Old 07-14-2014, 08:49 PM   #113
crysalis_01
Iron fist, lead foot
crysalis_01's Avatar
Drives: 2003 Mustang Cobra
Originally Posted by Bhobbs View Post
If that was a boss for a DI injector, it looks like the injector would be vertical in the head.
I could be wrong. I just read a few places it wasn't what people thought.
True, if they were restricted to only machine in one direction. My assumption is that the current bosses seen in the 2011+ heads are cut the way they are to serve two roles.
1. To be a place holder for the eventual use of DI injectors.
2. Since, DI wasn't to be initially utilized they were cast to not deter a proper burn of gases pre-DI.
So yes, in their current form they would not hold a properly aligned injector, as all DI injectors go in from the "side" of the head and not the "top" as bosses of this shape would force. However, the recess cast into the combustion chamber means that much less to redesign when DI comes along. It seems that redesigning a combustion chamber would take much more effort redesigning the grooves for the injectors on the outside of the head.
crysalis_01 is offline   Reply With Quote
Old 07-14-2014, 08:58 PM   #114
Bhobbs
Bhobbs's Avatar
If it is supposed to be a placeholder for a DI injector, I don't understand the purpose of designing it in a way that would not function.
Old 07-14-2014, 09:05 PM   #115
crysalis_01
Perhaps I wasn't clear in my previous post, my fault.
Prefaced with, I'm no mechanical engineer:
Perhaps the design cast without an actual injector inhibited a proper/full burn of gases. So casting the recess needed for an injector, but retaining all the characteristics needed for a proper burn, without an injector present, necessitated the design we see there.
So now that the recess in the chamber is present, that's one major step they can skip when reworking the heads for DI. Did that make any more sense?
Old 07-14-2014, 09:27 PM   #116
Bhobbs
Bhobbs's Avatar
Oh ok. I get you now. I happen to be studying engineering but haven't taken any fluids classes yet.
Old 07-14-2014, 10:11 PM   #117
hotlap
hotlap's Avatar
I graduated in 05 with a 3.71 GPA and fluid mechanics and thermodynamics were amongst my best class. Nothing learned there would help with what was present here.
Ronald Reagan -
Old 07-14-2014, 10:14 PM   #118
Bhobbs
Bhobbs's Avatar
So you don't think the boss sticking into the combustion chamber has any impact on the swirl characteristics of the air/fuel charge?
Old 07-15-2014, 08:38 AM   #119
HEMI DAVE
HEMI DAVE's Avatar
Drives: 2016 Z06, 2015 Hellcat Challenger,
Not only that....
But I also feel the Zygotic podium reflux from the centrifugal force resulting in the vacuum, is inherent to the fluid reticular cycle.
HEMI DAVE is offline   Reply With Quote
Old 07-15-2014, 12:44 PM   #120
hotlap
hotlap's Avatar
Originally Posted by HEMI DAVE View Post
Not only that....
What he said...
Ronald Reagan -
Old 07-17-2014, 11:41 AM   #121
Cobra_Commander
Cobra_Commander's Avatar
Drives: 2011 Ford Shelby GT500
Exclamation Finally 6G Mustang HP/TQ!
They finally released the specs.... wow!
http://www.mustang6g.com/forums/show...tang-2501.html
Pretty much what I expected.
Cobra_Commander
Cobra_Commander is offline   Reply With Quote
Old 07-17-2014, 11:45 AM   #122
crysalis_01
Yep, right inline with what anyone with common sense should have been expecting.
Old 07-17-2014, 11:52 AM   #123
Bhobbs
Bhobbs's Avatar
That's what I expected. Hopefull GM doesn't nerf the LT1 too much because you know Ford isn't going to keep those numbers long.
Old 07-17-2014, 11:52 AM   #124
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
I would certainly hope that is underrated... That's very surprising to me, but I'm perfectly fine with being wrong on this one. I was hoping for more of a competitive number forcing a HP bump for the 2016 camaro.
Old 07-17-2014, 12:06 PM   #125
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
Ok, now that the HP numbers for the smaller engines are out. I'm still confused. Why do they sell both? Seems close enough in performance that you could just go ahead a offer either one? Options are great and all, I just don't know how you would choose one over the other.
Obzen is offline   Reply With Quote
Old 07-17-2014, 12:12 PM   #126
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
I would assume that since the performance numbers are soo close that the MPG's would be completely different. Or it's a testing the waters kind of thing. See if people will bite for the smaller engine.
