#99 |
![]() Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
Hijack = anyone heard of or have experience with a lightweight flywheel? The stock one must weigh 10 lbs.
#100 | |
TPW 4-11
Drives: 2016 Camaro 2SS Conv. MRC M6 Npp Join Date: Mar 2016
Norm |
#101 |
![]() Drives: 2017 2SS Join Date: Apr 2016
I had some strange hesitation recently around 5,000 RPM so I decided to check out my 2017 A8 today. I was at WOT and the engine hit about 5K RPM, lost 500PRM pretty quickly, then suddenly went back up until it approached redline and shifted as normal. It did this several times. I was at freeway speed then went WOT a few times. It's also worth noting I had almost all accessories on and I was in track mode. I had AC going, radio on with Iphone plugged in, and the heated steering wheel.
It does not look like I have any issues with this wiring harness. My build was 6/8/2016. Model is 2SS, A8, MRC, NPP. There is a bracket surrounding this wiring harness that seems to be causing the trouble. All other wiring harnesses are secured out of the way of the belt. The pics did not come out as well as I had hoped but I am pretty sure the wiring harness is OK here. I will have to monitor the performance to see if this issue happens again.
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
#102 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
#103 | |
#104 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Camaro 2SS A8 Join Date: Jan 2015
Sent from my SM-G950U using Tapatalk
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#105 |
I think it was about 50-55F out. I like to use my heated wheel during all weather conditions. The thin steering wheel makes my hand cramp on long drives and the heated wheel helps a bit.
#106 |
![]() ![]() ![]() ![]() ![]() Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
Good point, I neglected to mention that the best way to test is to turn off those as it may mimic the hesitation issues .
#107 | |
#108 |
TPW 4-11
GP86 your 2017 car pic is the same as my car with that wire bracket, the OP car was not wire routed that way, newer builds ? why change what was working?
anyway doesn't sound like you have the same problem Good luck finding what is up.
Norm |
#109 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Can you point out in a picture which wire bracket you're talking about that's on 16s, but not on 17s? The bracket that I thought you were talking about appears to be on both.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#110 |
TPW 4-11
Look at the pics in post 100, at the bottom of belt the wires are about 3" below belt, the bracket above it next to block holds the wires out of the way. Now look at post 96 pics and the wires are being rubbed on by the belt, they seem to be routed differently
I guess they both have a bracket but wires are not routed the same
NormLast edited by checkeredflag; 05-12-2017 at 12:41 AM. |
#111 |
![]() Drives: 2019 Camaro ZL1 Join Date: May 2017
Add my car to the list. It caused my car to malfunction so much that I had to have it towed. Shame on GM!
2017 1SS A8 |
#112 |
since the front end clunk (loose end links) still exists on the '18s, I wanted to bump this so the new owners can check this as well
