#113 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 21 Bronco Join Date: Jun 2012
I still expect Camaro to hold the performance advantage tho, but I think the auto equipped models will be closer |
#114 | |
http://www.caranddriver.com/reviews/...-t-test-review http://www.caranddriver.com/reviews/...mi-test-review As for comments about 6th gen 6 vs 8 speed, it's not exactly apples to apples but Hot Rod did a full track day with both(M6 vs A8) using the same drivers. The split in times was around 2 tenths as well. http://www.hotrod.com/articles/drag-...ith-jeff-lutz/ All said in done, the A10 coupled with an aggressive final ratio should be good for 3 tenths imo. I doubt the 10 vs 8 makes any real difference but that gearing (final ratio) is going to help make up the TQ deficiency from a dig.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#115 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
The challenger gained 15 hp along with the a8.
#116 |
The 392s did, not the 5.7. That's why i used RT numbers and the Charger (since it only comes with the auto). Can't find any auto numbers before and after with the Challenger from same reviewer.
#117 |
#118 | |
Drives: Mustang GT Join Date: Aug 2017
10spd and 8spds are new generation stuff, faster shifting, better torque converters for launching. 6R80 factory torque converter is poo. |
#119 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 F150 Join Date: May 2014
The 5 speed auto in the LX cars is worse/slower than the 6 speed in Mustang.
#120 | |
5th gen Camaro in automatic did not have the same amount of power as the manual so your comparison there is moot. |
#121 | |
Dude, Im talking about 8spd auto camaro vs the 6spd auto in the mustang. No one is saying 6gen camaro has a 6spd auto.
#122 | |
Both Auto Camaro and Auto Mustang run quicker than their manual counterparts. What's the spread for each? Camaro very well could be 2 tenths quicker with 8 speed than 6 speed out of 5th gen or 6 speed out of Mustang, but there is no data to prove that. What did the 10 speed F150 pick up by switching from 6 speed? |
#123 |
2015 6 speed vs 2017 10 speed. 2017 they tested weighs less and it has more power.
There is a larger difference between 0-100 between them, but I don't have the information to know why that increased difference is there. |
#124 | |
#125 | |
Also true |
#126 | |
![]() ![]() Drives: 2017 2SS M6 Join Date: Apr 2017
Regardless no one but a GM or Ford engineer can verify how much of an advantage the new transmission will be for the Mustang. Around a track I can see it being huge but on the strip... maybe only a tenth |
