Old 04-09-2015, 04:46 PM   #113
Number 3
Hail to the King baby!
Number 3's Avatar
Anyone notice the CT6 introduction mentioned AWD with the 400 HP 3.0 TT?
Old 04-09-2015, 04:50 PM   #114
Bhobbs
Bhobbs's Avatar
Originally Posted by DenverTaco07 View Post
"The lighter structure also enabled the size and mass of elements such as the wheels, tires and brakes to be scaled accordingly."
Still not sure what this means, scaled in which direction heavier, lighter, bigger...what?
To me, it sort of says, hey, we have a much lighter chassis, we can put 20" rims on without any problem.
bigger brakes too?
or everything is lighter, wheels and brakes too?
Smaller and lighter for sure.
Old 04-09-2015, 04:53 PM   #115
BryceClark89
BryceClark89's Avatar
Drives: 01 Alero GLSV6/ 07 ZX-14/ 06GTO
Question ZL1 ish wheels for the 6th gen
I find it odd how people are complaining about the wheels on the 6th, but loved the 5th Gen ZL1's
Owned lifted 88 dakota two door short bed V6 4x4, Yellow/black LB9 powered 85 IrocZ28 MODS Edlebrock intake, throttle body spacers and mass air flow sensor, Edlebrock full exhaust, K&N drop in's, B&M 700r4 shift kit. 2001.olds alero GLSV6, BIKE~ 2007 Lazer Metallic Blue ZX-14
BryceClark89 is offline   Reply With Quote
Old 04-09-2015, 05:14 PM   #116
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
I doubt we will see 19" rims....A smaller diameter will mean less mpg....They will stay 20's for mileage if nothing else...
Old 04-09-2015, 05:17 PM   #117
ChefBorOzzy
ChefBorOzzy's Avatar
Drives: 2016 F150
Umm.. What?
ChefBorOzzy is offline   Reply With Quote
Old 04-09-2015, 05:22 PM   #118
90503
90503's Avatar
Originally Posted by ChefBorOzzy View Post
Umm.. What?
...I think I'm right....a smaller diameter tire will need more turns to go the same distance as a larger one....
I know when I put on my 19" track wheels and tires, the odometer is off by about 10%...
Old 04-09-2015, 05:24 PM   #119
ChefBorOzzy
Drives: 2016 F150
If you downsize the wheels, you should "upsize" the tires.
Old 04-09-2015, 05:28 PM   #120
90503
90503's Avatar
If that's the case, then yeah...If you keep the same diameter as a 20" rim and tire you are putting on a taller tire on a 19" rim, and not gaining that much in weight savings...
Old 04-09-2015, 05:28 PM   #121
GroundhogSS
GroundhogSS's Avatar
In addition to the extra weight of AWD, I don't want all of the development costs rolled into the price of a Camaro that we all would pay even though I suspect only a small percentage of buyers would want. Of course, I'm lucky that I live in Texas and would not see much benefit of AWD in everyday driving.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 04-09-2015, 05:31 PM   #122
Bhobbs
Bhobbs's Avatar
That doesn't mean they will get less mileage, it means they will need to change the gear ratios to match the different wheels.
Old 04-09-2015, 05:44 PM   #123
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Originally Posted by xc_SS/RS View Post
Yeah I was thinking pad surface area but I completely forgot about that. Seems like they went that route then with larger rotors. That could also increase cooling right?
I'm no brake expert but I would imagine a larger rotor would stay cooler longer than a smaller one, as well as cool better?
I do know that the ATS brembo calipers have 42mm pistons. These calipers appear to use the same size pads as the base (non-Z51) 2014 Corvette Stingray. p/n 23145627 is the pad listed for use in the ATS, CTS, XTS, and Vette.
Not sure how that compares to the current 5th gen brakes caliper/pad wise.
Old 04-09-2015, 05:48 PM   #124
AlexM
AlexM's Avatar
Drives: Used to be 2012 Camaro 2SS/RS L99
BEE used to have
MyLink with NAV
Black 10 spoke FR41 wheels (ZL1 Replica)
Roto-fab CF CAI / Scoop and Washer Bottle Relocation KIT
Vmax yellow painted ported TB
Solo HF Cats with Kooks 2.5" catback
SLP Replica Spliter, CF Stripes and CF bowties
Hawk ceramic brake pads
OEM Strut Tower Brace - Yellow Plastidip
Range device - AFM Delete
Halo/DRL Harness (Halo/DRL on day and night while driving)
Engine Cover/Air Compressor Delete
AlexM is offline   Reply With Quote
Old 04-09-2015, 06:10 PM   #125
i2disturbedSS
i2disturbedSS's Avatar
Drives: 2010 SS L99 IOM
Yeah a little fun off topic never hurts to much.
Good news also if you are getting a 6th gen, no weird weights on the brakes.
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins
i2disturbedSS is offline   Reply With Quote
Old 04-09-2015, 06:41 PM   #126
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Originally Posted by ECS C6 View Post
Cute how a new member like you is calling a Camaro owner since 1993 like me "new". LOL
I don't want to deny anyone ugly black wheels, so don't try to deny me the options of 5-star wheels or AWD. We all should be offered popular options from GM that people are willing to pay for.
Why mess up a successful design like the Camaro with AWD? Everyone has been whining about How heavy the 5th gen was and still GM sold thousands of thousands. Theres no benefit fora 3900lbs AWD Camaro over a RWD 3700 lbs Camaro with 460hp for Both. Since when the 4 bangers are catching. The Golf R is 3500lbs. Explain to me How better it is with much less HP?
An AWD car by GM wont be a Camaro. Thats it. Youd be the only one buying it. What do you drive?
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
