#113 | |
![]() Drives: Rally Green 2020 ZL1 1LE A10 Join Date: Jul 2018
Appreciated. |
#114 | |
I know it's an old thread but I promised when I came across the alignment specs I would post but since then there have been quite a few others with this same issue. |
#115 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
There are no downsides, only improved rear-end stability and composure in the latitude plane.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
#116 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Sucks it takes so much time/effort to install them... |
#117 |
![]() Drives: zl1 Join Date: Sep 2018
The cradle bushings in the IRS suck. The rear cradle and the toe rods and control arms are junk. Spend 700 and get BMR stuff and ZL1 1LE Solid Rear Cradle Mounts from gm for 375. Mustang and camaros IRS suck when it comes to the bushing causing the cradle to move around and wheel hop.
#118 | |
I called my dealer for an install quote and the shop foreman straight out told me to have it done at a performance shop to avoid warranty issues. Personally I think that if GM offers a performance part, it should be fully warrantied. I mean that is kind of the whole point of going with a GM performance part over an aftermarket company. Unless you are looking for it though, the bushings are mostly hidden from view. To someone like me who values handling and stability, it was still worth it.
Current:
#119 | |
My plan was to do the cradle bushing and the arms, but I ran low on funds , so I decided to just start with the cradle bushings. I no longer feel a need to do the arms or toe rods. Just the solid pucks back there gave me what I thought was lacking in an otherwise great handling car.
Current:
#120 | |
#121 |
![]() Drives: 2018 ZL1, 2018 Tahoe RST Edition Join Date: Aug 2018
My brand new Z does the same thing. It seems to be a common flaw. WOT does it every time.
#122 |
![]() Drives: Gen V Viper GTS Join Date: Jan 2018
+1
It would be great to find a dealer-blessed, warranty-friendly, cost-effective solution for this issue. First world problems, but still! |
#123 | |
![]() Drives: . Join Date: Jan 2013
I don't see how solid bushings could NOT degrade the ride and interior noise. You have less isolation. Rubber is used for a reason. |
#124 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
I had a 1SS 1LE and now a ZL1 1LE. Other than the improved stiffness and more planted and controlled rear end. There is zero difference in noise. Solid bushing dont do anything but help.
#125 |
![]() ![]() Drives: ZL1/335i Join Date: Apr 2014
I’m not totally convinced that this straight line rear-steer-like phenomenon is caused by the rear cradle bushings. I ran my car at the strip on drag radials last month, and it was rock solid (best mph was 132.7). I’d think the sticky tires would have compounded the issue if that was the case.
The fact that it’s been reported by ZLE owners also backs that up. On my car, it really only seems to happen when there’s a small amount of steering angle present. Like making a lane change while WOT. Or accelerating along a gentle curve on the freeway. I still feel like it’s something with the E-diff calibration. |
#126 | |
Not sure what to say, other than the engineers are not going to tune and install cradle bushings for no reason. It would be much easier for them to solid mount it, and call it a day. |
