Old 03-22-2023, 09:15 AM   #99
S.Macias
Only6Cylinders
S.Macias's Avatar
Drives: 2016 Camaro V6 1LT
Wasn't feeling the semi-gloss powder coated black that came with the vents so I sanded and repainted to match the body.
Instagram: @smaciasracing
S.Macias is offline   Reply With Quote
Old 03-27-2023, 01:42 PM   #100
S.Macias
Only6Cylinders
S.Macias's Avatar
Took it autocrossing for the first time since the upgrades. Huge difference. One of the faster cars of the day.
Old 04-18-2023, 11:23 AM   #101
glw2023lt1/rs
Drives: 2023 camaro LT1/RS
Originally Posted by S.Macias View Post
Over time, the rear diffuser was fading to that ugly gray color. I decided it was time to paint it black to match the body. Overall, I'm happy with my $40 DIY results.
Last image is before and after.
looks real nice, what kind of prep work did you do, I know you cant make it smooth like the aftermarket type, also what paint did you use, and will the paint stick ok without any promoter thanks
glw2023lt1/rs is offline   Reply With Quote
Old 04-18-2023, 01:25 PM   #102
S.Macias
Only6Cylinders
S.Macias's Avatar
First I cleaned and wet sanded. Then I used two light coats of adhesion promoter. Used two coats of the duplicolor sandable primer in black. Then after the primer is dry do a coat of adhesion promoter. Then 4 coats of duplicolor universal gloss black paint. Let dry. Then 3 coats of the duplicolor acrylic lacquer clear coat (blue can with car, motorcycle, house, helmet on can). Took a out a day to do. Install the next day after everything sits for 24 hours
Old 04-25-2023, 11:44 AM   #103
S.Macias
Only6Cylinders
S.Macias's Avatar
New OEM struts and rear shocks paired with Eibach pro-kit lowering springs.
Old 05-04-2023, 05:30 PM   #104
S.Macias
Only6Cylinders
S.Macias's Avatar
Installed a new door check on the driver side. Man what a difference. Also decided to remove the wrap on the hood and wing. Doesn't look like it's in a primer stage anymore and makes it way more aggressive.
Old 05-08-2023, 12:26 AM   #105
S.Macias
Only6Cylinders
S.Macias's Avatar
Full detail last night, then did some autocross this morning and afternoon.
Old 05-10-2023, 03:14 PM   #106
S.Macias
Only6Cylinders
S.Macias's Avatar
Some of the more official photos from Sunday
Old 05-13-2023, 01:09 PM   #107
S.Macias
Only6Cylinders
S.Macias's Avatar
Installed the Shrader rear seat delete. Fairly easy. Pretty much 22 pounds of weight off.
Cloth bench: 17.9lb
Cloth Back: 11.3lb
Rear seatbelts (all pieces): 4.5lb
Total: 33.7lb
Shrader: 11.5lb
Difference: 22.2lb
Old 05-16-2023, 11:21 PM   #108
S.Macias
Only6Cylinders
S.Macias's Avatar
Installed BMR rear of rear cradle chassis brace
Old 05-23-2023, 04:56 PM   #109
S.Macias
Only6Cylinders
S.Macias's Avatar
Got my hands on practically new SS Brembo 4-Piston calipers, SS front rotors, SS dust shields and the SS stock brembo pads. Local guy was selling for cheap. Waiting on my Goodridge braided stainless steel front lines then getting it all installed. Switching from DOT 4 to the Motul 5.1 since it is a daily driven.
Old 05-25-2023, 05:51 PM   #110
S.Macias
Only6Cylinders
S.Macias's Avatar
Goodridge front stainless steel braided lines came in. Painted the calipers yellow to match what's currently on. Brembo stickers should be here in a few days. Install next Thursday (6/1). Then new fluid flush and 0W-40 oil (6/6)
Old 06-02-2023, 10:11 PM   #111
S.Macias
Only6Cylinders
S.Macias's Avatar
4 piston Brembos, braided steel lines, Motul 5.1 fluid.... All I can say is wow.
And for those interested in doing the same on your 2.0/3.6, all you need is the brembo calipers (caliper bolts are the same as the single piston stock calipers), a set of the 13.6" rotors, and likely new SS brake lines or a set of the stainless steel lines (I ordered mine for $75 from ZZP). Overall cost was a little under $700 including the Motul brake fluid and install with flush
Old 06-05-2023, 09:04 PM   #112
S.Macias
Only6Cylinders
S.Macias's Avatar
Front of rear cradle brace installed.
