#113 | |
A Heartbeat Away.........
Drives: Not As Fast As I Would Like To Join Date: Mar 2016
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. |
#114 |
When you guys installed this did you leave a little gap or did you go right to the roof of the car? I was thinking of following the mirror line but i dont want dirt or wind getting inside the gap!!
#115 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Challenger SP Shaker/Arcadia Denali Join Date: Jan 2016
Left a gap, Top of the window i stopped. If ever wanted to take it off it would be much easier with fishing line that wont go near the paint. Can't tell there is a gap personally to be honest.
#116 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
+1
Kindness and compassion #OthersFirst |
#117 |
Ok so I installed this last night. I was concerned because the 3M tape seemed kind of thin but I cleaned the window with alcohol and then I used a 3M adhesion promoter that comes in a little white pouch and wiped down the mirror then I applied the piece. It stuck like cement.
You need to use the adhesion promoter for sure. I used a heat gun after just to make sure it molds to the contour of the mirror. Works perfect. ![]() ![]()
#118 |
Looks good buddy!!! For the price you really can't go wrong at all.
#119 |
$26 for the unpainted and it came matte black and i love it.
#120 |
Really brings out the rear of the car and think it may be the least expensive hop up for the exterior.
#121 |
Blessed ❤️
Looks great guys!! An awesome mod!!!
#122 |
![]() Drives: 16' 2SS M6 Join Date: Feb 2010
Well,
I attempted to install and can verify at least for mine, the tape that came with it sucks - didn't hold. I'm going to purchase some VHB tape but upon researching, I discovered there's a bunch of different types of 3M tape options, which one would be best? Also, some are pricey, kind takes some of the value of the spoiler away, oh I did use the adhesion promoter maybe I had a bad batch of tape https://www.amazon.com/dp/B002JOVUO0..._t1_B00JR4D7AA https://www.amazon.com/3M-VHB-5952-A...BD40HC8TRRBK2K https://www.amazon.com/3M-38583-Exte...t_sims?ie=UTF8 |
#123 |
you have to wipe the glass down with alcohol then use 3m adhesion promotor on the glass or on the tape. It sticks really well after that
#124 |
![]() Drives: 2017 50th Anniversary Join Date: Dec 2015
Picked mine up about a week ago. Went with the gloss black and it looks great with the NGM on my 50th. It arrived well packaged on Weds. Set the spoiler out in the sun while I prepped the rear window. I simply used 91% rubbing alcohol to clean the upper part of the glass.
Mine came with 3 strips of 3M tape. Removed the first few inches and stuck it in place. Pulled the remaining tape off as I stuck the spoiler to the window. Fit was perfect. Left the car to sit in the sun for a about an hour before putting it back in the garage and it's stuck on there good and solid. Over the long weekend I was able to get the car out a couple of times and I'm happy to say that the spoiler has stayed in place well into the triple digit range (in Mexico of course). Checked that it was solid before putting the car away last night and all is good to go. |
#125 | |
Blessed ❤️
before the alcohol.
#126 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS M6, NPP Join Date: Apr 2016
Not sure where you guys ordered it from, mine came from a seller in Riverside CA.. it had 3 strips of 3M tape and it sticks like glue. A week passed and that thing isn't coming off anytime soon.
