#99 | |
![]() Drives: 2017 C7 GS M7 / 2017 Camaro SS 1LE Join Date: Dec 2016
Don't forget I need the dry sump version as it's a C7 GrandSport... |
#100 | |
#101 |
the curves are not similar, hard to believe these are similar engine builds. Did you check the torque tables et al? I'm not that great at tuning, but would agree air flow never lies.
I keep forgetting you have a Vette. Maybe it would be cheaper to build from scratch? You can do drop in rods / pistons, valves and a smaller cam. Pick the blower of your choice, the Camaro LT4 conversions are inexpensive. But HP is addicting and your engine may rapidly run out of head room with the LT4 setup.
#102 |
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I figured I would post up a airmass comparison I just did with some old data logs I had. I compared some airmass readings I had before I put my TSP stage 1/2 cam and TSP PRC ported heads on. I also globally multiplied each run by the corresponding "Air Density Engine Torque Multiplier". I understand this really isn't' what you're supposed to do given I am graphing air mass, but I did it more so since we are comparing one to one and trying to see power output as a result of increased/decreased airmass.
I am extremely unimpressed by my TSP cam/ported heads on my LT1. Yes I know there are a lot of other factors and I also have completely stock NPP exhaust and a ported stock intake manifold and throttle body, but my airmass is basically the same as it was before the cam at it moved way high up in the rpm range relative to my decently small cam (228/236, .635/.635, 114 LSA). Also oldman, do you have the dynosim software? I am really thinking about getting it, but as a engineer I feel guilty that I am not trying to develop the equations and calculate things myself haha |
#103 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
If you look at the OPs tune you can see there’s opportunity there
#104 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
cmitchell17, the stock NPP flows quite well. The ported stock IM/TB isn't killing you either, a ported MSD would just help up top and you might lose even more down low than you might have with the heads/cam. They typically shift your power up higher. Do you have before and after dyno runs?
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
#105 | |
#106 |
The stock exhaust from the cats forward is indeed limiting his setup. Mainly the factory cats. The factory NPP cat back is not.
The stock IM/TB even ported limits the potential of a stage 2-3 head cam combo. The only way I would stick with a Stock ported IM/TB is on a mild stage 1 H/C setup where shift points would be similar to stock(64-6500rpm). Other then that you need a intake that carries the power up top better and utilizes the cams potential. Good news is the LT2 looks like a cheap upgrade that will definitely carry power much better up top. The biggest mistake I have seen over the years and it applies to all GM small blocks is folks putting too large of a cam in the engine, not properly addressing the induction, exhaust, and not revving it high enough. Seen this for years on LS combos. Another big mistake I see with those doing heads/cam setups is leaving the stock compression. That is why you lose low end and mid range because you lost a lot of DCR from the bigger cams lack of efficiency down low...especially after you delete VVT. You need to raise the compression to get that back.
#107 | |
#108 |
Shifts under load
"Another big mistake I see with those doing heads/cam setups is leaving the stock compression. That is why you lose low end and mid range because you lost a lot of DCR from the bigger cams lack of efficiency down low...especially after you delete VVT. You need to raise the compression to get that back.". That is excellent information and advice that only guys who truly understand engine theory can explain and good shops should know. I remember Pray talking about this too. Didn't realize he had stock manifolds and cats, definitely not helping. Cam choice is super important and too many people bite off on big lift and duration. Futral got me on my LS1 back in the day.
#109 |
On my end I don't have stock cats and stuff...
- Ported MSD - Ported 95mm by Solers Performance - ARH 1-7/8 Headers and X pipe Even without raising compression the cam package should work fine, you see a lot of examples of totally decent numbers with stock compression. I decided to buy a full Katech Stage 2 engine and sell mine in parts. I know the engine Katech sells me makes 600HP/530 FtLbs on pump gas. It has a smaller camshaft ("Torquer LT1 cam") but it keeps VVT so it makes torque everywhere, which is the best for my application (Roadcourse and AutoX). I also believe more their experience as far as valvetrain than TSP, as they do extensive durability and studies with their spintron valve test cell. They also have real racing experience. I'm tired of spending so much time figuring out the issue...Having a peaky engine is fun in a way but not efficient enough for my use. |
#110 | ||
#111 |
Do they include a tune?
#112 | |
I'm sure Katech does (or at a least a way to address it), they are a top shelf engine builder. I used Rynne Cunningham for my remote tune (super good), many good tuners that are sponsors here also.
From post 81: Quote:
Make sure you tell then you want the Johnson lifter: https://store.katechengines.com/cams...-parts-c4.aspx I'm green with envy, wish I could afford something like a Katch engine in a C7 or 1LE....
