Old 05-19-2017, 10:25 PM   #113
dcxeternal
Drives: 2019 ZL1 1LE
yet yours broke at 50ftlbs.....
dcxeternal is offline   Reply With Quote
Old 05-20-2017, 01:41 AM   #114
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
I ended up putting the new one in and torqued them down to 55 lb/ft as I didn't want to take any chance before the event tomorrow. It seems like my initial guess is correct.
Since I drove the car with loose end links when I heard the clunk, it most likely weakened the upper bolt and caused that. I can try adding a bit more torque but since I also applied some blue loctite I think it should b fine now.
glamcem is offline   Reply With Quote
Old 05-22-2017, 01:25 AM   #115
glamcem
glamcem's Avatar
I attended to another club event at the ORP yesterday (2017-5-20).
Ambient temps were about 15F degrees higher this time so my best lap was 1:55.. I had understeer issues maybe because of the tire temps . Overall I am not that impressed with the Trofeo R tires probably because of the softer sidewalls or the fact that it's recommended with 30 hot psi and -3.0 camber (it was easily 37-38 psis after a few hot laps). I will see how the NT01 will do next time at the ORP
Old 05-22-2017, 11:02 PM   #116
glamcem
glamcem's Avatar
Some pictures from the latest track event at the ORP this weekend.
X25 and I swapped cars at some point and asked each other's opinion on handling of both cars. His Miata track build (NA 2.5lt built motor, ohlins race coilovers, stoptech bbks..etc) has great handling feeling very well balanced and easy to rotate especially with the sticky Z214s I wish the bigger sizes were available for our cars .
Schroth harness also did a good job keeping me in my seat so it should be fine for now
Old 05-22-2017, 11:11 PM   #117
X25
X25's Avatar
Drives: '16 C7 Z51
Pics look beautiful! To be fair, though, it was sunnier than how it looks in the pics : )
Hankook Z214s were great. This made me wonder what we could do with good tires like Hoosier R7s, etc. on our V8 cars. Looking forward to trying out R7s on the C7.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 05-23-2017, 01:39 PM   #118
glamcem
glamcem's Avatar
Just an update on my rotors and ST43 pads after the 4th event (3 full event to be exact since the first couple two were only half day)
As you can see the hairline cracks are a bit more visible but should be fine for a few more events
I measured the ST43s at ~16mm (they're 18mm when new if IIRC) as you can see there's still tons of life on them
And this is the OEM pads with only 800 miles on them (no track miles) Measured at 15.2 mm. They still look brand new in comparison:
Old 05-24-2017, 12:19 AM   #119
G Fo12ce
G Fo12ce's Avatar
Drives: '16 2SS
Originally Posted by glamcem View Post
they're very good especially if you combined with the ZL1addons lift points..it definitely looks a better built than those traditional types
[/QUOTE]
Ya I have the ZL1 Addons lift points. Exactly why I was looking at them, thanks!
My Intro Post | My Order | My Ordering Guide
TJCR2Q | 2SS Red Hot|Adrenaline Red|MX0 A8|56R Wheels|5ZU Blade Spoiler|NPP Exhaust|F55 MRC|IO6 Nav
• 4/06/16 1100 Ordered (waiting for 5ZU acceptance)
• 4/19/16 2000 Accepted with 5ZU
• 4/23/16 3000 TPW:5/16/16
• 5/06/16 3100
• 5/13/16 3400 Broadcast Sheet
• 5/24/16 3800 Vehicle Produced
• 5/25/16 4B00 Bayed
• 5/27/16 4300 Intermediate Delivery
• 7/9/16 Delivered!
G Fo12ce is offline   Reply With Quote
Old 05-24-2017, 03:14 AM   #120
glamcem
glamcem's Avatar
Sure!
Old 05-24-2017, 01:17 PM   #121
glamcem
glamcem's Avatar
Decided to run the 305/325s NT01s and compare them against to stock and Trofeo R tires before it gets really hot here in Northwest so it will be an accurate comparison
I have a scheduled event at the RMP this afternoon. Poke doesn't look as bad as I though it would so hopefully there won't be any rubbing
Here's a picture of them next to each other
Discount tire quoted me $195 for dismounting and mounting the new tires (what a joke) so I took it to my local Costco Tire service and only paid $60. Service guys were really helpful also
Old 05-25-2017, 01:16 PM   #122
glamcem
glamcem's Avatar
I could finally get some proper seat time at the Ridge yesterday. At the last event I could only do one session with the Trofeo Rs.
Yesterday, crew seemed a lot more organized and there were only a handful of people there so I had a chance to try the NT01s. They felt great and I didn't have any rubbing issues (yay). I could push it better and as a result I improved my personal best by another second (1:54s)
After the third session, however, I had a flat tire :/ Fortunately, I was able to put some air and drive it to the Les schwab and had them fix my tire. I got screwed, literally
I said to myself I shouldn't let this ruin my day especially since there is no traffic and the weather was not hot (Ambient temps at around ~63F )
I turned back and improved my best lap for another second after that!
The front tires definitely begs for more camber. As turn in was not as good as I am used to, I had to alter my driving style (more trail braking) and my lines but car felt a bit more planted at the corner exits.
Lap times were pretty consistent and as you can see 1:52s are very possible. In fact, I was doing better at the last lap until I had to drift at one corner and blew that lap. Oh well
and here's a video of my personal best lap the Ridge:
Old 06-02-2017, 04:10 PM   #123
glamcem
glamcem's Avatar
It was a busy day yesterday I took my car to Chase Race for extending the upper camber bolt hole to get more camber. Thanks Provoste for all the information
After extending the hole a little bit we would add additional .6 degree camber upfront I also asked Doug (from Chase Race) to add little bit of toe out up front to help the steering feel/response for turn in. Hopefully car will be better in at the corner entry and mid corner. I have two more events coming up (June 4th at the Ridge and June 9th at the ORP) so hopefully these will help
Front wheels look completely tucked in
This is how the front brake pads and rotors look like after 5 event (4 full event) As you can see still good amount of pad life. Hairline cracks became more apparent but they should be good for another 2-3 days at least
Old 06-02-2017, 04:21 PM   #124
glamcem
glamcem's Avatar
I also installed the Roto Fab Intake with sound tube delete. The vendor made a mistake and accidentally sent me an oiled filter but hopefully my dry filter will arrive sometime next week so that I can replace
The cabin noise is almost non existent now (well besides the noisy NT01 tires of course lol) It definitely made a difference on comfort level
Got rid of this stupid "sound enhancer" pfft
Old 06-02-2017, 06:13 PM   #125
tx6g1le
tx6g1le's Avatar
Drives: 2017 Camaro 1LE
Glam what app are you using for live lap times? Great build btw, I'm following it closely. On another note the team at Vorshlag near me in Dallas should be releasing camber plates soon.
2017 Hyper Blue 1LE
tx6g1le is offline   Reply With Quote
Old 06-03-2017, 01:00 AM   #126
glamcem
glamcem's Avatar
Thanks I use RaceChrono app for Android. I have a dedicated cell phone (an old Nexus 5) for that since it's not available to Apple iOS. I've used Harry's Lap Timer previously and it's OK but I prefer RaceChrono for it's better visibility and better data analysis tools.
I considered camber plates at some point but am a bit skeptical about using them with the MRC suspension. I had my mechanic extend the upper camber bolt to gain more camber and it should be just fine until I get the Multimatics
