Old 09-27-2017, 10:10 AM   #113
RS-Chevy-SS
Drives: Hyper Blue 1SS NPP
Update - GM had the tech pull the bank 1 head. No issues. They instructed the tech to replace all lifters however. Tech is doing that now. Tech told them he doesn't think that is the problem and he thinks it's bottom end. They are going to do the lifters and then recheck for the knock. GM is being cheap.
Sent from my Pixel XL using Tapatalk
RS-Chevy-SS is offline   Reply With Quote
Old 09-27-2017, 07:59 PM   #114
ShadySS
Drives: 2017 Hyper Blue SS
hmmm interesting, Thanks for the update.
ShadySS is offline   Reply With Quote
Old 10-02-2017, 02:51 PM   #115
RS-Chevy-SS
Update - Dealer called me today saying car is ready. Said they drove it 70 miles no issue but we both don't think that was the problem. Going to pick it up and see what happens.
Old 10-02-2017, 03:36 PM   #116
AZ_1LE
Drives: 2019 ZL1 1LE
Hope it's good news.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 10-02-2017, 07:59 PM   #117
Jeremy711
Jeremy711's Avatar
Drives: 2016 2SS
My 2SS is making a rattle around 1,000 RPM. Only does it upon light throttle application and as you are coming off the throttle. Hopefully it's just a heat shield but it sounds 'rotational and fast' to be just a rattle. 2 videos below. One as I'm coming off the throttle the other is cracking the throttle pulling into the garage. I'll be visiting the dealer tomorrow.
https://photos.app.goo.gl/dTyj76uKdhaT4EqE3
Jeremy711 is offline   Reply With Quote
Old 10-03-2017, 08:58 PM   #118
PinHead
Drives: Duramax
Make sure they also completed an oil change.
Failing to change the oil when opening the intake/lifter valley/heads can cause debris and coolant to contaminate the engine's oil.
I've seen more than one engine limp in with internal damage from this.
PinHead is offline   Reply With Quote
Old 10-18-2017, 10:39 PM   #119
RS-Chevy-SS
Update. Noise still present. GM called and offered to repurchase yesterday. I accepted.
Old 10-20-2017, 02:35 AM   #120
PinHead
Drives: Duramax
Good deal, (on the buyback not the Eng problem).
Old 12-07-2017, 06:54 PM   #121
RS-Chevy-SS
Last update. I just dropped the car off at the dealer and completed the repurchase.
Old 03-27-2018, 09:42 AM   #122
histobeast
Drives: '18 SS 1LE SW
Damn
histobeast is offline   Reply With Quote
Old 09-16-2018, 06:03 AM   #123
Ace01
Ace01's Avatar
Drives: 2018 1LE SS "Silver Bullet"
AFM disabled on manual trans-Camaro's??
Originally Posted by LibertyHill View Post
I did some research and it does seem to confirm the failure would be less likely to happen to the manual cars where the system is disabled. There are a lot of recommendations out there to disable it ASAP for long engine life. Most of the failure history is on the old engines though.
"Doing a bunch of research, found this page. There have been instances of AFM lifters collapsing because of failed oil control solenoids or the lifter guides allowing the lifter to rotate. Other than that, design flaws were noted. Normally, oil pressure collapses the lifter in V4 mode and when it switches back to V8 mode, relieves that pressure in the lifter to allow it to come back to full height. When they fail, it's an internal mechanical failure preventing them to return. In that same page, it says that deactivation should prevent the AFM lifters from failing. But, this is assuming that the lifter guides are good."
Silver Bullet 1LE SS
Ace01 is offline   Reply With Quote
Old 09-16-2018, 11:32 PM   #124
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Yes. But they STILL put the crap afm lifters in ALL LT1's, manual trans included.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 09-17-2018, 08:07 AM   #125
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Unless I missed it, what are you getting in its place?
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
