#12447 |
Had an urge to polish it again. So I just gave it a full polish to strip off the other coating I had on it because I wanted to put a different one on.
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22 New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17 8/24. IT HAS ARRIVED at the dealer 8/25- It is in the Garage ACS ZL1 Sideskirts, 20% tint, CAI Intake |
#12448 | |
![]() Drives: 2023 Camaro 2SS and 2012 Camaro LS Join Date: Sep 2022
#12449 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
It they do exist they would be replica wheels. I haven't seen any 1LE replica wheels with a machined face. Most of the 1LE replica wheels I've seen are either black or graphite in color.
2023 Dodge Durango SRT (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
#12450 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
What did you do to your 6th Gen Camaro today?!
Few days ago moved into its new home
(14x22 garage) still a work in progress but a lot closer now with the floor done ![]() ![]() Sent from my iPhone using Tapatalk Pro
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#12451 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
Very nice, room for all the essentials too.
J-Rod Built and Matt@FSP Tuned |
#12452 |
Old Gearhead
Drives: 2023 GMC Sierra Denali Ultimate Join Date: Nov 2018
Hooked up the Battery Tender.... 40°and rain.
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black |
#12453 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
#12454 |
![]() Drives: ‘20 2SS Crush Orange Join Date: Sep 2022
Not sure if you received any good touch up advice but I’ll share my experiences. The biggest mistake is to make brush strokes. Best way is to “color between the lines” by loading the tip of the little brush with a drop of paint and dabbing into the chip without going onto the surrounding surface of the good paint. Let it dry for a minute and it will likely sink. If so, repeat by dabbing again until the chip is filled even with or slightly higher than the level of the surrounding paint. This will definitely produce better results than making brush strokes. After fully dried, I’ve had good luck with blending it a little bit, if necessary, with rubbing or polishing compound by hand. Hope you can picture this, and with a little practice you can become very proficient.
#12455 |
![]() Drives: 2023 ZL1 A10 Join Date: Nov 2021
[QUOTE=Ryanbabz71;11243577]Few days ago moved into its new home
(14x22 garage) still a work in progress but a lot closer now with the floor done [IMG]https://uploads.tapatalk-cdn.com/20221019/8d88a185864ff0896c7249b4774b426e.jpg[/IM ![]() Sent from my iPhone using Tapatalk Pro[/QUOTE Very nice enjoy..
#12456 |
![]() Drives: 2021 2SS Join Date: Jul 2020
Got it washed and waxed (Meguiar's Ceramic) in prep for winter slumber. Still driving it a for more weeks, but at least its all set to go for when the time comes. A quick wash, oil change and plug in the battery tender!
#12457 |
took it out for a drive today for the first time since I polished it again and coated it with Gtechniq CSL last Monday.
This weekend might be the last hurrah for it before its basically parked for winter.
#12458 |
![]() Drives: 22 LT1 Join Date: Oct 2022
I pulled out a clay bar and used Turtle Wax's Hybrid Solution's Ceramic Spray Coating. I'm trying to use ceramic products, and will be applying a 2nd coat after waiting 24 hours.
I'm not sold on the TW Hybrid Solutions product. I definitely don't think it offers superior gloss or depth of color but my car is a darker color and I didn't want to rub a product into the paint, wait for it to dry and then buff out. I'm also not sold on spending $1k for a professionally applied ceramic product, but, I'll see how this product holds up. |
#12459 | |
https://www.autoality.com/store/pc/O...a-407p8537.htm You do NOT need to polish the car if you are happy with the paint. Just do a good wash and maybe iron decon and then a panel wipe and install the coating.
#12460 | |
Thanks for the tip! I'm going to check Optum out. |
