01-01-2018, 05:14 PM | #1149 |
Drives: 2016 F150 Join Date: May 2014
I'm pretty sure Ford boys are idiots as well. Constant trolling and excuse making because Ford puts out inferior vehicles PRETTY MUCH across the board.
YOU JUST WAIT UNTIL THE MUSTANG GETS UPDATED, GUISE. - Ford dummies |
01-01-2018, 06:33 PM | #1150 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
Chevy guys, Ford guys, everyone in between...we're ALL idiots, lol!! It's just that us over here with team Chevy have the faster cars while they all are just trying to keep up. And we don't pay markups like they do for their inferior vehicles.
01-01-2018, 07:01 PM | #1151 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
...it didn't have the right option package. ...if had too many options and was therefore heavy. ...they didn't change the brake fluid
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
01-01-2018, 08:04 PM | #1152 |
01-02-2018, 02:13 PM | #1153 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
01-02-2018, 02:26 PM | #1154 | |
Drives: E92 BMW M3 Join Date: Oct 2012
I mean, how close to apples to apples do we need? Eventually we will be comparing a 2018 GT to a 2018 GT.
J-Rod Built and Matt@FSP Tuned |
01-03-2018, 12:38 PM | #1155 | ||
Drives: SS 6 speed of course Join Date: Jan 2016
http://www.hotrod.com/articles/hrdp-...-valve-timing/ thus completely eliminating the phasing / overlap advantage a twin cam with cam phasers offer. Note I'm talking cam overlap not the inherent greater flow area of 4 valves vs 2 valves. GM played around with two cams in the block in the late 90s, this is effectively solved with cam in cam about 8% increase in HP and much broader torque range vs just phasing a solid cam. So if low tech = smaller lighter package, lower center of gravity, significantly more drivable and usable torque, better MPG, cheaper to produce, completely rebuildable, easy to work on, cheap parts, and can see huge gains in HP be simple additional technology like cam in cam. I think I'll stick to simple stupid. Oh and I do build and race B18C and K20 Honda engines, so it ain't like I'm scared of 4 valve.
01-03-2018, 01:10 PM | #1156 | ||
01-03-2018, 01:29 PM | #1157 |
Drives: 2016 CAMARO 2SS Join Date: Apr 2017
Have any other 18's run 11's bone stock?
2016 SS A8 STOCK 12.35@113.6 DA 1956
PRAY E85 TUNE,PRAY PORTED IM/TB,ROTOFAB DRY, DRAG PACK 11.33@121.8 DA 1248 PRAY PORTED MSD, 2" TSP LT's 11.38@122.4 DA 3664 GFORCE DRIVESHAFT,LME 174 T-STAT,ATI UDP up next... |
01-03-2018, 02:02 PM | #1158 |
Drives: 2019 GT350 Join Date: Jan 2011
I'm curious has any publication review run an SS into the 11s, how about a very low 12? Any? or do we simply have to take the word of private owners that their car is 100% stock, running pump gas, and has done so?
Is this the fastest verified Pass? (Summary: Driver-Jeff Lutz, Private Track Rental, over 80 passes best-12:21) http://www.hotrod.com/articles/2016-...ed-1500-miles/
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot Last edited by newmoon; 01-03-2018 at 02:26 PM. |
01-03-2018, 02:19 PM | #1159 | ||
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
Sent from my SM-G955U using Tapatalk
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
01-03-2018, 02:19 PM | #1160 |
As far as I know, only the Hot Rod magazine test with Evan Smith driving it hit 11's. 11.8XX was his best time, said bone stock and only adjusted tire pressure. I believe he was consistently hitting high 11's too.
01-03-2018, 02:20 PM | #1161 |
Do you mean to produce and/or buy? I wasn't aware of that. I have to admit I am slightly surprised. I just assumed the Coyote would be more expensive considering it is bigger and has more moving parts, 4 cam shafts etc etc. YTou learn something new everyday i guess.
01-03-2018, 02:25 PM | #1162 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
Car and Driver finished up their long term test after 40,000 miles in a manual 2016 Camaro and it ran a 12.3 sec @ 118 mph in their testing. https://www.caranddriver.com/reviews...rm-test-review MotorTrend in their initial review did a 12.3 sec @ 116.1 also in a manual http://www.motortrend.com/news/2016-...t-test-review/ |
