TireRack
Old 03-23-2017, 12:29 PM   #113
JERRYwss6
JERRYwss6's Avatar
Drives: 2011 rjt Camaro SS
Originally Posted by swiftkart View Post
Go with 2012LS3Vert belt wrap bracket since it does the same thing as the LC32 setup I'm using and also 2010SSRSM6 who turned me onto LC32's bracket by the way, the extra belt wrap is a must.
Hey man seen you have a nick Williams 102mm throttle body. I'm wanting to order it but seen people have issues with it, which one do you have? The regular one or the boosted application one?
JERRYwss6 is offline   Reply With Quote
Old 03-23-2017, 12:38 PM   #114
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
I have both versions. I had the non boosted version and it was fine. There are parameters that are now adjustable in HPtuners for the error that causes the blade to close. In addition, I ran it with our snout which creates lift on the back of the blade, which helps with the commanded opening % vs actual % error. I only switched to the boosted version so I wouldnt have a potential issue on the dyno when I aim for 1000rwhp on E85. I have two extra NW standard versions on the shelf if you end up wanting one, just PM me. They are my personal extras.
2012LS3VERT is offline   Reply With Quote
Old 03-23-2017, 01:43 PM   #115
JERRYwss6
JERRYwss6's Avatar
Pm sent
Old 03-23-2017, 04:33 PM   #116
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
after reading this interesting thread.. I'm so glad I went TT...
Old 03-24-2017, 07:28 PM   #117
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
NW102 regular, no issues at 800+rwhp, I'm sure Ted J. has the settings spot on.
swiftkart is offline   Reply With Quote
Old 03-29-2017, 08:24 PM   #118
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
Car hit the dyno after the ice bucket went in...... Huge difference in IAT's and looks like I'll get her back later this week or early next week as long as the new lid is done.
Now I just need someone to get a bigger snout out already and get a 102mm TB/CAI setup.
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 03-30-2017, 12:06 AM   #119
2012LS3VERT
We should be testing our snout late next week, depending on the dyno. My motor is getting new rings, so I found someone local with a fresh big cube/boost build to do a back to back to back test on. When it does go into my car, I am definitely going to modify my existing CAI box for a 4.5" tube and filter, probably with a velocity stack filter mount. I will post up parts and sources, as we don't plan on manufacturing one. The CTS-V guys with 102mm TBs see decent gains because of the ID of the intake tube being at least as big as the 102mm TB.
Old 03-30-2017, 11:20 AM   #120
JERRYwss6
JERRYwss6's Avatar
I'm pretty sure JLT makes a 4.5 intake tube it's for a stock ls3 intake could fit with some adjustments. I don't have a magnuson anymore :( I hated that it didn't whine and I ordered a RDS spacer that never got here so I filed a claim and won. Goin with twins now.
Old 03-30-2017, 11:28 AM   #121
2012LS3VERT
No problem, i dont have the whine problem with a cog drive I just love TVS blowers on street cars, 80k miles easy before even a blower oil change.
Twins are awesome, I have turbo cars as well!
Old 03-30-2017, 11:45 AM   #122
JERRYwss6
JERRYwss6's Avatar
Yea the only thing with the cog is that it's there all the time. Yes I loved the inthe instant power, made passing very easy.
Old 04-05-2017, 12:12 PM   #123
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Our part is different, but does the same thing. It is compatible with any number of ribs. I just have to make some of the brackets. It will be an add on piece to our 10 rib kits and 8 rib kits when we have those as well. That will make it available to anyone with a 6 rib kit also. In the pic, I tested it with an 8 rib belt while I waited on my 10 rib belt to come in. I did not try a 6 rib belt to see if it would slip at my power level.
Any progress on the 8-rib kit?
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 04-05-2017, 03:28 PM   #124
2012LS3VERT
Ive started making some of the pulleys, but we generally really recommend the 10 rib for most people. The only real cost difference will be the water pump, and our cost with the pump ends up being about the same as a pieced together 8 rib kit. I am working it though, possibly with a powerbond 8 rib, as ATI doesnt make an 8 rib for the Camaro.
Old 04-05-2017, 06:32 PM   #125
swiftkart
swiftkart's Avatar
I've had good luck with my 8 rib Powerbond.
Old 04-11-2017, 09:30 AM   #126
Tonka1
Drives: Camaro
Checking on availability on the custom snout for 102mm your making
Tonka1 is offline   Reply With Quote
