#99 |
Red Bull
Drives: 2017 Chevy ZL1 Join Date: Dec 2020
I just don’t want to end up needing to tune the car 2-3 times. What about a 10% lower and a DSX aux? Hoping that would help me keep the E content up. Or both of those and a standard blower port then tune and tcm tune. I would prefer to do the tuning 1 time.
#100 |
Well, you've got an opinion above that all you need is a lower (there are numerous % choices, I picked 10%) and a tune to make 700. I'll take his word for it, but a Kong, 10%, and LS FP should more than do it.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#101 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
The more boost you add the lower your E content will likely have to be, but that being said, you might still be able to run some E and make 700whp depending on pulley choice. You can however make 700whp on 93 octane though with your mods and a Kong ported blower and lower pulley.
#102 | |
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 01-03-2022 at 09:19 AM. |
#103 |
Red Bull
I don’t think that a 10% lower only will achieve my goal of 700. I think it will be in the 680 range. I could always use my 15% lower but I don’t want to add a ton of added heat and over spin the blower. Would my jms voltage booster be enough to hold E40-50 with 10% lower and a standard blower port? I feel those 2 together would get the job done and keep the heat under control for the most part.
#104 | |
#105 | |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
#106 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
If you do a cam and blower combo your looking at 800 on pump without trying too hard providing you have the right cam and combo. See JRE superstreet brawler package. That's no aux pumps, aux tanks, or meth just plain old reliable OEM intercooler system. You would have to tone down the boost to get down to 700 on E.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#107 |
Red Bull
Thanks Ted I definitely want no meth. So with a cam could you also run a lower and hit 700 tire and on some blend of 93/E85? Then maybe add the blower later down the line if it’s needed?
#108 | |
The torque is easy because you spin the blower faster, the HP is hard because the cam outflows the stock blower even when spun faster. But a blower cam combo is like magic, the struggles of making power disappear like Houdini.
#109 |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
Curious on the 700 RWH for the OP, are you planning on going with a wider tire? I'm looking at possibly adding more HP (first I have to receive delivery, of course) but I also want to make sure that I'm adding useful HP. I hate the idea of just adding HP to give myself a big number, as I think I'd probably go with a Hellcat if I was only concerned about big HP numbers. I want to make sure that I have enough tire/brakes for the boost in numbers, otherwise I'm just creating a tire shredding device. I hope that the 325s from a 1LE are at least a part of the discussion.
#110 | |
#111 | |
And just like most reviews of the ZL1 that start off with, "You won't win many bar room bets..." when compared to the "more potent" Mustang and Challenger, they always seem to give the nod to the Camaro over the other two when it comes to objective road racing. I suspect 700 RWHP may be the magic number with the current setup. |
#112 | |
