#10865 | |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
true. I would rather bet that the car will have more than 556hp than weigh < 3900 lbs. I am fighting myself everyday......impatient and stupid side of me says, "talk to dealer now, make an unofficial reservation, and pay the mark up and order as soon as available". The wife side of me says, " wait til 2013. |
#10866 | |
I used to be Dragoneye...
#10867 | |
Ahhhhhh forget it. Once I start talking about this, I won't stop and before I know it, I am totally obsessed and ready to pay whatever. Sux having OCD.
#10868 | ||
Drives: '11 Mustang GT Premium Join Date: Oct 2010
http://www.cadillacforums.com/forums...009-cts-v.html The official engine weight of the LSA is 467lbs (which is really heavy) undressed and without plumming/exchanger. There was a build being done last year and the engine weighed 544lbs dry but I cannot find the site again (and it was on a scale) I will dig up the discussion about the LS9 weighing 529.9lbs ready to run.. I just need to look into it alittle more. Heres the PDF on the marine LSA weighting 467lbs dry with no auto dress, plumming or exchanger. http://www.gm.com/experience/technol...LSA_Marine.pdf Quote:
![]() Lemme look for that LS9 weight. Both the LSA and LS9 weights are hush fully dressed but there are people that have weighed them... |
#10869 |
Ah, here is the LS9's dry weigh 529.8lbs http://www.chevyhiperformance.com/te...aft_specs.html
I can easily see an LSA being well over 550lbs wet. |
#10870 | ||
#10871 | ||
When the Z28 was being discussed, so was weight... I think once they started adding things on top of the basic SS, they soon realized that this thing was going to be a monster. Just with the engine and transmission alone puts this thing close to 4100lbs. Even the LS9 would only save about 20-30lbs... Now were talking a huge cast iron diff, "beefy" driveshaft, "beefy" halfshafts, exterior moldings, interior work, MRC and other improved suspension/sways. Adding all this up, we start pushing the 4200 mark. This is where the Wheel/tire combo comes in. The exhaust, which should be very similar to the SS's with the exception of the mufflers, manifolds and H or X pipe. I'm not 100% sure, but I think I have heard some folks going with aftermarket exhaust for a 35-45lb weight savings, won't pass emissions so I would say 15-25lbs is a good target area for exhaust. This is only if there are no additional support braces under the car... Its only 20-30lbs but for handling... it has to be done.... |
#10872 | |
Drives: 2003 Cobra Convertible Join Date: Feb 2009
#10873 | ||
![]() Quote:
The fact is they never once addressed a Z28 in any official capacity...so we are held by the facts to believe they never intended to call this King of Camaros by that moniker. I believe differently...and think that after they looked at the sheer capabilities of this new rendition once it was near completion...they decided to take a step beyond heritage and bring the "ZL1" nameplate into the light for the first time. A legend in its own right...it is both old and new; representing raw power and cutting-edge technology. More fitting for this model than even the iconic 'Z28', and I'd have to agree. As far as the exhaust...most of the weight is in the resonators and mufflers on the Camaro. Some have said the mufflers themselves weigh approximately 45 lbs, together. When you figure on replacing them with an axle back....there's the 20 lbs savings...plus or minus. And that's just about what Chevy's done with the Dual-Mode system. As long as the cat converters stay in position...it's an emissions compliant system, after-market or no. There's only a few more things I can bring up at this point...for whatever it's worth... Throw the paper and the time slips and the numbers out of the window for a second. When you have a passenger or two in your car. You're adding 200-400 lbs, unless they are dainty women (in which case, more power to ya!). And unless you're hyper-sensitive...you will not notice this weight...you just won't. Admittedly, you're not racing...but these cars will spend 90% of their lives on public roads, and that must be taken into consideration. Some have said that you're butt-dyno won't really notice that your car is lighter until you take out in the neighborhood of 500-600 sprung pounds. Whether this is "scientifically proven", or not...the fact is 200-300 lbs is hardly detected by your senses when you're already in a 2-ton car.....worrying about how to save 15 at high expense, is simply laughable...I put together that post, only because I enjoyed the math...I don't care if the car weighs 4300 lbs, because I know it will be damn good, regardless. The point of that little rant was to get to this point: The goal with all performance cars, after the numbers game, is to connect with the driver. And even though it's adding some pounds, the ZL1 will be infinitely more responsive and "nimble" feeling than the SS, or even the LT models. THAT'S what's important to me... And with that...I'll stop de-railing the .... 'valued' GT500 rumor thread....
#10874 |
The passenger does not need a six way adjustable power seat!!!! Power seats are heavy man. The difference is like 20-25lbs...
#10875 | |
![]() Drives: f150 Join Date: Jan 2010
#10876 |
Ah, thanks for the gallon of gas weight correction... I hit the scales on the Autobahn the other day and I weighed 1617.963kg with 3-4 gallons of gas. You can definitely feel the difference in the car between a full tank and a 1/4 tank. There is absolutely no other variable that affects performance other than mass...
Edit: If I would have pulled some of the stuff out of the trunk and the car seats in the back I would have been at 3550lbs... There will be about 90lbs coming out of the car shortly. |
#10877 |
Guest
How's all the bench racers doing tonight. I can't believe this thread lasted this long when the car is over two years from surfacing and the ZL1 isn't out until next year. Do you guys all realize that both companies could make changes to these two cars that could make this entire conversation a mute point? Either way it's been fun reading all the BS being spewed in here. LOL
Continue. |
#10878 | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Camaro VS Mustang Mega Thread | Beau Tie | Chevy Camaro vs... | 3644 | 03-09-2012 07:45 PM |
| Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 10:06 AM |
| Official 2011 Mustang GT info released | nester7929 | General Automotive + Other Cars Discussion | 81 | 12-28-2009 03:13 PM |
