Old 10-17-2019, 01:54 PM   #99
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
I gonna use deez and not worry about crushing shit, the dealer already crushed the steel part.
ssmofo is offline   Reply With Quote
Old 01-21-2020, 12:56 AM   #100
KirkH
Originally Posted by winter568 View Post
QuickJacks make life easy and they are worth it for safety.
What model QuickJack do you have?
Thanks!
Old 01-21-2020, 09:05 AM   #101
Magnum922
Magnum922's Avatar
Drives: 2017 Camaro 2SS, A8
Here's the dealer jack point from my last visit that I saw. This time they used the front aluminum arms instead of the steel, which you can see the rubber puck Mark's on. Havnt had any damage yet. I did buy the lift add on I am going to put on this summer.
Magnum922 is offline   Reply With Quote
Old 01-21-2020, 10:56 AM   #102
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Jacking by the aluminum shear plate is asking for trouble. It's pretty thin aluminum and doesn't seem suitable to me for jacking purposes, but I guess they've dispersed the load over that puck so you might be OK. if you try that jacking just from the front corners alone, I think that will buckle.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 02-23-2020, 02:29 AM   #103
LSA
Drives: Fast
Are you using the quickjack pinch weld blocks? Can you get a close up of how whatever pad or block you’re using sits against the bottom of the car?
LSA is offline   Reply With Quote
Old 02-23-2020, 08:04 AM   #104
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
I've moved on from the jack stand dance and picked up a Quickjack from Home Depot for $1100. Ordered the BL-5000 EXT then called and canceled the order and got the BL-5000SLX, I think the standard one will be more flexible on other vehicles and also weighs less. With the money I saved I picked up the extension kit to turn it into an EXT, and the SUV kit for the truck. The standard one will pick up the Camaro fine with the rearmost front pad, I use the aluminum clamp on lift points in all three positions. I purchased pinch weld rubber blocks but ended up just using the standard blocks that came with the Quickjack. Very pleased with it so far. [IMG][/IMG]
Warrior102 is offline   Reply With Quote
Old 02-23-2020, 07:27 PM   #105
rocknss
rocknss's Avatar
Drives: 2017 50th Anniversary Camaro SS
I'm glad I don't drive my Camaro in the winter because the cars that are those pinch welds will be rusted so bad you won't be able to jack up the car using them.
2017 50th Anniversary Camaro 2SS
2016 Chevy Malibu LT (wife's car)
2004 Chevy Impala (winter car)
2001 Chevy Camaro SS (sold)
1969 Chevy Suburban (restoration project)
rocknss is offline   Reply With Quote
