Old 11-10-2021, 07:59 PM   #11033
hotlap
hotlap's Avatar
Originally Posted by jamala00 View Post
Hmmm... I wonder if those are a little different? When I look at the GM Accessory site I see different part numbers and the parts seem to physically look different.
https://www.gmpartsdirect.com/oem-pa...nsion-84116168
I think I see the difference. I posted the gen2 splitter and skirts that came with the 19+. Your number is the earlier style.
I wouldn’t be surprised if GM doesn’t stock any of this stuff to support them after production ends. I believe I saw that the 16-18 dark taillights are no longer available
Ronald Reagan -
Old 11-11-2021, 05:59 AM   #11034
Chevelle vs Camaro
Chevelle vs Camaro's Avatar
Drives: 2018 Camaro SS
Washed and added a Layer of Kamkaze OverCoat and then topped it with Polish Angel Cosmic Spritz
Chevelle vs Camaro is offline   Reply With Quote
Old 11-11-2021, 06:35 AM   #11035
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
Ahhh, Ya, ok that makes sense. I'll have to see if I can see a 19+ with them on. Actually I'm pretty sure that is what the neighbor has. I'll have to stop in by him.
jamala00 is offline   Reply With Quote
Old 11-11-2021, 06:39 AM   #11036
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
Here ya go!!!
Nothing like an SS is offline   Reply With Quote
Old 11-11-2021, 06:42 AM   #11037
jamala00
jamala00's Avatar
Originally Posted by Nothing like an SS View Post
Here ya go!!!
Thanks...! It looks like they don't stick out quite as far as the older style. I like that. Do you have the new style front splitter on there too? If so can you post of pic of that?
Old 11-11-2021, 06:44 AM   #11038
Nothing like an SS
Faster!!!
Yes, it is a 1LE, so splitter was factory, I only added the skirts. This is before I installed the skirts
Old 11-11-2021, 06:54 AM   #11039
Nothing like an SS
Faster!!!
Although, due to a mishap, I did replace the splitter! lol
Old 11-11-2021, 06:58 AM   #11040
jamala00
jamala00's Avatar
$hit happens right..! LOL
So I like the newer side skirts better, but I do like the older front splitter better. Not that I don't like the newer one, just like the older one better. It's not as "pointy". (If that is the right description) The older one seems to have smoother edges.
Old 11-11-2021, 07:23 AM   #11041
I prefer the original ZL1 style side skirts, they offer much more protection and don't have the "channel" in the rear that seems to direct airflow and rocks right onto the rockers.
Old 11-11-2021, 07:31 AM   #11042
Thinking about our potentially bleak Camaro future, I splurged on an ultra fancy scan tool (see here). It works pretty well with the car, plus it has a ton of special functions such as ABS bleeding and TPMS reset and many more. Coincidentally, I discovered that I had stored codes for weak key fob batteries, so I guess it may be time to replace them after 3.5 years.
Old 11-11-2021, 08:11 AM   #11043
jamala00
jamala00's Avatar
Ahh, I see what you mean, ya I can see that happening in the other ones.
Old 11-11-2021, 12:00 PM   #11044
willzilla
D3RPZILLA
willzilla's Avatar
Drives: 2021 Camaro ZL1 a10
Installed the BMR Suspension driveshaft safety loop (not really needed for my application but had exhaust off for the Borla ATAK exhaust install I figured why not, lol) and the BMR Suspension driveshaft chassis brace (it's pretty, haha) Waiting on the new torque to yield bolts to show up so I can do the rear cradle lockout and front rear cradle chassis brace installs
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy
YouTube Playlists: Performance Mods | Show Mods | Other Mods
willzilla is offline   Reply With Quote
Old 11-11-2021, 03:48 PM   #11045
MANNAXMAN
MANNAXMAN's Avatar
Originally Posted by flobb View Post
Installed ebay knock-off eos side skirts.
box wedges are just a little extra support while the double sided tape took hold. I used screws on the underside.
Did they come painted? How was the fit and quality? I've thought about purchasing a set from ebay since the cost of the skirts from C7 have skyrocketted since they first became available.
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 11-11-2021, 04:41 PM   #11046
flobb
Drives: 2022 2SS
I bought the cheapest one I could find, and specifically got the "gloss black" ones.
1. They are not black. Not to the naked eye, and definitely not against a black car.
2. They had some of that anti-scuff film covering them which absolutely would not peel off. I ended up taking a sander to them because I had to paint them anyways.
3. Fitment I have nothing to compare to, but they aren't perfect. I got my passenger side on pretty tight with double sided tape across the top and screws underneath. Unfortunately on the driver side I didn't pull the car out and turn around in my garage to give myself more room to work and I have some gapping.
I painted mine with Krylon spray paint and they are still slightly lighter than the OEM black paint. But I clearly wasn't out for show quality from the start.
flobb is offline   Reply With Quote
