#99 |
![]() Drives: '17 1LT RS V6 6M NPP Join Date: Apr 2016
Make sure you turn off the stability control. I forgot to, and the car stopped me from spinning. Then I turned off the t/c and stability control and pulled a perfect 180. It was great.
#100 |
![]() Drives: 2017 Camaro 2LT-217CI Join Date: Aug 2015
nice
#101 |
Mack da M1SS1LE
Drives: 2017 Summit White 1SS 1LE Join Date: May 2015
Since we are all talking about winter duty in our Camaros, why don't we add some tips for undercarriage care? I have done some light searching of the interwebs to find out what we can do to protect our cars from the chemicals used to treat wintery roads. 1- Wash your car immediately after a snow storm. When I say immediately I mean when it is safe to do so and preferably once the temps climb above freezing. Use a car wash that has an undercarriage spray. This is by far the easiest solution. If you wouldn't dare take your car to a barbaric car wash, even if it is touchless, then you may need to go to a detail shop that can lift "your precious" and power wash the underneath. 2- Pre-treat your baby's bottom with a coating designed to act as a barrier between your car and the salt. This seems to be a bit on the extreme side to me but it will probably provide a good defense against corrosion if you can't manage to clean your car after the snow has fallen and melted away. I'm sure there are others who have even more answers than that and I encourage them to chime in. If I'm wrong on any of this just remember, I did a light search on the Googles for some info to pass on. Happy roading, can't wait for next summer.
#102 |
![]() Drives: Soon to be a Camaro Join Date: Oct 2016
Just my two cents but putting your car away for the winter is like buying a brand new expensive coffee maker but putting it away and not using it because it's not the season.
Coffee tastes good any day of any season ![]() Plus, these things have a life span and they will wear over time so why not enjoy it while it's still new and baby it when it's seen it's days in the sun 8-10 years from now |
#103 | |
Mack da M1SS1LE
THIS RIGHT HUR!!! ![]() ![]() ![]() ![]() |
#104 | |
I used to be Dragoneye...
+1 on the wash after a snow storm/salty roads idea...also yes, preferably after it warms above freezing. I don't believe in the undercoatings. There's already a layer of paint and primer under there. IMO, they don't do what they're advertised to...and make it difficult to service some things. ..but I do treat the undercarriage with steel wool, rust-fix, and black paint to take care of any nasty spots that form. I have extensive experience with maintaining boats, and constant touch up maintenance is just.....what you do. ![]() Also - prepare and plan to replace some things under there, long-term...bolts, control arms. At least I do...don't want a rust-compromised control arm on the car while doing a track-day in the summer!!! ![]() |
#105 | |
![]() Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS Join Date: Nov 2016
EVERY trip they make out here to plow and SAND (more like GRAVEL) they dump 6 tons of sand/gravel, road salt on that 13 miles. Occasionally they do that 2-3 times a day. Every time a car passes, you're hit with gravel. Not only damaging your windshield but your bodywork. We can not go through a winter with a daily driver without a WS replacement every summer. Once the snow/ice melts, we have TONS of gravel left on the roads until it's washed off by Spring rains or blown off the road by cars. The center portion of the road and each lane, will still have a line of gravel. I'll leave mine in the garage until the roads clear....getting your car damaged every trip out , somehow sucks the fun out of it for me. |
#106 | |
I literally cannot stand driving behind one of those gravel trucks even if they're only going 45 KM let alone have to deal with gravel on the ground. I guess country side has its pros and cons eh? Spirited driving in the hot weather while we're stuck in traffic but on the other hand we can drive it all year round without too much substantial wear and tear whereas you guys put the beast in hibernation ![]() |
#107 | |
![]() ![]() ![]() Drives: 2016 SS Convertible Join Date: Sep 2016
#108 | |
Worth it though, for the freedom to truly experience what our cars have to offer , when we have good road conditions. |
#109 |
Drives: 16 2SS NPP MRC Join Date: Aug 2016
Haven't sorted out my winter tires yet... Drove right into a snow storm last night... Was 25 minutes from home when i pulled into the gym parking lot and i could see the start of a flurry. 30 minutes later it was a blizzard... Those summer tires tried there best but i ended up back in the parking lot and calling for a ride...
I got 180 lbs worth of gravel in 2 large tupperware buckets in my trunk for some weight and tires next week. I love the snow! But i need to get this sorted asap i don't like ditching my car in parking lots... |
#110 |
Envy
Drives: 2011 SGM 2SS/RS - Black hood/hockey Join Date: Aug 2011
How the hell do so many people not have a garage? :(
#111 |
Mack da M1SS1LE
#112 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Challenger SP Shaker/Arcadia Denali Join Date: Jan 2016
The rock salt trucks just dropped so much down on the streets in my area that you can do a 180 with no issue even before the snow comes!!!
Tags |
snow, snow tires |
