Old 05-06-2025, 10:53 AM   #99
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
The underhood diverter is flimsy sheetmetal that has been painted over. I would not worry about it providing any sort of structural rigidity/ integrity to the hood or the CF piece at all. Matter of fact, CF is very strong by nature, based on its build and having dealt with it so recently to do the bracket, I can tell you with full certainty that it is a very well made, very strong piece.
I'm not arguing, in any way, but does anyone have an option on if the OEM sheetmetal support we remove for this bracket have any heat protection for the CF Insert? I've wondered about that.
FWIW - I STILL love my bracket from GABE. It's awesome.
'20 ZL1 Black "Fury"
Old 05-06-2025, 11:18 AM   #100
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Thats a good question. I asked that to a prominent CF manufacture when I was looking into a CF lid, and they said "no problem" most CF resin is good for 200F direct contact... which is why the lid being smacked with 300F compressed air would not last long, even with a Ti insert. Considering the air gap and between the 150F lid and the CF insert, leaves us no concern.
Old 05-06-2025, 01:00 PM   #101
bcasurvey1
Drives: 2019 ZLE sold now 2021 ZLE
Originally Posted by LuckZL1 View Post
Hi bcasurvey1, I have had the bracket installed since my post and have already driven around 2,000 miles with it on at various speeds and from Los Angeles to Las Vegas. At higher speeds I notice a slight wobble in the Hood Insert which is most likely from the amount of new air being pushed over the insert now at speed, but as far as the hood is concerned as long as the hood was installed correctly you shouldn't be worried.
If you are worried about the holes you are using for installing the bracket, it should be hand tightened and not overdone, similar to how the rain shield is re-installed. You may run into issues using all the supplied nuts from GMS, so I reused all of the OEM nuts and One GMS nut for the center as it was easier to install than the OEM nut. (See picture below). P.S. I do not have the hood pins in yet.
Let me know if you have any other questions though, happy to help!
Thanks for the reply and disregard my PM I didnt see your post.
I may cut mine up and leave part of it on there, not sure yet, it depends what I have when I take it apart.
I dont have hood pins either and dont really want them if I can get away with it. (the latch is pretty solid).
What is the plastic looking piece under your hood? is that what mine will look like underneath?
Someone made a valid point about heat, maybe something to keep an eye on.
whoever put my hood on did a good job so i think it will be ok.
I am ordering a bracket today and trying it out and I will have my car on Daytona track for Track nights doing 155+mph on June 19th so it should be a good test, it either goes or blows lol....
bcasurvey1 is offline   Reply With Quote
Old 05-06-2025, 01:30 PM   #102
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Thats a good question. I asked that to a prominent CF manufacture when I was looking into a CF lid, and they said "no problem" most CF resin is good for 200F direct contact... which is why the lid being smacked with 300K compressed air would not last long, even with a Ti insert. Considering the air gap and between the 150F lid and the CF insert, leaves us no concern.
Old 05-07-2025, 05:42 PM   #103
LuckZL1
Drives: Camaro ZL1
You definitely don't need to cut up the water diverter if that is what you are talking about cutting up.
The latch is definitely very solid.
Which plastic piece are you referring to? The supports for the bracket?
As far as heat, I did a little bit of heat shielding (horribly) which you can see, and the hood has held up amazingly.
Oh yeah you definitely shouldn't have any issues but it will be the ultimate test! Lol
LuckZL1 is offline   Reply With Quote
Old 12-04-2025, 11:47 AM   #104
Laguna Crazy
Drives: ZL1 stick w track Mods
basic option here
looks nice but I did mine with a couple of strips of aluminum bent to shape for a couple bucks. mine is a strictly track car and don't drive in the rain.
Laguna Crazy is offline   Reply With Quote
Old 12-04-2025, 08:08 PM   #105
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
I know this is Gabe's thread, but the design of two, or four individual brackets has to be done using 7075-T6 not the 5052 grade sold at Home Depot which has half the strength.
I tested many versions before ending where I am... this design you are using can lead to a "tank slapper" with the scoop trying to rip itself from the aluminum tabs and press-in retainers at speeds exceeding 140mph. This is one part you do not want to save a few bucks on.
Patriot Motorsports USA is offline   Reply With Quote
Old 12-07-2025, 11:28 AM   #106
JSH
JSH's Avatar
Drives: '20 ZLE
I installed this bracket back in the summer, and of course, I don't believe there's way to measure its impact on engine compartment heat. But, it can be a bit disconcerting when you're parked at the light, and the sun is positioned to highlight the oil vapors escaping from the CC through the vent.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 12-08-2025, 12:22 AM   #107
SOCAL.M6.ZLE
As a proud member of the EPA, I think you made a typo... because I know your not implying that your catch can is venting to atmosphere... that would be very bad....
Old 12-08-2025, 05:38 AM   #108
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Good news, it looks like Gabe's hood bracket will allow my 2650 to fit under the hood with the current TooHigh PSI LS Port plates I have with no clearance issues ! We did the billet cover too so that would have also helped as I recall. But regardless, it's good news!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
2023_ZL1-AUTO is online now   Reply With Quote
Old 12-08-2025, 11:11 AM   #109
JSH
JSH's Avatar
Drives: '20 ZLE
Yes, MM Race and Wild CC systems vent to atmos. Somehow I think you knew that
2020 ZL1LE A10.
Old 12-08-2025, 12:12 PM   #110
SOCAL.M6.ZLE
Hell yeah... secondary benefit for sure!
Old 12-08-2025, 01:30 PM   #111
SOCAL.M6.ZLE
Unacceptable...
