Old 06-24-2017, 10:06 AM   #113
Canadamaster
Drives: Future zl1 1le
I would assume yes but will these work on the 18's as well? I can't see there being a change
Canadamaster is offline   Reply With Quote
Old 06-24-2017, 11:57 AM   #114
Roto-fab 1
Roto-fab 1's Avatar
Originally Posted by TDS View Post
UPDATE:
I installed mine last night and did not need to cut the clip. It is actually pretty easy to leave it in tacked and reusable. All I did was take a small flat head screw driver that fit into the clip from bottom right to to left and the twist. It spreads the clamp open just enough that you can pull the tube out. Need a decent grip but it will come out. As you can see in the pictures it did not alter the shape of the clap and you really cant tell it was screwed with. Everything else about the kit is AWESOME and will thought out. I must say it was the best packed shipping box ever.
Attachment 880691
Attachment 880692
Great input! This is what forums are all about! Thanks also for your thoughts on the intake design and packaging.
Old 06-24-2017, 12:04 PM   #115
Roto-fab 1
Roto-fab 1's Avatar
I will ask around for confirmed fitment, but I would imagine the system fits an 18.
Old 06-24-2017, 08:37 PM   #116
rtm_tinman
rtm_tinman's Avatar
Drives: 2017 camaro ZL1 Red Hot M6
I put my CAI on a couple weeks back and since I got two check engine lights. Both were for an issue with the emissions system. Any one else?
rtm_tinman is offline   Reply With Quote
Old 06-25-2017, 06:23 AM   #117
BSR-1
BSR-1's Avatar
Drives: 17 ZL1 M6 Black
Put mine on today and so far so good.
Also have a ported throttle body and no CEL yet.
BSR-1 is offline   Reply With Quote
Old 06-25-2017, 12:16 PM   #118
Roto-fab 1
Roto-fab 1's Avatar
I have not heard of any CELs caused by our CAI. Did you unhook the battery before install? Also did you leave the MAF connection plugged in and remove the MAF sensor by unscrewing the 2 MAF screws only?
Hope to get to the bottom of this.
Michael
Old 06-25-2017, 12:18 PM   #119
TheRedhead
TheRedhead's Avatar
Drives: 2018 Red Hot ZL1 1LE
Just the intake? Any exhaust work?
2018 RED HOT ZL1-1LE: Nav,PDR,Floor Mats
Built!
TheRedhead is offline   Reply With Quote
Old 06-25-2017, 12:40 PM   #120
rtm_tinman
rtm_tinman's Avatar
Michael
I did not unplug the battery. I only unscrewed it.
I'll try the unplug first. Maybe tomorrow. I'll let you know.
Old 06-25-2017, 01:56 PM   #121
jbp8653
jbp8653's Avatar
Drives: 2017 ZL1,2013 ZR1, 1952 C3100 Resto
Michael
We unplugged the MAF. Upon start up it went into limp mode. This was caused by us unplugging it. Cleared the code and all has been fine. Know better next time
2017 ZL1,Mosaic Black, auto,nav/pdr, Roto Fab,Mamo
2013 ZR1 60th Anniv.
1952 C3100 resto-rod. LS6, 4L60e, 228R cam
jbp8653 is offline   Reply With Quote
Old 06-25-2017, 02:10 PM   #122
Roto-fab 1
Roto-fab 1's Avatar
Glad things are straightened out!
Old 06-28-2017, 06:15 AM   #123
Roto-fab 1
Roto-fab 1's Avatar
We have received a few questions about the process of switching back to the stock intake after installing the Roto-fab CAI. To reinstall the OEM system, we recommend using the small hose clamp supplied in your CAI hardware kit in place of the OEM clamp that was removed during CAI installation.
The swap can be done in about 30 minutes, and will require most of the tools noted in CAI installation instructions.
If anyone has further questions, we would be glad to help! You can also refer to our CAI installation guide below for a detailed explanation of the Roto-fab install process, as well as a few benefits the system has to offer!
Roto-fab CAI installation guide, part 1
Roto-fab CAI installation guide, Part 2
Old 06-28-2017, 10:55 AM   #124
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
WOW!!
Was hoping for a 50 cent tube instead.
Now I have to buy a stock OEM intake tube if I want to use a Roto Fab, I'm betting that will be real pricey.
Putting on a hose clamp on the stock OEM system is NOT what some dealers want to see.
I not trying to be a dick but you guys can't do better than that?
Some of us have really strict dealers, some of us have cool dealers.
-Bobby
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 06-28-2017, 12:30 PM   #125
Dethsupp0rt
Drives: None
If your dealer is that strict, you should probably just stay stock if you can't find another dealer.
Again, removing the tube without destroying the clamp is possible if you take your time.
I'm impatient and even kept it intact, so I'm sure you could too with a little patience and following the procedure another person posted above.
Dethsupp0rt is offline   Reply With Quote
Old 06-28-2017, 02:08 PM   #126
soceur77
Drives: 17 NFG ZL1 17 GTR 22 RS6
someone posted how to remove the stock clamp pretty easy with just a flat head. He said it was reusable for if had to go back to stock
soceur77 is offline   Reply With Quote
