#12433 | |
![]() Drives: ‘20 2SS Crush Orange Join Date: Sep 2022
#12434 |
![]() Drives: Chevy camaro Join Date: Jan 2022
Started doing an Oil, filter and tire rotation. My garage is kinda small, with tool boxes lining one wall and a smoker and my motorcycle on the other.
Finished the oil and filter change and started the tire rotation and found this, so I stopped. No reason to to do the other side. My camaro is a 2017 convertible with 30,000 miles on the original tires, which puts them at 5 years old. Looks like I'm finally getting rid of these noisy run flats. Unfortunately, retired and fixed income. Looking at the BFGoodrich G-Force Comp-2 A/S Plus All-Season Radial Car Tire for Ultra-High Performance, 245/40ZR20/XL 99W or the Continental Extreme Contact DWS06 Plus 245/40R20 99Y B.
SOLD - 2017 Camaro 2LT RS Convertible 2017 GMC Arcadia Denali |
#12435 |
I'm wondering! If I use some really strong rubber glue, duck tape and a large wood working clamp to hold it together until it dries, how many more miles could I get.
#12436 |
![]() ![]() ![]() Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
The correct answer is “0” miles!😂😂
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
#12437 |
PaPa Smurf
Divisional AutoX Houston Region.
2022 Rapid Blue SS 1LE
#12438 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Had the DWS06's on my '16 C7 2LT and the BFG Comp-2 on my '17 SS 50th 'vert. I would give the edge in ride comfort to the Conti's (softer side wall) and the traction / handling nod to the BFG's just due to the stiff sidewall. Both worked fine in the wet, and very light snow (although that was not something I'd recommend in a C7).
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
#12439 | |
I have the Contis DWS06 Plus. We’ll see how they wear but from the dry pavement street driving I do, they handle extremely well. Good luck in your search. Always exciting to get new rubber. Just don’t let some kid take a screwdriver or metal scraper to your wheel weights, scratch & gouge your wheels then leave the #*%*! old adhesive, and hammer the crap out of your lugs with an impact. Another tire mounting common mistake is to take a tire in with minimal weights, only to get new tires and have a long line of weights simply because they didn’t have the knowledge or were too lazy to match-mount once the balancer called for excessive weight. End rant. |
#12440 |
Washed her at the new "detailing bay" extension I had the concrete guys append to the driveway. Pretty convenient, now everything reaches and I don't have drag the pressure washer and the buckets and everything around a zillion times
![]() On the same note, I began using Adam's graphene shampoo and graphene detail spray a month or two ago as an experiment, and they are looking good so far. The graphene detail spray is way better than their old "plain" counterpart, it leaves zero residue no matter what and adds more shine that lasts a bit longer.
#12441 |
Electrical Engineer
![]() Bought some dishwashing gloves to try washing the wheels more easily. Still waiting on choosing a set of wheel brushes, but this certainly helps cleaning the backside of the spokes. Switching to my winter wheels/tires soon. When I do, I'll fully clean and ceramic coat these wheels. Just turned 1,500 miles.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 45k mi. @ Mar 2025 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
#12442 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
Thanks. I considered having a shop remove, clean and ceramic coat my wheels, but thought better of it for the same reason. And even though a small bottle of the ceramic coating was $50 it was considerably less than what a shop would charge to do the work.
2023 Dodge Durango SRT (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
#12443 | |
The dry rot is just one of the reason that I'm going to go with four new tires. Might go with new wheels too. I've really hated the ride of the run flats, so here's my excuse. Unfortunately, I have to sell the M1a from my small collection to pay for it. But the arthritis in my left thumb makes it easier.
#12444 | |
I have one of these https://www.amazon.com/Adams-Microfi...41-spons&psc=1 and this https://www.carsupplieswarehouse.com...ane-wheel-mitt I prefer the work stuff wheel mitt
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22 New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17 8/24. IT HAS ARRIVED at the dealer 8/25- It is in the Garage ACS ZL1 Sideskirts, 20% tint, CAI Intake |
#12445 | |
![]() Drives: 2016 2SS Convertible Join Date: Dec 2019
https://mckees37.com/collections/ez-...z-detail-brush It works great and gets between the calipers and wheel to do the inside barrels fully. I coated my wheels with this: https://mckees37.com/collections/sio...-wheel-coating Two summers since I did it and it's still repelling stuff great! Doesn't hurt that I also swapped the Brembo pads to Powerstop Z26 pads either!
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
#12446 | |
Electrical Engineer
I was looking at Wooly wheel brushes from Chemical Guys.
