Old 10-28-2021, 09:14 AM   #10949
willzilla
D3RPZILLA
willzilla's Avatar
Drives: 2021 Camaro ZL1 a10
Installed a TackForm Headrest Mount for GoPro & Other Action Cameras into my 21 ZL1
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy
YouTube Playlists: Performance Mods | Show Mods | Other Mods
willzilla is offline   Reply With Quote
Old 10-28-2021, 09:25 AM   #10950
willzilla
D3RPZILLA
willzilla's Avatar
Also washed the car, lol.. Took what felt like forever!
Old 10-28-2021, 09:33 AM   #10951
Hrothgar
Drives: 1971, 1973, 2002 Camaro
Installed the Soler 76mm Throttlebody yesterday and started the ECU Familiarization Process with the new hardware. No Codes thrown yet. This weekend follows the Cold Air Inductions CAI and soon thereafter, the Soler SE0525-DLX throttle controller, which should round out my very modest set of performance Mods.
Hrothgar is offline   Reply With Quote
Old 10-28-2021, 10:34 AM   #10952
BLACK21SS
Oldman w/a teenager brain
BLACK21SS's Avatar
Drives: 2022 ZL1 A10
That’s the car I wish I had bought. Beautiful.
BLACK21SS is offline   Reply With Quote
Old 10-28-2021, 10:39 AM   #10953
willzilla
D3RPZILLA
willzilla's Avatar
Thank you! <3
Old 10-29-2021, 02:13 PM   #10954
hotlap
hotlap's Avatar
Installed the Interior Foot-Well Lighting - GM (23248208)
The install wasn't that difficult. Putting the rear screws back in to install the passenger insulator panel was the hardest part (contortion in order to see the holes. I wore a LED band headlight so I could see everything easily.
https://www.gmpartsdirect.com/oem-pa...hting-23248208
Ronald Reagan -
Old 10-29-2021, 02:39 PM   #10955
Attachment 1083207
We're fellow footwell sufferers then Lying on my back, head stuck in the footwell, legs up on the seat, I cursed the day I'd bought this kit (and I needed a little help with the last bolt, I just couldn't take it anymore).
The end result is definitely worth it, though.
Old 10-29-2021, 05:27 PM   #10956
hotlap
hotlap's Avatar
I had them in my 2016 (ordered with car LPO) and missed them while I had the 18. I bought this kit in June and kept putting off the installation. Now that the days are shorter I bit the bullet.
I was dreading doing this but it turned out to not be too bad. I was face up, feet on ground, with my back arched to see those rear insulation panel bolts.
I took me about 90 minutes total and I was taking my time. If you are handy and fit, it’s doable.
Ronald Reagan -
Old 10-29-2021, 05:27 PM   #10957
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
I did the brake pads last week as I needed to rotate the tires.
The fronts are pretty much toast. They wear a bit unevenly so there are areas that only have 1 mm of pad left so I am glad I got them in time. The rears are also done even though they aren't that worn out, but worn enough that if I head to track days, the tech inspection might give me some trouble.
Yeah the installation is pretty annoying. Make sure to take breaks in between unless you want to break your back.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 10-29-2021, 06:59 PM   #10958
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
So we need to be sure to take breaks while doing our brakes so as not to break our back doing the brakes???
Old 10-30-2021, 12:11 PM   #10959
hotlap
hotlap's Avatar
Got the Sottozero’s mounted today. They’ll go on the car Thanksgiving weekend
Ronald Reagan -
Old 10-30-2021, 09:06 PM   #10960
sequal
Drives: 2019 Camaro 2SS
It was a few days ago now, but a storm took out my power and internet just after completing it.
Fitted my Roto-Fab intake, been meaning to get this done for so long now.
sequal is offline   Reply With Quote
Old 10-30-2021, 09:26 PM   #10961
2SS Capt
2SS Capt's Avatar
Rolled over to 5,000 miles today, not bad for owning the car for just over 21 months (took delivery with 3 miles on the clock).
Old 10-31-2021, 07:03 AM   #10962
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
Since last on here May of '21, I installed a set of yellow/black fuzzy dice...they've yet to require adjustment.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
