Old 03-06-2024, 09:11 PM   #99
taylorforschool@gmail.com
PKG4U
taylorforschool@gmail.com's Avatar
Drives: 2018 ZL1
Originally Posted by 2018ZL1 View Post
Those great numbers! Hooking will be your challenge now! If it hooks you will be in the 8's easily! Very nice!
^^ Camaro big dawgs pushing big numbers!
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S
Mods after Warranty “Imma keep it stock”
taylorforschool@gmail.com is offline   Reply With Quote
Old 03-07-2024, 12:11 AM   #100
ZL14ever
Drives: 2018 Camaro ZL1 A10
What 100 octane fuel are you using? did you try going higher than 22 deg timing?
Nice results indeed
ZL14ever is offline   Reply With Quote
Old 03-07-2024, 06:52 AM   #101
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Awesome numbers. I don't remember seeing if you're still at elevation, but I think I remember seeing LMP getting some more power out of a 2650. I don't remember if it was on E', and of course, wouldn't know the cam' specs', but the boost was similar, and your numbers are still great.
'20 ZL1 Black "Fury"
Old 03-07-2024, 08:53 AM   #102
JSH
JSH's Avatar
Drives: '20 ZLE
Nice results indeed
Sunoco GT100
My tuner believes it only wants 22 deg. at wot, which is very surprising to me considering that I believe that's pretty close to stock advance. Actually, it's more than surprising, it's ... confusing
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 03-07-2024, 09:09 AM   #103
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Nice results!
Fwiw, Folks get way to worried about timing...my brother is the same way. 22 degrees is probably close for a setup like that. 24 would be absolute max imo. This isn't your average bolt-on or mild cam setup where guys are pushing 28-30degrees on Ethanol. Cylinder temps play a vital role in how you time an engine. Something making 1100+ vs 700 is going to have significantly higher cylinder temps. Aside from that it didn't hook before, so it sure as hell isn't going to hook now. So a degree or 2 of timing should be the least of concern here. lol
Old 03-07-2024, 10:45 AM   #104
JSH
JSH's Avatar
Drives: '20 ZLE
Nice results!
I'll put the 3.0" pulley on it on the street, and 2.625 at the strip. It's as fast as it can be w/o a cage, so this should do it.
2020 ZL1LE A10.
Old 03-07-2024, 11:30 AM   #105
JSH
JSH's Avatar
Drives: '20 ZLE
It's got the most boost +/- it's ever had so I'm not sure what it wants now. I'm sure an E guy could figure a way to make more on a bet.
2020 ZL1LE A10.
Old 03-07-2024, 12:08 PM   #106
ZL14ever
Nice results!
Thanks. I understand and agree with the logical reason behind leaving timing at 22 deg. I was wondering if the car is octane limited at this point. If so, do you think an E50 mix would allow 2-3 more degrees of timing?
Old 03-07-2024, 03:20 PM   #107
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Negative. I run E50 at a very similar power level and run 22 degrees. More timing will just be hard on the bottom end for little power gain IMO.
Old 03-07-2024, 03:43 PM   #108
JSH
JSH's Avatar
Drives: '20 ZLE
I've got a can of MS109 and would like to make a few pulls on it to see what it makes on say 24 degrees versus the current 22. I agree with Josh that every degree of advance increasingly beats the crap out of rods and pistons. But this engine is rated to 1400, so...
2020 ZL1LE A10.
Old 03-07-2024, 04:19 PM   #109
KingLT1
KingLT1's Avatar
That 1400hp is likely at the crank. At least that is how most companies rate engines. You are likely close to that now. At 17% drivetrain loss, 1400hp = 1162whp.
Old 03-07-2024, 04:30 PM   #110
JSH
JSH's Avatar
Drives: '20 ZLE
I have not thought much about LMEs horsepower rating, but you're probably right. By the way, they email me asking for a video of the dyno because they know how much it made. I didn't see the dyno and haven't seen a video
I looked into this crank to wheel horsepower loss topic last year and I ended up thinking it would be closer to 12 or 13%
2020 ZL1LE A10.
Old 03-08-2024, 11:07 AM   #111
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
What people often don't think about is tuners also have to take the owner into consideration. If it hurts the motor it is likely to always be called the "tuners fault." Does the owner read their plugs, log their car, do general maintenance? Things owners in the past would often do few nowadays have the know how to do themselves. Everyone wants the big hp with the stock reliability. That will never be a reality. Leaving a little bit of power out can leave a nice cushion for small mechanical issues. This is an observation and not aimed at anyone in particular.
I'm running the factory rods and crank in my C7Z that has been built for 10k miles now. It sees 24 degrees of timing by 3,400rpm and maxes out at 26. Engine runs like a top. Would I recommend it to someone that can't read data and turn a wrench? No. On the flip side the blower is still being ran in it's efficiency range where g/cyl still climb to the cams peak hp and running on DI only. A way many don't spend the money to do so.
CamOnlyJabroni is offline   Reply With Quote
Old 03-08-2024, 12:10 PM   #112
Z OH 6
Drives: 2024 CT5-V Blackwing
15% is typically a very accurate number for most modern auto transmissions, manuals will be slightly lower than that.
Z OH 6 is online now   Reply With Quote
