View Poll Results: Who has experienced an oil pump failure?
2016 or earlier 25 14.88%
2017 57 33.93%
2018 77 45.83%
2019 4 2.38%
2020 4 2.38%
2021 1 0.60%
Voters: 168. You may not vote on this poll
Old 12-25-2022, 05:14 PM   #1219
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
Originally Posted by Mark R View Post
Pump failure is not complicated. The pivoting ring inside the pump, the part that bears against the pump vanes, will crack. Once that does, it is a matter of a few seconds or a few hours until the pump has a catastrophic failure.
Other vehicles with the same pump aren't reporting such a high failure rate. Could it be the stress the LT4 engine puts on the pump is the reason?
george is offline   Reply With Quote
Old 12-26-2022, 11:14 AM   #1220
Mark R
Drives: 2018 ZL-1
Well, increase the stress enough on any component and you will break it.
Old 12-26-2022, 04:21 PM   #1221
55chev
Lamude Racing Engines
55chev's Avatar
Drives: 2018 ZL1 Hyper Blue Jennetty tuned
MAYBE ,but more than likely a harmonic frequency issue.due to being supercharged,if you think about the blower belt attached to the front pulley.
55chev is offline   Reply With Quote
Old 12-26-2022, 05:05 PM   #1222
george
ZL1 Driver
george's Avatar
Interesting!
Old 12-27-2022, 11:54 AM   #1223
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Originally Posted by Katech_Zach View Post
They did make revisions, there are 7 part numbers I believe. So I do think the later model years have improved pumps, but they still have chances of failure. Just at a lot less probability. Every time GM releases a new version, we buy one and test it like the rest. We have been able to break every pump we have stressed so far. The newer pumps are harder to break, but they still break.
Cracked housing (center left)
ZX-10R is offline   Reply With Quote
Old 12-27-2022, 04:59 PM   #1224
Mark R
Drives: 2018 ZL-1
There you go. A picture is worth a thousand words.
Old 12-27-2022, 05:30 PM   #1225
george
ZL1 Driver
george's Avatar
The TSB (https://gm-techlink.com/?p=12041) describes there may be no or low oil pressure along with DTC P06DD (Engine Oil Pressure Control Solenoid Valve Performance). The two issues including the cracked housing must be connected somehow. I read in a subsequent GM Authority article about KATECH and it has some good numbers regarding tolerances.(https://gmauthority.com/blog/2019/05...engines-video/). It would be nice if a recall was eventually done, but I doubt that.
Old 01-03-2023, 09:55 AM   #1226
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
Dry sump or wet sump has nothing to go with the oil pump failures in 2017 and 2018. There are no advantages to dry sump other than space savings as long as both system have similar oil capacities. The Camaro has enough ground clearance to get away with a wet sump oiling system to reduce the cost and complexity vs a dry sump system. If GM engineers felt a dry sump was needed in the Camaro, it would have been there.
The is extremely inaccurate information.
The only reason to go wet sump is simplicity, pricing, and packaging. It is typically easier to package a wet sump oiling system because there is no dry sump tank. It would have added $2,000~ or more to the base price of the Camaro that they needed to keep competitive with Mustang/Charger/Challenger/etc.
Having a dry sump is extremely advantageous, especially for a tracked vehicle. You are pulling your oil from a full tank of oil, and all engine oil is scavenged out of the pan and pushed back into the tank after being filtered. There is 0 change at oil starvation if everything is functioning properly, regardless of track conditions.
GM engineers put a factory corvette dry sump oiling system in the GT4 Camaro because the wet sump was inadequate. There is a reason why a lot of the seriously tracked 6th gen Camaros are scattering on large highspeed sweepers or uphill straights. Oil is returning to the sump and the g-force is keeping the oil away from the pickup tube.
For the large majority of 6th gen owners, they will not push the car past the limits of the wet sump oiling system, so it is adequate for most users which is why GM kept it the way it is. The only reason the track-heavy ZL1 1LE did not have a dry sump oiling system, was the packaging involving the supercharger front drive and dry sump tank. They would have had to redesign the entire front rad / duct assembly to package a tank in front of the engine like the Z28.
Katech_Zach is offline   Reply With Quote
Old 01-03-2023, 09:57 AM   #1227
Z OH 6
Drives: 2024 CT5-V Blackwing
10-4, just going by the 1,000 other articles I've read on wet sump vs dry sump. Good to know they were all wrong. That being said, I don't think wet sump vs dry sump has anything to do with the oil pump failures since that seems to be an oil pump design issue.
Old 01-03-2023, 10:03 AM   #1228
Mikesvt04
Drives: ZL1 1LE
Katech_Zach
Can you please expand on the revisions of the stock pump and where/ what stresses cause failures in 19+ cars?
Mikesvt04 is offline   Reply With Quote
Old 01-03-2023, 10:07 AM   #1229
Katech_Zach
There is a purpose for both systems. Wet sumps are typically not suggested for any sort of road racing. COPO uses a wet sump in their drag engines, but they have special pans designed for oil sloshing while launching. There is a reason Corvette hasn't had any wet sump engines since 2014.
You can improve the wet sump oiling system via baffling in the pan (improved racing, not released for gen 6 yet), but this is a band-aid.
Here is a good overview of both if you wish to further educate yourself on the subject:
Old 01-03-2023, 10:36 AM   #1230
ZX-10R
ZX-10R's Avatar
Higher viscosity oil spec for the 1LE is another band aid
No reason to run a modern engine with higher oil viscosity than 10W-30 imo, 10W-40 for racing maybe
Old 01-04-2023, 08:08 PM   #1231
george
ZL1 Driver
george's Avatar
Zach:
Your recommendation for those of us with extended warranty on a 2017 ZL1 regarding the oil pump replacement?
Old 01-05-2023, 08:15 AM   #1232
Katech_Zach
Zach:
If you do not modify your car, or you work with a dealership that has more leeway, I wouldn't worry with the extended warranty. You should be covered.
If you do have a failure, I would highly suggest for a new complete engine, and not a repair. Junk runs through the engine at varying levels from the failure, and you do not want to just slap a new pump on and go.
Originally Posted by Mikesvt04 View Post
Katech_Zach
I won't go into extreme detail, but the same failure happens in the 19+ cars, just far less frequent. We can cause them to fail the same way as the first revision, it just takes a lot more effort/stress to do so.
We have had a handful of 17-18 cars come in with pump issues, only 1 19+ car with a failure, which happened to be a 2021.
