Go Back   CAMARO6 > Members Area > Past Camaro Fests > 2018 Camaro Fest (VIII)
Old 12-21-2017, 03:54 PM   #99
Tom And Cheryl
Tom And Cheryl's Avatar
Drives: 2013 SS Convertible, ThumperII
Last year I did test an tune, made 5 passes, on the 5th pass the car launched pretty hard, went to pull 2nd gear and the clutch pedal stayed on the floor, half-track after thinking I broke the car and how are we getting home, then pedal hit my foot (fluid issue I am sure) and the car was good. This year drag racing and car show, more racing than show. I learned a lot in a short amount of time It was well worth a little track time. Flushing the brake/ clutch fluid in spring.
Tom And Cheryl is offline   Reply With Quote
Old 12-21-2017, 04:18 PM   #100
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
More of a pressure plate issue more than anything. The pressure plate is the root cause on the pedal stick issue.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 12-21-2017, 04:24 PM   #101
Tom And Cheryl
The pressure plate got to hot, I was thinking fluid but I'll go with the pressure plate. This fest just going to spread things out to try to stay cooler.
Old 12-22-2017, 06:59 AM   #102
faSSteddie
faSSteddie's Avatar
Drives: 2013 Victory red/white stripes SS
Originally Posted by HRD_WRK View Post
_ That type also provides an advance notice from the countdown so one doesn't feel as rushed-again preferred by most.My last post was written for what is best for the masses-which at this event is also about giving new drivers chances to race and enjoy it. There's not as much satisfaction(turns to frustration for some) if they try it out and Red light often. It's better to lose other ways than to go out on Red.
Frustration from redlighting happens only when you redlight, feeling rushed by the pro tree happens every pass whether you redlight or not.( and that says nothing to the extreme frustration with the added possibility of feeling rushed by the pro tree AND redlighting) I feel that novices and newbies have a tendency to leave late, as they are waiting to actually see the green bulb light up,
faSSteddie is offline   Reply With Quote
Old 12-22-2017, 07:42 AM   #103
Tom And Cheryl
Put ThumperII on the list for the stock SS V8 list
Old 12-22-2017, 08:16 AM   #104
RubyCamaro
Jan
RubyCamaro's Avatar
There is a reason they call it the PRO tree. Just sayin'.
Old 12-22-2017, 08:30 AM   #105
vja 2014 zl1
Drives: 2018 Triple Black ZL1 A10
I did some drag racing a motorcycle 40 years ago, all with a sportsman tree. The first time with a pro tree was at the last fest and it took a couple of passes to get used to it(not good at it but ready for it). The main thing I learned is "Get all your ducks in a row BEFORE you stage.
vja 2014 zl1 is offline   Reply With Quote
Old 12-22-2017, 10:59 AM   #106
Lafourche1
Drives: 2019 CLA 450 Mercedes
No reason not to jump in your respective class. You can still just treat it as a test and tune run.
More the merrier!!!
OK - Count me IN. Stock SS with 6M
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red
2014 Lincoln MKT EcoBoost (The Bus)
Lafourche1 is offline   Reply With Quote
Old 12-22-2017, 12:11 PM   #107
Bo White
Bo White's Avatar
When you stage up weither its pro tree or sportsman your supposed to be ready to race. Its like the batters box, dont step in unless your ready for that ball.
Totalled:
Old 12-22-2017, 12:17 PM   #108
True, or stage 1st if you want extra time.
Old 12-22-2017, 12:55 PM   #109
faSSteddie
faSSteddie's Avatar
Bo, you know that is not entirely true, trying to deep stage as well as smoothly bringing the engine rpm up to the desired point, both happen after the staging lights are lit. So unless you shallow stage and leave the line off idle, this is not really the case.
Maybe I would, if I was not so busy trying to steer around the unnecessarily large waterbox seeing how I am running normal street radials.
Old 12-22-2017, 12:57 PM   #110
Bo White
Bo White's Avatar
Pre stage is there for you to get ready. Once the stage beams come on your there to drag race. I see people deep stage all the time on a pro tree.
Totalled:
Old 12-22-2017, 12:59 PM   #111
Bo White
Bo White's Avatar
For those that have little to no experience at drag racing that would like to learn more I along with others in the modified class will gladly help and show pointers and procedures. This is part of the fun of going to these events. Everyone has to start somewhere.
Totalled:
Old 12-22-2017, 02:49 PM   #112
Ace0751
GEN5 Detail
Ace0751's Avatar
Drives: 2011 Synergy Series 2SS Convertible
Wow this is getting thrown out of proportion a little to much. This is meant to have fun pro tree or sportsman tree whether you’re a rookie or not. Most want to just go down the strip to see what time they get and go from there (look at the drag racing threads). RT and ET starting coming in after the persons know what there car can do and how to better it. Some do go heads up with friends while others work on there RT or 60’ etc. The tree to most is not a concern at first.
I like either and will adjust accordingly to what is given, not complain because they are using something different. I like hanks idea though, random tree that sucker lol.
Roto-Fab CAI, Borla ATAK Exhaust System, Stainless Power Headers, RX Performance Catch Can, ACS T4 Splitter, Oracle side markers, Dyno Tuned by RDP Motorsports
Ace0751 is offline   Reply With Quote
