#99 | |
![]() Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR Join Date: Aug 2018
Please Pleas PLEASE say that the 18" will come in matte bronze, or whatever that color is.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track |
#100 |
![]() Drives: 2018 ZLE Join Date: Mar 2020
When will the arc8 pre order matte bronze start shipping?
#101 |
![]() Drives: 2017 Camaro SS 1LE Join Date: Jul 2020
Arc-8 in Satin Black
19x10 ET20 with Goodyear Eagle F1 SC3's 295/30/19 19x11 ET43 with Goodyear Eagle F1 SC3's 325/30/19 |
#102 |
![]() Drives: 2017 SS 1LE Join Date: Jun 2017
#103 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
That's good news! For a given size, what's the approx. weight difference between ARC-8 and SM-10? Are you planning to implement any other styles in Camaro specific fitments?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#104 | |
![]() ![]() ![]() Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
+1, I have always liked the look on all the BMW's at the track
+1, looking forward to the production release Quote:
Approximate ETA till they're available???
#105 |
![]() Drives: F-Series Canyonero Join Date: Nov 2020
#106 |
![]() ![]() Drives: Camaro Z28 Join Date: Jan 2017
Production is scheduled to start in about two weeks and we will be launching a Group Buy on them in early/mid January. Pricing and finish options will be finalized then, but Satin Black and Anthracite will be offered for sure. Will be crunching the numbers to see if we can sneak a third option in the first batch.
- Cory
JJ - Fitment Specialist /// Forged Wheels /// Wheels For Your Camaro
Camaro Wheel & Tire Fitment Guides /// Defining Real Performance /// Camaro Wheel Gallery expert@apexwheels.com |
#107 | |
18x11" ET7 - front only 18x11" ET35 - rear, or front with 26mm spacer 18x12" ET41 - rear only 19" 19x10" ET20 - front/rear 19x11" ET11 - front only 19x11" ET35 - rear, or front with 26mm spacer 19x12" ET41 - rear only All will have the direct fit center bore and knurled beads! Not to mention 18" will clear the ZL1 brakes and Z/28 Carbon too.
Camaro Wheel & Tire Fitment Guides /// Defining Real Performance /// Camaro Wheel Gallery expert@apexwheels.com Last edited by Apex Wheels; 12-08-2020 at 06:57 PM. |
#108 | |
![]() Drives: 2018 ZLE Join Date: Jul 2014
#109 |
Checkout our Customer Dave's #7 of 24 Hertz-Hendrick Motorsports Camaro ZL1 1LE rocking a set of APEX ARC-8 wheels!
APEX Wheel Fitment Specs:
Owner's Instagram
#110 |
Yes of course! All will clear the ZL1 brake setups, along with pretty much any aftermarket kit out there as well.
#111 |
![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
On the 18's Cory, you may want to remind them that they may have to grind off a small portion of the steering knuckle for proper clearance on the fronts but that MAY NOT be an issue if you are using camaro offsets instead of BMW offsets on the CURRENT SM-10 wheels that are NOT Camaro Specific.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 12-09-2020 at 10:52 AM. |
#112 |
![]() Drives: 2017 SS 1LE Join Date: Jan 2018
Please tell me we can get them in bronze.
