#99 | ||
![]() ![]() ![]() ![]() ![]() Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
![]() Quote:
![]() http://www.camaro6.com/forums/showpo...8&postcount=69
#100 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS Join Date: Dec 2009
What size is the bolt head for the rotor to rotor hat?
Orange Krush II
#101 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I checked my Gen 5 ZL1 2 piece rotors, 8mm socket for both the nut and bolt.
"KEEP THE FAITH"-Fbodfather |
#102 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
Anyone have a good method for getting enough torque on the caliper-knuckle bolts to loosen and tighten them? I saw it's 140 ft-lbs. Seems tough to torque that much in the constrained wheel well on jack stands. I don't think my wrench would even fit.
#103 | |
![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS 1LE Join Date: Feb 2017
For the J6M brakes the caliper-knuckle bolts are: First Pass: 150 N-m (111 lb ft) Final Pass: 15-30 degrees and they have red thread locker on them or the dry factory equivalent |
#104 |
1LE Convert
Two foot breaker sounds like a lift is needed then. Or the impact
#105 |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
glamcem, Provoste, anyone...
Can someone confirm the part number I have for the front caliper bolt? 11547494 Thanks!
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#106 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Matthew look up Cem's build thread in his sig. You may find it there.
#107 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
#108 | |
I’m adding it to the ‘brake pad’ thread that is stickied.
2017 HBM SS 1LE
#109 |
![]() Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
So will these fit our cars with the 6 Pistons Brembo’s https://www.tirerack.com/brakes/brak...oModClar=Coupe
? They seem to have the same part number but include the hats. |
#110 |
![]() Drives: 17 SW 1LE Join Date: Jun 2017
C7Z rotors should fit, you just ditch the hats.
#111 |
Those that have ran the DBA T3 5000 front rotor rings, are they better than stock? After 14 track days I think my fronts are done.
New stock rings with hat are $329 from Rock Auto DBA T3 5000 rotor rings are $355 from KNS Brakes What about the rears, stay with stock? |
#112 |
I'm now getting vibrations during braking with these. I can feel grooves and cracks with my fingernail
