Old 09-27-2016, 12:59 AM   #99
Its_LouieV
Drives: 2016 Black 2LT/A8/RS/NPP
Originally Posted by DetCam View Post
Here are the pictures of the 18" Steelies on my 1SS
It is bolted on and does spin.
First one: Note only a few mm clearance to caliper.
Rear clearance: Only a finger and a half fits behind
Top Down view
So depending on your level of comfort, steelies with spacers might work. Personally, I wasn't comfortable, so I coughed up the cash for a new set of 18's.
Thanks for doing this research, Still new to this, do you think those steelies would fit on a 2LT RS without brembos?
Its_LouieV is offline   Reply With Quote
Old 09-27-2016, 06:51 AM   #100
Shasta McNasty
Drives: 2016 1LT V6 M6
I just posted something on this:
http://www.camaro6.com/forums/showpo...5&postcount=56
Short answer: you would be able to bolt them up but I doubt you would like the result unless you also used 25mm spacers.
Shasta McNasty is offline   Reply With Quote
Old 09-27-2016, 03:47 PM   #101
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
We have lots of winter wheel options. Please contact me if I can help you place an order or if you have questions. I have been selling winter set ups on these cars from 2010 on and know what works well for these cars.
Rudy@Tirerack is offline   Reply With Quote
Old 11-16-2022, 10:54 AM   #102
Andy2002a
Drives: n/a
For anyone else trying to run steel wheels here's what I did:
- 4 Camaro steelies from FB marketplace (Look on FB marketplace, mine were $100)
- 2x5mm spacer
- 2x3mm spacer
- TPMS sensors + Tool off Amazon (~$60 + $10)
245/50R18 Snow tires (225/55R18 will also work, 235/50R18 will be slightly smaller)
Mounting the wheels at the front it tight so I went with a 3mm spacer(2mm should work too but 3mm was easier to find).
without spacer:
Front struct clearance is fine:
For the rear you must run a 5mm spacer otherwise the caliper will get damaged. I've driven the car for over a month now and I haven't had any issues with rubbing.
Andy2002a is offline   Reply With Quote
