#113 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Ebay had just sent out a 15% off offer this past Wednesday and the max discount was $100. I believe with the 20% off it is also a $100 max. To get more than $100 off, you would have to purchase each ring separately (possibly with two different accounts).
"KEEP THE FAITH"-Fbodfather |
#114 |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
Rears are just fine, IMHO. On a slightly related note, folks in this thread and the 'track pad' thread have mentioned how good the brake bias is. That has been my experience, as well. I lipped the front and rear rotors at the same rate. I run the same pad type F/R.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 Last edited by MatthewAMEL; 11-27-2018 at 01:02 AM. |
#115 |
![]() ![]() ![]() ![]() Drives: 1LE Join Date: Sep 2017
Generally speaking how much lighter would the rear rotors be each if they were two piece?
#116 | |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
https://www.racingbrake.com/Two-piec...ear-p/2505.htm |
#117 |
Finally got the time to get mine on today...
Thanks to KNS Brakes for getting them out so quickly. Appreciate all the help in this thread. Install is straight-forward...just be sure you have a impact tool to break the caliper bolts loose.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#118 | |
#119 |
3.9 lbs per rear isnt bad plus lost weight for my wheels and tires.
Or |
#120 |
![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS 1LE Join Date: Feb 2017
What pad you going to use with them? Interested to see how long they last compared to OEM
#121 |
BigShow
Drives: 2017 1 Camaro + Chevy Avalanche Join Date: Oct 2014
I was unable to break the Caliper bolts free, I even went out and bought an electric impact wrench. They just would not budge. I guess I have to take it to a shop.
#122 | |
Whether you or the shop does them, make sure to clean out the old thread locker out of the knuckle threads with acetone or something similar. New bolts have the thread locker patch on them, or clean off the residual thread locker and reapply as per the Service Manual. |
#123 | |
![]() Drives: 2017 Camaro 1LE SS Join Date: Oct 2016
#124 |
![]() Drives: 2018 Camaro ZL1 1LE Join Date: Jun 2018
Just found a smoking deal on these rotors at thmotorsports.com
I guess they are having a tax sale right now and they are listed at $276.38 a rotor with free shipping. I ordered a set because I need new front brakes badly. |
#125 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS Join Date: Dec 2009
Looking for a complete set of clips and bobbins if anyone has a junk set of rotors.
Orange Krush II
#126 | |
![]() Drives: SS 1LE Join Date: Oct 2017
