05-23-2019, 05:44 PM | #113 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
Keep the numbers coming.
BTW and for reference: https://www.lsxmag.com/tech-stories/...rger-on-a-zl1/ |
05-23-2019, 06:15 PM | #114 |
Dyno Show Queen LOL
I still haven't got a slot available to test the 103 vs the 112mm, at that time we will be testing spacers and Vararam's new box.
I did drop it over Sorians 1 week ago to see if we could fix the bog issue some of it is the 112mm but that's good, some of its air intake sensor messing with timing, and a good bit is the nanny bs to save the rear end and clutch. Hptunners is writing my vin into 19 software that gives some control to be able to make changes to the nannies. Out of the blue Kong contacted me about blower porting the 2650 so it was pulled 2 days ago and on it's way. I asked what he though power wise he said about fifty.. that was good enough for me seemed like a nobrainer. They did a base line just before to see what's it's making now that's 90 outside.. 868 down 30 hp. On another note.. It's faster than a zr1 on a 50 roll but after 3 races he was almost on me. So I'm going to an exchanger, trunk tank, and another exchanger inside the car where the seats fold down and puller fan on it so draw cabin air.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 05-23-2019 at 06:49 PM. |
05-23-2019, 06:26 PM | #115 |
Drives: 2018 Camaro SS Join Date: Sep 2009
Lucky you! Helluva deal
05-23-2019, 06:47 PM | #116 |
You should have taken it to the track. That's a true test.
05-23-2019, 06:51 PM | #117 |
Dyno Show Queen LOL
Yup
05-23-2019, 07:35 PM | #118 |
Taking a 6-speed car with this much power to the track doesn’t seem like a good idea to me. Especially on those tires. Wheel hop and your done. I wouldn’t trust the driveshaft, the axles, or even the clutch if it hooked. I have seen that carnage
05-23-2019, 07:58 PM | #119 |
Dyno Show Queen LOL
Maybe some day, like I've stated beating a 720s in a roll race is what I'm after and still being able to turn.. the 345s toyos in the heat have been pretty dam good way better than the Nitto 305 45 18s I had.
05-24-2019, 11:46 AM | #120 | |
Drives: 2017 ZL1 Join Date: Mar 2014
Bolt on LT5s, with a Kong ported blowers are dynoing more than 1000rwhp. You should have a very strong car when you get it back! |
06-01-2019, 07:11 AM | #121 |
Dyno Show Queen LOL
Looks like the Eforce car is in the 8s.. No need to go to the track now! It's proven!
06-01-2019, 11:38 AM | #122 |
With no nitrous and while being spun relatively slow. Just imagine when he spins it with a 9.77/2.65 like the others on here do
07-03-2019, 01:08 PM | #123 |
Dyno Show Queen LOL
Update: I took the car back to Sorians to try and resolve some of the hesitation and bog issues that i'm having off the line while trying to launch.. 5 % might of been from the 112mm but most of it was the clutch and rear end protection.
The 17s from what he told me not a lot of tweaking can be done so He had HPtuners write my 17 vin into a 19 file. while he was waiting for the file Greg Kong contacted me out of the blue about blower porting, on the 2650 mustangs they have been picking up 100 plus RWHP. So I sent it to him for some porting.. The blower just came back and Matt said I have good news and bad news.. the good news is your up almost 2lbs at 5000 rpms... " I say 5000 because I haven't been able to make a full pass because rail pressure is doping to much" So the porting took my safety net, if you remember I was running a 9.2 lower or the 15% over drive ATI (on an LS motor its a 17% I believe) and 3.0 upper making 16psi. at that time I had room for 1 pulley swap. Now the plan is to go up a size to 3.25 rather than going to a 50/50 mixture. I figured if I can make a tad more power and turn the blower slower its a win win! Another note 3.25 is the largest you can run with the 112mm I didn't have a problem with the 103mm but with the 112mm its very close... I still have a stock lower I guess we can go that route if all else fails and I'm still out of pressure. should have the car back this evening for some more numbers and the bog issue fixed!
08-21-2019, 06:23 AM | #124 |
Drives: CTS V3 Join Date: Aug 2019
Any more updates on this build?
08-21-2019, 11:52 AM | #125 |
Dyno Show Queen LOL
I'm in the process of doing port injection or DXI. I'll make a decision tomorrow and be updating.
08-21-2019, 12:25 PM | #126 |
Surpassing FIC +30% injectors and the LPE high volume pump is pretty good problem to have! Quite a beast you got there.
