Old 04-15-2017, 12:26 AM   #99
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Originally Posted by 2SS 1LE View Post
I have different tire sizes than stock, 285s in the front.
But if you still want measurements I can take them.
On 19" or 20" wheels? I run 285's on a 19" wheel so would be curious of the measurements if that's your setup. Does it look like it sits any lower than before the install?
Eric SS is offline   Reply With Quote
Old 04-15-2017, 12:39 AM   #100
LSmith353
LSmith353's Avatar
Drives: 2015 Ultimate Track SS
If you measure from the center of the wheel to the highest part of the fender arch opening, that will show comparable ride height regardless of tire size.
I purchased all of the components of the kit separately less the springs and obviously the re-calibration. I also got the rear control arms and the strut tower brace. I actually ordered all of the hardware prior to learning of this lack of ability to re-program a 2016. I started the install today. I also had to finish putting together a QuickJack so only got the front done. I was so close to ordering the full kit. When I pieced it all out without the springs, it was only $650 with the tower brace. I figured if it was lacking, I could add the rest later. Guess I got lucky.....
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/
2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD
2010 2SS/RS M6 -- SOLD
LSmith353 is offline   Reply With Quote
Old 04-15-2017, 12:50 AM   #101
LSmith353
LSmith353's Avatar
Ha.... that remains to be seen. Other than taking off the back tires, I haven't even looked at the rear yet, so maybe not. If I don't do it, it probably won't happen unless I can get it to Houston or Dallas. No one around here is trustworty.
Old 04-15-2017, 08:55 AM   #102
F1FTY
Drives: 2018 ZL1
The cradle needs to be dropped for the busings
Which bushings and what cradle?
I have the strut tops for the front in my kit but no bushings?
F1FTY is offline   Reply With Quote
Old 04-15-2017, 10:21 AM   #103
LSmith353
LSmith353's Avatar
He is referring to the rear control arms I purchased in addition to the sway bars and control links that come in the kit....
Old 04-15-2017, 05:01 PM   #104
LSmith353
LSmith353's Avatar
I should have said "trailing arms".... Cradle does not have to be dropped. Here is the kit I bought. http://www.thatgmpartsguy.com/suspen...it?parent=1034
Old 04-15-2017, 05:51 PM   #105
F1FTY
Drives: 2018 ZL1
Yeah I have those and the 1LE kit and was wondering what he meant haha
Thanks for clearing it up
Old 04-15-2017, 07:01 PM   #106
NewCamaroOrder
Drives: 2017 Camaro 2SS Nightfall Gray 1LE
Update, they finally finished my car! It took them until 6:00 PM on the final day to get everything wrapped up but they did.
Apparently, they have to get a "BCI" code from GM corporate before they can flash the suspension controller. The guy was telling me that they have to provide a reason for the re-flash. Which I don't get. They sell the suspension upgrade package that includes the re-flash, why would you need to provide a reason?
Whatever, its done and it drives like it should have from day 1. You can actually apply the loud peddle exiting a turn with some anger and it just squats down and goes. Before if you did that it was spin followed by traction control intervention. When I'm just driving it doesn't feel much different. Its not until you start trying to apply some of the power that you really start to notice the difference. But it is night and day when trying to go fast.
I'll try to get new measurements and post a before and after comparison table in the next few days. The holiday is cutting intro my free time, dame rabbit!
NewCamaroOrder is offline   Reply With Quote
Old 04-17-2017, 06:31 PM   #107
F1FTY
Drives: 2018 ZL1
Quoted $760 to do full install, reflash of shocks and an alignment. Told me it would take an entire weekday. Next month!
Old 04-18-2017, 09:36 AM   #108
Calcanuck
Drives: 2017 Hyper Blue 2SS
What are you running for wheels and tires? I am wondering how the upgrade would behave on the stock 2SS wheels and tires.
Thanks.
Calcanuck is offline   Reply With Quote
Old 04-18-2017, 03:21 PM   #109
NewCamaroOrder
I was all stock 2SS until this upgrade. I have just over 2,000 miles on her and still running stock rims and tires.
The car has a lot less body roll. It just squats down and goes.
I'm waiting a couple days before I take after measurements. I want to let the car settle if its going to.
Old 04-18-2017, 03:27 PM   #110
NewCamaroOrder
You might ask if they have ever done this upgrade before. They told me 1 day and it took all of 3 days to get it back. They said they had 14 hours labor in it. I told them now that your guy is trained I'll bet he does it in 7 hours next time.
I'm just saying because they were supremely confident until 3/4 of the way through the 1st day. Then the truth came out that it was their first time doing this upgrade and they wanted to take their time and get it right, which part of me appreciated.
I had to tell their guy to make sure and grease the new rear control arm bushing otherwise it would squeak like hell. He thanked me for the tip. I thought any mechanic should know that but whatever.
Old 04-18-2017, 03:49 PM   #111
F1FTY
Drives: 2018 ZL1
Yeah it would be their first install of the kit so I do appreciate them contacting GM to get the procedure known but you're right, who knows what the tech will do first time out. Unfortunately, to keep warranty, I don't have a choice.
Old 04-18-2017, 05:16 PM   #112
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
I really wanted to do this originally but decided to pass, at least for now. It would just be wasted money (and added weight) since I've got drag radials on in back.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
