04-10-2016, 10:10 AM | #113 |
Drives: 2016 1ss camaro Join Date: Dec 2015
04-10-2016, 10:12 AM | #114 |
Drives: camaro Join Date: May 2013
How the f are you guys getting under this thing to check??? I guess ramps are needed.
Hyperblue/JetBlack |
04-10-2016, 10:18 AM | #115 |
04-10-2016, 10:19 AM | #116 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
OK even tho my VIN comes up in the recall I climbed under there today and it appears I am good. No raised numbers. Here is a pic I took and circled the area it would be according to the bulletin.
Instead I saw what looked like sharply engraved numbers in the area I circled in blue below. It was hard to see this area and could not get a pic. There was definatley engraved digits in this area so it will not be in the same area as the raised letters would be. Again VIN ends in 134437 built 12/15
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
04-10-2016, 10:24 AM | #117 |
Hyperblue/JetBlack Last edited by suzook; 04-10-2016 at 10:46 AM. |
04-10-2016, 10:52 AM | #118 |
Drives: Used to Drive Blue Camaros Join Date: Oct 2008
Thanks very much for the detailed info. Unfortunately, I'm on the lucky VIN list so it's off to the dealer this week. If you want to check the pan for the raised number at home, you don't have to remove the aero pan. There are two quick ways to let you clearly see the number (or lack thereof).
1. You can see the raised number from the gap behind the crossmember on the passenger side. The gap is to the right in this photo. Use a good light or camera. This requires you raise the car to get into position. 2. Another method is to slide a camera phone up into the gap behind the crossmember and take a few photos. Obviously I'm using a lift, but this can be done without ramps in the driveway with a bit of stretching. Be careful not to hit the exhaust when reaching underneath. |
04-10-2016, 10:53 AM | #119 |
Here's the photo of my pan with the raised number.
04-10-2016, 10:59 AM | #120 |
In the pic you quoted the blue circled area is where I found my engraved numbers. The red circled area is where the raised numbers are wich you can plainly see there and the small red circle with the number 2 disregard this is the pic from the GM bulletin.
04-10-2016, 11:03 AM | #121 | |
Drives: 2SS, Hyper Blue Join Date: Feb 2016
Pull this cover: (a few 10mm bolts, 3 #10 torx and a pushpin) Searched all around this area with a mirror. Look to the left for the engraving (buried so it can't be photographed). If you have the raised numbers they should be easy to see though:
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav Last edited by Modshack; 04-10-2016 at 11:23 AM. |
04-10-2016, 11:45 AM | #122 |
Drives: Me: '16 2SS yellow, Wife: '16 1SS Join Date: Feb 2016
yep mine needs it!
- Dennis Hixson
2016 Camaro 2SS ** EdelBrock E-Force Supercharger, 3" pulley, RotoFab air intake, Alky Methanol Injection System, Corsa Extreme Exhaust, Kooks longtube headers, TSP VV2 CAM, 1LE wheels @ 285/30/20 front & 305/30/20 rear... 707.41rwhp, 702.36 torque |
04-10-2016, 11:54 AM | #123 |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
GM says mine is possibly affected.
I stuck a GoPro and a flash light under the front of the engine and got this picture. I think this means I'm all good? #124752 |
04-10-2016, 11:58 AM | #124 |
Retired from Car mfrs....
Post 119 seems to be the difinitive pic.....
04-10-2016, 12:05 PM | #125 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
According to the recall site where you enter in the VIN, mine is G2G.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
04-10-2016, 12:35 PM | #126 |
Damn I'll be bringing mines in tomorrow to get checked out.
Sent from my SAMSUNG-SM-N910A using Tapatalk |
