drives: Camaro Z28 Join Date: Jan 2017
We got some amazing pictures of Chris's ZL1 1LE on a set of our new soon to be available 19" Camaro fitment SM-10 wheels in Anthracite finish!
APEX Fitment Specs: Front: 19x11" ET11 APEX SM-10 with 305/35-19 tires Rear: 19x12" ET41 APEX SM-10 with 325/35-19 tires Tires: Goodyear Supercar 3R Suspension: Stock -Ian
JJ - Fitment Specialist /// Forged Wheels /// Wheels For Your Camaro
Camaro Wheel & Tire Fitment Guides /// Defining Real Performance /// Camaro Wheel Gallery expert@apexwheels.com |
#120 | |
![]() Drives: 2017 SS 1LE Join Date: Jun 2017
#121 |
Our customer David sent in some awesome photos from his track day at Laguna Seca. His 5th gen Camaro was looking good on a set of 19" APEX ARC-8s in Satin Black.
APEX Wheel Fitment Specs:
#122 |
![]() Drives: 2020 ZL1 1LE, 2020 M2 Competition, Join Date: Dec 2020
Will the direct fit SM-10 be available after the new years?
#123 | |
We are aiming for Camaro Specific SM-10s to be available in March!
Front: 19x10” ET20 with 285/35-19 tires Rear: 19x11” ET43 with 305/30-19 tires
-Ian
#124 |
SM-10s really suit the lines of the 6th gen Camaro. Take a look at Stephen's 2018 Camaro SS 1LE on 19" SM-10 Wheels in Race Silver.
#125 |
Looks good!! I definitely like the SM-10 design better than ARC-8.
#126 | |
-Ian
