Old 04-19-2017, 10:06 AM   #113
reeper
reeper's Avatar
Drives: 2010 HD D/A, 2015 Z06, 2016 2SS
In for updates. Hoping GM come up with a suspension flash for the 2016's
2016 Hyper Blue A8 2SS
GM Bodykit: Black
MRR 017 wheels: Black
OEM Blackout tail-lamps
OEM SEMA Grille
35% window tint
Black glow-tie
BMR Suspension (Pretty much everything)
ACS rear-deck spoiler
Rotofab CAI
Lolly-pop red rotors by Madison Powder Coating
reeper is offline   Reply With Quote
Old 04-26-2017, 12:08 PM   #114
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
Read this whole thread and I'm intrigued. So has anyone had a chance to measure this setup for possible drop?
Atomic Ed is offline   Reply With Quote
Old 04-26-2017, 09:17 PM   #115
glenB
Drives: Chevrolet Camaro SS
These dealers taking 3 days to install this kit are just pounding the pooch. I can see one and a half days, tops. That would be springs, bars arms, alignment and reprogram. I've done 3 installs of these parts short of the alignment and reprogram and had plenty of time in one day.
If they say they haven't done it so it may take extra time, find a new dealer. Nothing in the install is out of the ordinary. To be honest, the teach can lock in the front camber before he even takes out the strut. The rear doesn't even effect the camber. The arms aren't longer or shorter than what's on the car. When I installed my GM lowering kit I didn't do an alignment for two months and when I did I was still within GM specs.
glenB is offline   Reply With Quote
Old 05-01-2017, 04:30 PM   #116
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Any update on how much of a drop anyone got from going FE3 to FE4 springs??
Eric SS is offline   Reply With Quote
Old 05-02-2017, 02:48 PM   #117
NewCamaroOrder
Drives: 2017 Camaro 2SS Nightfall Gray 1LE
I still plan to put together a detailed diagram showing all the different points I measured before and after the suspension upgrade but I have been slammed at work and at home lately.
NET RESULT = 1/2 " lower all the way around on my 2017 2SS
NewCamaroOrder is offline   Reply With Quote
Old 05-02-2017, 02:50 PM   #118
NewCamaroOrder
I included the alignment information as it can impact overall height.
I have noticed that the plastic pieces under the front fascia lip scrape a little when backing into my driveway if I don't cut an angle when pulling in. But its not bad.
Old 05-02-2017, 03:23 PM   #119
Eric SS
#becauseracecar
Eric SS's Avatar
Thank you. Maybe I'm reading this wrong, but with the numbers you gave wouldn't the total drop be 1" and not 1/2"?
On your sheet you show the front measurement from wheel centerline to fender changed from 15.5" to 15" You also show a change from 6" to 5.5" from what I assume is a lug to the ground. That means you lost 1/2" above the hub and 1/2" below the how for a total of 1" from fender to ground. Same with the rear. 1/2" above the centerline and 1/2" below the centerline = 1" total. Am I wrong? Thanks.
Old 05-02-2017, 03:33 PM   #120
NewCamaroOrder
If you compare a before number with an after number it is only 1/2 ".
The measurements are separate not cumulative. Center line of the wheel to the fender is the 15 1/2 - 15. The 6 - 5 1/2 is the bottom of the fender to the ground.
Old 05-02-2017, 03:43 PM   #121
Eric SS
#becauseracecar
Eric SS's Avatar
I'm still not seeing it. In the rear your total height from ground to fender arch is 23.5" before the suspension (15 3/4" + 7 3/4") install and 22.5" after the install (15 1/4" + 7 1/4"). That doesn't make much since though since a suspension change only shouldn't make any difference in the wheel centerline to ground distance. What am I missing here? I agree that maybe it should be 1/2" total if you only take the wheel centerline to the fender arch but does that mean you changed wheel/tire heights as well at the same time (that would be the only way to change the wheel centerline to ground)? I just want to make sure I have all the info correct, Thanks!
Old 05-02-2017, 03:45 PM   #122
Eric SS
#becauseracecar
Eric SS's Avatar
OK that makes sense. I thought those smaller numbers were a measurement taken from a point on the wheel, not a point on the body.
Old 05-02-2017, 03:46 PM   #123
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
He said the measurements are separate. axle to fender versus ground to chassis. Adding them up gets you no useful number.
***edit. simultaneously reply.
1/2" lower, good to know. Thanks OP.
Old 05-02-2017, 03:57 PM   #124
NewCamaroOrder
Sorry for the confusion! That's why I wanted to put the measurements over an image of the car so it would have context.
My original thinking was to know the wheel gap change and the body panels to ground change. The measurements also provide numbers showing the front to rear visual rake of the car.
Old 05-02-2017, 04:15 PM   #125
Eric SS
#becauseracecar
Eric SS's Avatar
Yeah no problem, it's great info! We've been wanting the height info on the FE3 vs FE4 springs for a while and this a great confirmation.
Old 05-04-2017, 12:55 PM   #126
archer1965
archer1965's Avatar
My 16 had the 1LE suspension upgrade kit installed yesterday. The dealership is working with GM on the suspension flash today. GM engineering has a solution and imminent release of new 2016 software,which they are using on my car today.
I'll post before and after ride height measurements today or tomorrow.
2SS Nightfall Grey / Black Rally Stripes / Sunroof
NPP / MRC /1LE Suspension / Nav / M6/ Xpel'd / CAI
archer1965 is offline   Reply With Quote
