Old 05-13-2023, 08:20 AM   #99
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
Originally Posted by gatewayracer View Post
Not the OP here, but I posted in this thread since I felt the same as the OP as far as not noticing the extra 200 HP.
Anyway, I reached my break in point and went to a stretch of rarely used back highway separated by 1/4 mile of land between oncoming traffic and did a few pulls. Tires were warm and air temps in the high 70's and the stretch of road was flat as a pancake.
The first pull was in track mode /race and using the drag race launch control. At the release of the brake, the car sputtered (I felt like there was a problem) and the car seemed like it was trying but barley moving from 0-35ish, then after about 35 mph it laid me back in the seat through the 100 mph pull. Times were 4.50 at 60 mph and 8.50 at 101.
The second pull, I held the TC button down for 5 secs in track mode which turned off both ESC
and Traction control (all on me). I launched similar to the first run, I came to a complete stop, hit the throttle and couldn't keep the tires from spinning (38 psi per the dic) so I just aborted!
Third pull, still set in track mode with ESC and Traction control off, I launched with part throttle and was full throttle by 35 mph. Needless to say, the 0-60 was bad just like the 1st pull but the 60 to 100 was an exact duplicate of the 1st pull using launch control.
My 2021 2ss 1LE drag race launch was 4.2 to 60mph from timer (which was the 1st and only drag launch I did ever with the car, which was also on a back road). However, it never fell on its face and sputtered like the ZL1 which only had a 4.5 0-60 using the drag race launch control.
I suppose the ZL1 just needs some traction to keep the nannies from kicking in?
Your 60-100 mph split of 4.0 seconds is about right for an A10 ZL1 in warm air. It matches what Car and Driver got exactly. Motortrend was 3.9 sec. My car has been 3.8-4.0 sec 60-100 depending on temperature. A 4.0 split corresponds to a 125-126 mph trap speed in the 1/4 mile. I wouldn’t worry about the 0-60 split because it’s so traction limited.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 06-01-2023, 12:39 PM   #100
Greg83
Drives: 2023 ZL1 M6 Sharkskin
Ok, I promised you guys an update and I finally had time yesterday to get my ZL1 up to Nickey for an evaluation. I want to start by saying Stefano and Matt were awesome!!! They went above and beyond to take care of me and my car. They even gave me a great tour of their shop… pretty cool!! Matt and I took the car for an extended test drive where he was able to do multiple pulls and log a bunch of data… After driving the car and reviewing all the data Matt determined that my car is running appropriately for a stock ZL1. Stefano and Matt offered to dyno the car but it didn’t seem necessary knowing that Matt has a very good idea of how a stock ZL1 should run. In my defense I did state that the car did seem to run much better and pull harder after disconnecting the battery over night to reset a possible “low octane” map. After that I guess I was just a little paranoid and hoping to find a little more power. I guess I’m just like a lot of guys on here and want MORE POWER…lol. Anyhow it’s nice to know that my car is running as it should and I’m just a bit of a hypochondriac, and a little crazy. Thanks again Stefano and Matt!!!
2019 Porsche 911-T M6-SOLD
2020 Crush ZLE A10-SOLD
2023 Red Hot ZLE M6 ordered 5/9/23, never built
2022 Shadow Grey 1SS-1LE M6-SOLD
2023 Sharkskin regular ZL1 M6-SOLD
Greg83 is offline   Reply With Quote
Old 06-01-2023, 02:01 PM   #101
JTS
JTS's Avatar
Drives: 2023 ZL1 A10
Nice.. glad to here all is within the performance parameters.
2023 ZL1 A10 Shadow Gray Metallic
JTS is offline   Reply With Quote
Old 06-01-2023, 03:48 PM   #102
Idaho2018GTPremium
Go out and do a couple of the 60-100 mph splits I suggested previously. Let’s see where it’s really at and not just based on feel.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2007 MazdaSpeed3
1987 Camaro Z28
Old 06-01-2023, 04:59 PM   #103
Greg83
Yes, now that it’s broken-in and I know it’s data log is in parameters, I’ll have to learn how to use the onboard electronics and record some times.
Old 06-01-2023, 05:24 PM   #104
DangerZL1
Drives: 2023 Black ZL1 Auto
Glad there’s nothing wrong with your car. You’re fortunate to live reasonably close to a top notch tuner and builder.
Old 06-01-2023, 05:29 PM   #105
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Glad your ZL1 was okay and I figured it was. You just need to break the engine in more and it will improve with more miles.
Old 06-01-2023, 06:35 PM   #106
NicKey
NicKey's Avatar
Drives: Nickey Super Camaro
It is always nice to meet a fellow enthusiast and car guy. I too am happy for you that your car is opperating as it should. Post up some pictures for the membership to see, it is a good looking ZL1. Have fun and enjoy the car. Stop back for a visit when you are ready for some more power
NicKey is offline   Reply With Quote
Old 06-01-2023, 08:00 PM   #107
Greg83
Thanks Stefano!! I’ll definitely stop in again, maybe we’ll throw it on the dyno just to see… sounds like guys want to know the numbers.
Sometimes I LOVE the subtle Sharkskin color, other times I wish I would have gone with something flashier.
Old 06-01-2023, 08:10 PM   #108
Greg83
Would the onboard times be accurate considering my 19” ZLE spec tire height is about 1/2” shorter than the OEM 20’s? Does the onboard computer measure the cars speed via GPS or more likely the speedo speed?
Old 06-01-2023, 08:51 PM   #109
Vigilante375
Drives: 2018 Camaro ZL1
It may be a tad off at higher speeds. What I suggest is getting setting a trip with Google maps and see what the speed on it says vs your car speedo at 60 and up to 100.
Then record a couple of 60-100 pulls.
The speed in the PDR is based off what the speedo in the car says.
Old 06-14-2023, 07:40 PM   #110
Greg83
Another update!! Had the car up to Nickey Performance today for a couple dyno runs. Once again a special thanks to Matt and Stefano for taking car of me, they are awesome to work with!!! Turns out there is nothing wrong with the car, all the numbers came back “normal” for a stock ZL1. It came in at 578 WHP. I guess the tall gears in the M6 manual trans just make it seem to pull less aggressive than the previous A10 ZLE that I owned. Maybe I need to go back to an A10… Anyone with a low mile A10 ZL1 or ZLE looking for a M6 car???
Old 06-14-2023, 08:00 PM   #111
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Good to hear.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 06-14-2023, 09:09 PM   #112
Greg83
Originally Posted by Chrome383Z View Post
Good to hear.
Thank you!!!
