#99 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I like my e-brake! It just takes a little time to get used to it, at least for me!
#100 | |
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
To other posts, electric park brakes absolutely are a safety feature. It's a much more efficient and robust backup braking system compared to the old manual systems. It can be setup to apply itself automatically in a ton of different parked scenarios (even when no one is in the car) and it'll have better control than a lever or pedal would if it's used to stop the car if the hydraulic brakes fail. It's probably even cheaper to use an electric park brake now that it's been developed, too. The motors and switches are readily available (seemingly moreso than manual calipers and mounting hardware at this point), wiring harnesses are cheaper and easier to adapt to multiple vehicles, assembly is less complex, and there's no special bracketry or trim that needs to be specifically designed and tested for a smaller quantity of vehicles.
2017 SS 1LE.
#101 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
Anyone know what will happen if PB is on and the battery dies? Anyway to release the brake?
#102 | ||
Hot Camaro
I did not state it should never be done,I stated that I would never let anyone do that (to my car). |
#103 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
i also really don’t like the electronic ebrake.
#104 | |
Drives: 2017 Super Sport Cam. Join Date: Feb 2018
Good question. Someone go out this weekend, apply parking brake then disconnect battery. Attempt to release brake. Please report back with your findings on this important test. Thank you.
