Old 01-10-2019, 06:09 PM   #99
Mark R
Drives: 2018 ZL-1
This seems like a lot of hassle mounting the catch can at the front.
I used the 2 piece bracket that mounts on the left strut tower and the CC fits just dandy. It's a real clean fit.
I did, however, have a friend weld the two pieces together, once I had them in the correct position, just so the bracket would not move once installed.
I'm very happy with the install, which I did according to this video:
Hope this helps.
Mark R.
Albuquerque, NM
Old 01-10-2019, 06:59 PM   #100
Alain
Alain's Avatar
Hope this helps.
Mark R.
Albuquerque, NM
I agree with you that this is turning into a shit show.
I didn’t realize this much customization was necessary to install this thing (the brass fitting and this bracket).
But, some of us don’t have a choice other than to mount the catch can in the front. We have coolant reservoirs in the area where you mounted yours.
Hopefully Elite will eventually come through for those of us who HAVE to mount it in the front.
2018 ZL1 1LE/Red hot
Old 01-12-2019, 11:15 AM   #101
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Sent you a PM to help you out.
Elite Engineering is offline   Reply With Quote
Old 01-12-2019, 06:44 PM   #102
02fbody35th
02fbody35th's Avatar
Drives: 2018 ZL1
Guys, don’t over think this. Everything you need to mount the can in front of the engine (or anywhere else you want) comes complete in the kit. I mounted mine in front of the engine with the standard bracket that elite sends. You just have to get a little creative and think outside of the box. All I did was take the bottom bolt out of the thermostat housing and replace it with a stud. That’s where I mounted my bracket. If you don’t have a stud you can simply just pull the bolt and sandwich the bracket between it. It’s a tight fit, and you might have to play with it a bit. But it will fit there. Check out my pics. Good luck. Also the bracket looks close to the belt in the pic. But trust me. There is a ton of room between the two.
02fbody35th is offline   Reply With Quote
Old 01-12-2019, 07:43 PM   #103
Alain
Alain's Avatar
Thank you for posting those pics fbody.
I briefly looked at mounting it on that same bottom bolt but it looked like the belt was gonna be in the way.
Like you said, it looks like there is enough room to clear. Didn’t look that way to me when I mocked it up. There’s no bouncing around of that belt in that area right? I guess that’s one of the job of the belt tensioner.
Gonna give it a second look when I have some free time.
Id still like to have the two piece bracket just in case for some reason mine doesn’t work out mounting it to the radiator.
Old 01-12-2019, 09:05 PM   #104
OVERPAR73
2018 Garnet Red ZL1 conve
OVERPAR73's Avatar
Drives: 2013 & 2018 ZL1 vert
Alain,
I also used that bottom thermostat bolt like shown above and like I said before I ground down the bracket a little so it wasn't so close to the belt. I also thought it was a little too close for my liking! I think I have another bracket coming from Elite so I can give the two mounting brackets a try. I sent them a picture of what I wanted and got a response from Steve at Elite so I'll see if anything comes in the mail this week. Glad my car is down for the winter and I also have a nicely heated garage to complete all these mods over the winter.
Bill
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
OVERPAR73 is offline   Reply With Quote
Old 01-12-2019, 09:15 PM   #105
02fbody35th
Drives: 2018 ZL1
The belt is close. But it’s got about 3/4” space. I don’t think it will bounce that much. But if it concerns you, you could alway grind the bracket down a little.
Old 01-12-2019, 10:49 PM   #106
Alain
Alain's Avatar
Originally Posted by OVERPAR73 View Post
Alain,
Bill
Thank you Bill. Unlike you, I don’t have a heated garage and it’s 29 degrees here in NJ so I’m grateful you are ao dilisgently keeping up with this.
What bracket is Elite sending you? The two piece bracket?
They sent me a PM about it, I responded but I haven’t heard back from them yet. I’m pleasantly surprised that they are helping us out in seeing this install through. I feel like most companies would have bailed on us in one way or another.
Let us know what you get from them this week.
Old 01-12-2019, 10:50 PM   #107
Alain
Alain's Avatar
I’ll probably end up grinding it. Thank you again for your pictures.
Old 01-13-2019, 02:05 PM   #108
Elite Engineering
Drives: 2010 Camaro
Thanks again for the pictures. This should work very well.
Old 01-13-2019, 04:46 PM   #109
02fbody35th
Drives: 2018 ZL1
Question for you guys that have the elite can installed. Is it normal for there to be a vacuum suction when removing the oil cap with the engine running? I noticed today if I opened the oil cap with the engine running there is some pretty serious vacuum on it. And the engine runs a little funny like there is a vacuum leak. Is this normal?
Old 01-14-2019, 06:47 PM   #110
OVERPAR73
OVERPAR73's Avatar
I have the second piece of the bracket on it's way. Will keep you all informed on the status and final install of the can.
Old 01-14-2019, 07:01 PM   #111
Alain
Alain's Avatar
Thank you Bill.
Hopefully I’ll get a 2 piece bracket as well.
Old 01-17-2019, 07:47 PM   #112
OVERPAR73
OVERPAR73's Avatar
Got my catch can in it's final position tonight. I went with my original position on the lower bolt of the thermostat housing. I tried the top bolt with the new bracket but it was to high and was hitting the rain deflector when I tried lower the hood. I also ground down the original bracket a little bit since it was so close to the belt.
