Old 11-10-2021, 09:00 AM   #11019
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Originally Posted by Puddin View Post
I was going to ask the same thing since I don't see any anchor bolts.
LMAO about the commercial. Perfect timing. Yes the lift is free floating, it actually came with casters. Im able to lower the lift with the casters on and it lifts it a few inches off the floor and Im able to move the whole lift around even with the car on it. Actually moves a little too easy when its mobile, better to have 2 people to control it. When its off the casters and flat on the ground its very stable, I have it on rubber matts because the floors are a little slick and it doesn't move at all. I liked the idea of being able to change the garage around when ever I want and I'm able to stick the lift way into the corner when a hurricane is in the forecast so I can load the garage with all the cars.
pauly1119 is offline   Reply With Quote
Old 11-10-2021, 09:01 AM   #11020
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Originally Posted by 2nd/6thGenTx View Post
Looks like a good deal on tv for viagra.
Hitting the Vette demographic it seems as well
Old 11-10-2021, 09:12 AM   #11021
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Awesome set up you have there…I had zero idea there was a such thing as a free floating lift that could be moved around (very cool). Do you happen to know the minimum clearance (height)? This may be a better option cost and space wise on my next house.
Note self… look into this
Old 11-10-2021, 09:13 AM   #11022
10mm
Drives: My wife nuts...
What's the make and where to I get one?
10mm is offline   Reply With Quote
Old 11-10-2021, 10:06 AM   #11023
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Thanks, they come in several sizes depending on your ceiling height. My ceilings are about 13 feet in the garage so it’s pretty high. If I put the car all the way up I can’t reach it. It can actually go up one more position in the picture which is about another 6 inches. I’ve had it for about 6 years now and it’s been great.
Old 11-10-2021, 10:09 AM   #11024
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
I bought it from Fast Equipment in Ft Myers Fl. They shipped it and put it in the garage. It’s not the best one in the market but I highly recommend.
https://www.fastequipment.net/
Old 11-10-2021, 10:15 AM   #11025
Chutzpah
Chutzpah's Avatar
Thanks!
Old 11-10-2021, 12:25 PM   #11026
flobb
Drives: 2022 2SS
Installed ebay knock-off eos side skirts.
box wedges are just a little extra support while the double sided tape took hold. I used screws on the underside.
flobb is offline   Reply With Quote
Old 11-10-2021, 01:45 PM   #11027
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
You can not get a GM Ground Effects kit right now. I checked and asked my local dealer. They are no where to be found.
jamala00 is offline   Reply With Quote
Old 11-10-2021, 04:27 PM   #11028
MyneS
STORM
MyneS's Avatar
Drives: 2021 Satin Steel Metallic 2SS
Added some orange
I decided to add a lil bit of color to the interior w orange 🍊 seatbelts.
IG: nacol2012
Check out: The creation of STORM
American Authority Front Bumper, ACS Rockers, GM Dark taillights, ZL1 Carbon Fiber interior dash, Engine Bay “red hot” Dress Up, 6LE Skorpion hood, Borla ATAK w Xpipes (TRADED)
MyneS is offline   Reply With Quote
Old 11-10-2021, 05:25 PM   #11029
hotlap
hotlap's Avatar
Wildhammer shows inventory of GM Splitter and Side Skirts.
I bought the Skirts that I sold from them and they were great
https://wildhammermotorsports.com/16...eneral-motors/
Ronald Reagan -
Old 11-10-2021, 05:26 PM   #11030
TigerFA
Drives: Camaro 2SS 2017 Red Hot
Give it a Catch Can, a Bedi Cleaning and new Injectors....
TigerFA is offline   Reply With Quote
Old 11-10-2021, 06:15 PM   #11031
jamala00
jamala00's Avatar
Hmmm... I wonder if those are a little different? When I look at the GM Accessory site I see different part numbers and the parts seem to physically look different.
https://www.gmpartsdirect.com/oem-pa...nsion-84116168
Old 11-10-2021, 06:59 PM   #11032
hotlap
hotlap's Avatar
I think I see the difference. I posted the gen2 splitter and skirts that came with the 19+. Your number is the earlier style.
I wouldn’t be surprised if GM doesn’t stock any of this stuff to support them after production ends. I believe I saw that the 16-18 dark taillights are no longer available
Ronald Reagan -
