Old 10-01-2017, 08:41 PM   #99
Rocketsled
Drives: 2018 Camaro 2SS Black A8 NPP Nav.
Mine just started doing this at 1000 miles. I made an appointment for Tuesday. Ugh! One would think by now word would have reached the production line about this issue.SMH
Rocketsled is offline   Reply With Quote
Old 10-01-2017, 10:50 PM   #100
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Thumbs down
Originally Posted by ScottMZ3 View Post
My new 2018 ZL1 with 402 miles just started making the clunk. Have an appointment on Wednesday morning to get the end links tightened. How is this still an issue on 2018s??
Confirmation that 2018's still have this issue.
What kind of company just says "Awe f - it!" to loose, clunking sway bars, year after year, unit after unit.
Disgusting
Even Louis Chevrolet is pissed off!
bbb
"Why are my sway bars still clunking?" LC
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 10-02-2017, 09:17 AM   #101
Rocketsled
Instead of waiting 'til Tuesday, I took the car in for service this morning. The tech said that the fix for this is to replace and retorque the end link nuts but they have no nuts in stock. So they put on locktite and torqued the nuts. The noise is gone though!!
Old 10-04-2017, 06:41 AM   #102
Childs Play
Pizza & Wings Only $12.99
Childs Play's Avatar
Drives: 2017 Camaro SS
I now seem to be having this issue as well. First noticed it about two months ago. Brought it to the dealership and they said I had a strut not seated properly. I mentioned the TSB for the sway bar but they didn't tighten them then. Went on my way and the noise was gone for about a week. Came back even worse after that.
Brought it into the same dealership and mentioned the TSB again. They didn't even acknowledge it. Said they didn't hear anything and gave me the car back.
Went to a different dealership yesterday first thing in the morning. They heard the noise and tightened the sway bars per the TSB. Was good after that until I hit a rough patch of road when going out for dinner later last night... I heard a slight tap sound when pulling back into the driveway that night.
Now the noise is back when pulling out of the driveway and over speed bumps this morning.
I also notice the sound slightly when starting from a stop at a red light.
I'm at a loss... Going to take it to one of the shops around here that are hopefully more competent than GM and have them check all/most of the suspension.
It's maddening...
Edit: I'm going to buy the nordlock washers and loctite. It looks like I could perform this myself. Maybe learn something during the process and not have to rely on GM to fix simple things that shouldn't be an issue in the first place.
H-Town Camaro Club
Past Rides:
2012 Camaro 2SS/RS M6
2012 Camaro ZL1 A6
2017 Camaro 2SS M6
Childs Play is offline   Reply With Quote
Old 10-04-2017, 10:31 AM   #103
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Originally Posted by Lt1z350 View Post
I just ordered the bmr sway bar links for mine and going to be done with it. 139.00 for piece of mind.
Have those been proven to fix the problem?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 10-04-2017, 04:38 PM   #104
ScottMZ3
ScottMZ3's Avatar
Drives: 2018 ZL1 A10, 2019 BMW X5
FYI, looks like there is an update to the service bulletin. They are now requiring replacement of the nuts instead of just re-torquing them as well as requiring locktight. I was told at the dealer today that it might be 1-2 weeks before the parts arrive because they are coming from a 3rd party vendor and not GM. Uhg. Perhaps these new nuts will prevent them from coming loose again though? The torque specs are also different than the previous bulletin. Here is a copy of the new bulletin (updated 09/15/17).
Its now PIC6276B:
2018 Nightfall Gray Metallic Camaro ZL1 - A10
Purchased 9/23/2017
ScottMZ3 is offline   Reply With Quote
Old 10-04-2017, 04:41 PM   #105
camaro5
camaro5's Avatar
It's maddening...
Excellent solution. Hey - GM - Nordlock washers! Be sure to use brake cleaner on all threads before loctite application.
Very cool part.
But know they are relying only on loctite and proper torque on a lock-nut to secure the fasteners.
Add Nordlock washers for better reliability.
BMR Suspension ELK017R
GM Sway Bar End Links for 2016-2017 Camaro
14. Insert the provided 10mm x 60mm bolt and washer into the
lower bushing of the end link and tighten using a 17mm wrench.
NOTE: Blue Loctite is recommended on this bolt.
Torque to 33 ft/lbs.
http://www.jegs.com/i/BMR-Suspension...gaAt3wEALw_wcB
http://www.jegs.com/InstallationInst...142-elk015.pdf
The new nut in the above posted bulletin P/N 11548382 MAY solve this too.
GM's paying 24 minutes of labor from get the car to park the car for this operation.
http://www.camaro6.com/forums/showpo...&postcount=108
nnnnnnnnnnn
STANDARD DISCLAIMER
Old 10-04-2017, 06:30 PM   #106
Childs Play
Its now PIC6276B:
Hmm. I just had them do the re-torque yesterday and it’s already making noise again. I doubt they did this one. :/
I wonder if I provided them the washers if they’d put them on... Probably not.
H-Town Camaro Club
Past Rides:
2012 Camaro ZL1 A6
2017 Camaro 2SS M6
Old 10-04-2017, 08:39 PM   #107
Stex
Drives: 67 goat, 69 goat ram air III
Damn, every GM, I do mean every GM I have bought since '90 have had major issues and slooooooow fix from GM. Wife's Honda/Acura's no problems. Hmmmm.
Stex is offline   Reply With Quote
Old 10-04-2017, 10:06 PM   #108
camaro5
camaro5's Avatar
nnnnnnnnnnn
They probably didn't give you new nuts.?. P/N 11548382 Of course GM paying techs 24 minutes total labor doesn't help either.
STANDARD DISCLAIMER
Old 10-04-2017, 10:13 PM   #109
Childs Play
According to the invoice I got it says they just retorqued them. I’ll probably call my service advisor and see it they’re aware of the updated TSB.
H-Town Camaro Club
Past Rides:
2012 Camaro ZL1 A6
2017 Camaro 2SS M6
Old 10-04-2017, 10:35 PM   #110
ScottMZ3
ScottMZ3's Avatar
I fixed my post from earlier. Not sure why my photos disappeared. You can see the TSB now.
Purchased 9/23/2017
Old 10-07-2017, 01:36 PM   #111
ScottMZ3
ScottMZ3's Avatar
Just had the new nuts installed this morning per the updated TSB. The clunk is gone! Now let’s hope it stays that way.
Such a relief to have that noise gone...was driving me bonkers on my new ZL1 with only 500 miles.
Purchased 9/23/2017
Old 10-08-2017, 08:25 AM   #112
Stex
This is crap GM. At least GM could do is tell us what happen?? Bad supplier stuff, assembly line mess up or total incompetence from GM on design and testing. Or worse yet, let them go out with know problem while we work on a fix?
