Old 09-15-2015, 01:20 PM   #99
ilirg
ilirg's Avatar
Drives: 2011 Camaro 2ss
We still have this to look forward too
ilirg is offline   Reply With Quote
Old 09-15-2015, 01:21 PM   #100
SS22
SS22's Avatar
Drives: 2010 Blue Camaro RS
Since the bottom grill is SO big, what if the ZL1 differentiated itself visually by eliminating the top grill? The tri bar badge could be used instead of the bowtie and it would call back to the 3rd gen.
SS22 is offline   Reply With Quote
Old 09-15-2015, 01:27 PM   #101
Trans damm
Drives: Trans am
Can anyone tell if the writing on the side is the same on both sides? Also as others posted the numbers on the side don't really indicate anything because they all say "more" or "less then"
Trans damm is offline   Reply With Quote
Old 09-15-2015, 01:29 PM   #102
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
I can't put my finger on it, but this looks like something different that what we saw in the leftlane spy shots. Wheels are similar but tires are different (as is the gap). The hood just doesn't seem the same and I can't make my mind envision that front end under the black wrap on the other photos. It's probably just me going bonkers though.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 09-15-2015, 01:32 PM   #103
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
already discussed at length in thread.
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 09-15-2015, 01:33 PM   #104
EE7
Drives: New
This. I think we have two super Camaros on our hands.
EE7 is offline   Reply With Quote
Old 09-15-2015, 01:35 PM   #105
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
My guess... We're looking at a Z/28 and not a ZL1. The motor underneath is a bigger badder motor not seen in the Vette or the Cadillac. it is also sporting the flow tie which was developed for the Z/28 to squeeze out that much more performance.
The ZL1 while an HP model is not meant to break records on the track, regardless if it will or will not. The Z/28 is the track monster and is 100% focused on that.
This is also not the same car we have seen before in heavy camo. That had a more ZL1 style hood setup (from what we could see).
My guess... Both the ZL1 and Z/28 are in the process of getting tested. GM is aiming to take on the GT350R and the Z/28 is now the lead HP car coming first or maybe even along side the ZL1.
GM will position the ZL1 as the luxury Camaro with a Super Charger that will most likely be slightly cheaper than the Z/28 just like last time. It will continue to bill the Z/28 as a track car and will throw crazy racing specific bells and whistles on it.
Keep in mind the Z06 is basically one of the fastest track cars in the world. The Z/28 will end up right behind it if not a bit further back. The ZL1 will follow these two. I honestly see it like this.
SS Coupe
Camaro SS
Corvette Stingray Z51
Camaro ZL1
Camaro Z/28
Corvette Z06
I see GM moving forward with a potential new 427 or even the same 427 in the current Z/28 on the lighter 2016 platform to secure the lead once again over the GT350R.
Just my 2 cents.
Sledgehammer70 is offline   Reply With Quote
Old 09-15-2015, 01:35 PM   #106
GretchenGotGrowl
Could be different parts on the same model as they were testing things out, but it has been bugging me all morning...something tells me this one is different.
Old 09-15-2015, 01:37 PM   #107
mcsoul
Drives: Want a gen 6
My guess is that Z/28 will absorb the ZL1 kind of like how the Z06 absorbed the ZR1.
So we will get a full interior supercharged z28 that tracks very well and no stripped out track special on coil overs.
mcsoul is offline   Reply With Quote
Old 09-15-2015, 01:37 PM   #108
Trans damm
Drives: Trans am
Are these 5th Gen Zl1 rims?
Old 09-15-2015, 01:38 PM   #109
tpmotorsports
tpmotorsports's Avatar
Drives: Camaros
#HPSIX + Flow Tie leave little doubt we are looking at the 2017 Z/28. Since we know the weight will be about 3685, likely NA 570 HP...
Also anyone else pick up on the orange stripes? Are those tape or are they teasing us with orange paint revealed under the camo?
'17 ZO6 - Watkins Gray Metallic
'17 911 4GTS - Carmine Red
'17 Bolt - Hyper Blue
'02 SS - 35th Anniversary Ed. - 645 miles
'89 IROC Z - 2500 miles
'73 Z28 - Survivor 36k miles
'69 RS/SS 496 - 631 HP 618 TQ
'67 SS - Alum. 406 under construction
tpmotorsports is offline   Reply With Quote
Old 09-15-2015, 01:41 PM   #110
Trans damm
Drives: Trans am
It's been discussed if the writing on the left side of the car says the same thing as the right side of the car??? Don't see that.
Old 09-15-2015, 01:42 PM   #111
oklapike
oklapike's Avatar
Drives: 2012 45th Anniversary SS Coupe
Originally Posted by hotlapZL1 View Post
anyway, if it is real... I'm hoping its a 580 HP, 3,750 lb NA Z/28. A 640 HP LT4 at 4,134 lbs wouldn't be consistent with what they've shown in the SS
Honestly, I'm not sure your speculation on a 6th gen Z/28 is either; assuming, of course, that GM is even developing a NA Z/28.
a) I have trouble believing that GM would allow a 6th gen Z/28 to be heavier than the SS (if they can at all help it).
b) Based on the GT350, I'd guess GM is aiming for 530-550 hp (if the 6.46 on the car is a PWR target, GM might be looking at trying to trim 130-250 lbs from the SS).
Also, there's a rumor that the next ZL1 should be under 3900 lbs (I'm personally hoping for less than 3850). Think about the CTS: curb weight for the V6 RWD is 3745, curb weight for the CTS-V is 4145. If you add 400 lbs to the V6 Camaro curb weight, you'd get 3835 lbs (that'd be for the ZL1 auto).
oklapike is offline   Reply With Quote
Old 09-15-2015, 01:42 PM   #112
GretchenGotGrowl
The hash marks are taped on to help the driver know where the wheel centers are from the driving position.
