08-28-2017, 12:50 AM | #99 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
08-28-2017, 07:21 AM | #100 |
Drives: 2014 2SS/RS/1LE Join Date: Mar 2015
What is Dodge doing it on? The Hellcat engine is being shared between a few models, the Demon is only a one year run and its basically the Hellcat engine with some tweaks to it. Dodge did this to the Viper and they were losing money on it by not sharing any parts from it with any other vehicles. It was only a few years ago when they decided to put the V10 in their truck but it was a little too late by then. The GT350 and GT350R have the same engine, so in a way its being shared. If you want a unique engine for one model only, then the car would end up costing way too much and there probably wouldn't be a lot of them sold. Again it is not cost effective to do this.
08-28-2017, 07:24 AM | #101 |
Very true but they need to lose some weight in the Corvette's also. I know that's getting harder to do with all the electronics they keep adding to the cars.
08-28-2017, 08:55 AM | #102 | |
Drives: 2016 F150 Join Date: May 2014
08-28-2017, 09:29 AM | #103 |
The only part unique to the Z/28 was DSSVs...
08-28-2017, 09:59 AM | #104 |
08-28-2017, 10:04 AM | #105 | |
Drives: 21 Bronco Join Date: Jun 2012
Granted, Corvette is a pretty damn good place to pull parts from lol |
08-28-2017, 10:10 AM | #106 | |
The base engine is generally fine. My issue is that doesn't generally apply at the higher power levels. LSA to 5.8 Trinity, LS7 to 5.2 Voodoo, etc.
08-28-2017, 02:51 PM | #107 | |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
I'm sorry but the GT350's flat plane crank is no more unique than say a flat plane crank engined Ferrari or whatever, it's just bigger cubes and american made. Not at all unique on its own just slightly different. The goal at the end of the day is how to make effective power production for the given task. I give ford kudos for making it but I'm not sold that the voodoo will be a durable solution for reliability reasons and for all it's' so called uniqueness it barely beat the Z/28 with it's parts bin decade old engine at Laguna Seca and that was due more to the carbon fiber wheels, not the voodoo.
Swift....Silent....Deadly
08-28-2017, 06:27 PM | #108 | |
Drives: 2004 Pontiac Grand Prix Join Date: Oct 2010
08-28-2017, 07:01 PM | #109 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
I think the 6th gen z28 will feature the same weight loss strategy of the 5th gen z28, with carbon fiber wheels wrapped in ridiculously wide rubber added to match the gt350R. Carbon ceramic brakes would also be standard. Suspension would be carried over from the ZL1 1LE. Wishful thinking would put the weight of the car around 3,500 lbs, about 600lbs less than the Zl1. I believe the car will also have very aggressive aero to boot. The powertrain will most likely be some iteration of the current 6 speed, with an ELSD, 3.91 gears, all mated to an LT376/535 screamer. Or some version of it.
http://www.chevrolet.com/performance...ines/lt376-535 The car would be priced above the ZL1 1LE, as it would be the track monster with the faster time.
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! Last edited by soloknight6; 08-28-2017 at 07:19 PM. |
08-28-2017, 08:56 PM | #110 |
Life Is Short Enjoy It!
Drives: Original Owner 15 Z/28 #934 Join Date: Sep 2016
Well not exactly right - unless you feel like if they come from the GM parts bin they are not unique - but had a lot of changes from SS 1LE
See Attached from GM Marketing |
08-29-2017, 08:13 AM | #111 | |
Now last gen they said the Z/28 cant be supercharged. Well the only place they can pull engines from is Corvette. Top dog corvette right now has the LT4, most are assuming that the ZR1 Corvette will have an even more powerful supercharged engine. Also a no go for the Z/28. What Corvette does, Camaro must follow at least based on recent history. |
08-29-2017, 08:26 AM | #112 | |
