02-07-2020, 07:37 AM | #113 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
No, I have not been to the dyno. Car is in Georgia, I am working in DC. When I get home to see the family, I am getting the house back up to spec after 6 years of renters. That leaves little time for the Camaro. Usually I just get to wash it and take it for a drive or two.
I see the cam you posted about. I have watched that same BTR video interview about 12 times to better understand the valve events. On my 224/240 cam the IVC is 44 and the EVO is 60. I asked for cam that did not give up the low end torque of the LS3 and still let the supercharger sing up top. Also that it not be a max effort cam. I love the idle and low speed manners of the cam. The power in boost is incredible - I could probably make some more power with a 228/244 or a 230/248. But am very happy with what I have now. If I were to do it again. I think I would look for cam 228/244 .640 int and .510 exh keeping near that .3 rule. The .510 on the exh side would help the valve train since the exh valve is heavier. No expert, just an enthusiast.
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi Last edited by racesloth; 02-07-2020 at 08:59 AM. |
02-07-2020, 07:50 AM | #114 | |
Drives: 2010 1SS LS3 Join Date: Aug 2019
The “off the shelf” BTR ls3 supercharged centri cam is real close, maybe better in some places. 227/244 115+5. .615/.595. This one would put dcr at 8.16, ivc 43.5, and evo at 62 with 5.5 overlap. I asked twice if the cam specs were correct and he emailed back and said yes.
2010 CGM 1SS
408/4L80E/ZL1 ESS G4 |
02-07-2020, 08:17 AM | #115 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
02-07-2020, 08:37 AM | #116 | |
Ted.
www.jannettyracing.com
02-07-2020, 08:41 AM | #117 |
Great choice if you stay with stock cube, but if you stroke it and build a 416, things change and cam dynamics change. I could not help myself and ordered the ESS G3X tuner kit btw. I had them include a few extra different parts than most but basically what you have. No waste-gates or other tricks. Just rpm limit the boost for now till I build a short block. Cam change is all I am doing to prep for the install.
2010 CGM 1SS
02-07-2020, 08:46 AM | #118 |
Dan
I do not have a 427. I am SBE LS3 376 with stock CR. I will have to look up my dynamic CR with the current cam (8.15 IIRC). EDIT: DCR is 8.13
The BTR3 centri 5.5 of overlap goes more with current thinking on centri set-ups. Mine has exactly zero overlap. I think the diff btwn a cam with evo at 61 and ivc event at 45.5 degrees and a cam with ivc 43.5, and evo at 62 is negligible for a street car. Any difference could be made up in the tune and boost level. Plus all of the other variables like induction, exhaust set-up, trans and rear end gearing. Who can tell? These things are more critical in a specific purpose built machine that does one thing very well. A well sorted 1/4 mile car would not make a great 1/2 mile car. Bottom line is are you happy when driving your ride?
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi Last edited by racesloth; 02-07-2020 at 11:16 AM. |
02-07-2020, 12:20 PM | #119 | |
2010 CGM 1SS
02-07-2020, 12:55 PM | #120 |
Dan
You are thinking of Bildo maybe? His cam is larger at 228/244. TBH when I called up TSP to order the PATG cam - they said they would have steered me slightly bigger. So I feel your guy's recommendation is good. Your car will be a beast...
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
02-07-2020, 08:36 PM | #121 | ||
02-07-2020, 09:26 PM | #122 | |
2010 CGM 1SS
03-12-2020, 11:51 AM | #123 |
Dan
Going to add the DSX flex fuel and tune for E85 as they new sell it near my home.
I am going to run some logs this weekend and take the Camaro to Cars and Coffee at Jackson, SC (House of Hook). I still don't know how much boost I make. It is pullied for 10lbs but on a stock LS3. I have ported heads, blower cam, LT's and 3" exhaust. So I am thinking I am below 10 - 7-8 maybe... ESC makes a larger crank pulley 8.25" vs my 7.8" and I can swap from a 3.6" blower pulley to a 3.47" or 3.33" - I just want to know where I am at before I move on anything else...
Dan
03-12-2020, 12:21 PM | #124 | |
03-12-2020, 12:37 PM | #125 |
Dan
Yes I have HP tuners and a ZL1 MAP sensor - I just have not run logs on it since I got it back to the US. I was in a hurry to get it on the boat back from the UK and did run 1 or 2 logs but I had the DSX aux pump plug backwards (it will connect both ways so it did not read the MAP sensor) stupid I know - Flipped it and ran a short log to make sure it was working at idle and threw it on the boat.... That is why I will run logs this weekend....
Dan
03-12-2020, 02:04 PM | #126 |
My car runs much better on E60. Mine read 9% before I got my first tank of e85. Adding the sensor changed fueling, so be aware. It is much more responsive to lambda changes. More stable for sure.
2010 CGM 1SS
Tags |
cam, id850, twin disc, whipple |
