#99 | |
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
#100 |
Cool, maybe I'll be there one day....lol. I work on the car, do laundry, cut grass, sweep carpet, dust...etc...work on car......you get the picture. OH and lets not forget, decode Whipples instructions. I'm turning it over to CIA, Maybe they can make sense out of it......
#101 |
Brett, no shame in taking your time with it.. keep it fun and not a chore. Heck I took over a month to do all of mine haha. I can say pro charger sends pretty good instructions with their kit.
#102 | |
The guy that put those "DESTRUCTIONS" together should have his crayons taken away from him and time out in the corner. |
#103 | |
![]() ![]() ![]() Drives: 2018 ZL1 Join Date: Oct 2011
2018 ZL1…Many mods to come
#104 | |
#105 |
#106 |
Two steps forward, on step back....Damn it. Went out to the garage, looked at the motor, looked at all hoses (were they go) check length and connections......BAM.
I never use other ppl stuff, I always Custom make and fit stuff, Why is this any different? All back to gather, coolant filled. Wanted to fire to CK for leaks and wash lower plates out from Trans line recall.....GD it, harness WILL NOT work. I was so wanting to start and run with stock MAP. Then jack it up (block) pull the nose, and install coolers, tank, electric AND headers. Tomorrow is another day. SIDE NOTE: some hoses are TO long for a clean, PRO look. Don't be afraid to cut them (and cut the mesh) You can zip tie, tape, or Shrink wrap (like I did) Last edited by brettman; 05-12-2017 at 06:36 AM. |
#107 |
To clarify, Whipple & some members stated to install MAP in forward (unused) port (caped) The harness and sensor (OEM) is 3 pin. The CTS (included) sensor is 4 pin. Do the math, and the mount distance. I DO NOT possess a wire stretcher. I don't even know where to buy one. I'll end up cutting and extending wires to run for dyno/tune. I hate chopping a harness up. So when I'm done, I'll buy connector and plugs to make it right. PAIN IN MY A??.
#108 |
I just bought a 24" MAP extension. That will work the best. Drive to Dyno, unplug Stock MAP, plug in 3Bar, done (and untouched harness) Sometimes you just have to walk away and re-think it.
#109 |
I'm guessing that it will run like crap without the tune. How far do you have to drive?
#110 |
#111 |
![]() Drives: . Join Date: Jan 2017
Gluck Brett. I finally got an activation key to try and load the Whipple tune tomorrow morning. Still dont really understand this "credit" thing.
#112 | |
Are you going to just run that, OR dyno/tune?? WE all know more work to come...lol. We are HP junkies.....But it's legal....LOL. Credit?? mine is 835, last check, your credit I don't get it either.....LMFAO. It's all good brother, learn, have fun, enjoy, thats what I do. MAP wire will be here Weds. I've decided to send out Header job. Way to much going on....AND I'M F-ing RETIRED. Couple more days for me and I'll make some noise (I hate my neighbors) Lazy S.O.B.S. |
